Old 05-28-2012, 10:48 AM   #26
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
Been done guy. Thnx tho. Ive done all these other ideas
cosseywrx is offline   Reply With Quote
Old 05-28-2012, 11:19 AM   #27
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
When I cleaned my iacv the old way before my writeup it didn't work even after doing it twice.
2gnt2wrx is offline   Reply With Quote
Old 07-03-2012, 10:08 PM   #28
Strider327
Member#: 131280
2004 Impreza WRX
Mine goes to 1k sometimes slightly over at around 1200 at most. It is definitely reflected on during hot days only. Cold days, no worries.
Strider327 is offline   Reply With Quote
Old 09-03-2012, 01:56 AM   #29
GingerBugEye
Member#: 318903
02 WRX
this worked on my stock 04 and my tuned 02
GingerBugEye is offline   Reply With Quote
Old 04-25-2013, 10:12 PM   #30
dogbert
Member#: 136106
bumping an old thread.
Fixes for this issue?
I have had my CC cable disconnected for some time but would like to actually fix this issue, I cut up a sheet metal heat shield for the CC unit itself as an extra shield from turbo heat but this did not resolve. Anyone have any decent fixes for this aside from pulling the cable off. In my case at least you cant loosen the cable enough to fix it on a warm day.
Only started when I went stage 2 with a tbe, its heat wrapped and I have the factory heat shield although modded to fit the larger dp.)
dogbert is offline   Reply With Quote
Old 04-25-2013, 11:28 PM   #31
wrx1392
Member#: 342331
2003 wrx
blue
my 2003 has been doing this ...i thought it was programed into the Cobb 2 reflash.....but come to think of it i removed the heat shield just before the reflash. mine only does this when in stop and go traffic .going to adj the cable .thanks guys .
wrx1392 is offline   Reply With Quote
Old 05-02-2013, 08:53 PM   #32
wrx1392
Member#: 342331
2003 wrx
blue
made the cruise control adj ....and what do you know while in traffic the idle stay normal the whole time ...thanks for the tips guys.
Old 06-04-2013, 10:05 PM   #33
squeekzilla
Member#: 285961
Alright, Iv'e totally removed my cruise control. I loosened my throttle cable. I cleaned the IACV and replaced the gasket. My car still idles at 4.5k RPM in hot weather only. Right as it cools off at night, I have no idle issues. any help?
squeekzilla is offline   Reply With Quote
Old 06-09-2013, 06:38 PM   #34
allfours
Member#: 339966
I had the same issue today, I adjusted both cables last winter and its been fine since. Today I was idling for a long time and it started idling very high 3.5k max. I then noticed my coolant temp gauge in dash was much lower than it usually is at operating temp. Seems odd, I am going to have to assume its a coolant temp sensor issue giving false readings causing the issue..? Anyone have any experience with this?
allfours is offline   Reply With Quote
Old 06-09-2013, 06:52 PM   #35
cosseywrx
Member#: 276443
Mine does all the same things. Hot days only
Old 06-11-2013, 06:06 PM   #36
boyurlazy
Member#: 129385
As everyone stated the cruise cable expands from the heat and for some reason makes idle go up. Just detach the cruise cable and you will be good. Dealer clip recall didn't work for me or my friend. We both detached the cruise cable and never had this problem again.
boyurlazy is offline   Reply With Quote
Old 06-14-2013, 11:20 PM   #37
captshiner
Member#: 350257
2005 9-2x Aero
Artic Silver
I believe that the gauge and the computer run off of two separate sensors, and the failure of both would be highly unlikely. I would be looking into other issues like the IAC, and TPS, or any other component that could effect idle speed.
My issue was in an '05 Saabaru 9-2x. I have been experiencing the same hot weather idle climb. Eventually, I got back to my garage while it was still happening and check the CC cable; sure enough, it was tighter than it ought to be. Grabbing a 12mm wrench and loosening the cable solved it instantly.
captshiner is offline   Reply With Quote
Old 06-15-2013, 12:30 AM   #38
wrx1392
Member#: 342331
2003 wrx
blue
just loosen the cruise cable(put some slack in it) ...no need to disconnect it ,mine is still working well no more high idle
Old 06-15-2013, 07:03 AM   #39
allfours
Member#: 339966
Thanks for that information, I am going to just keep a wrench in my car and adjust it the next time it happens.
Old 06-15-2013, 12:18 PM   #40
captshiner
Member#: 350257
2005 9-2x Aero
Artic Silver
Just make sure you're loosening the cable, and not tightening it. Seems obvious, I know, but you want to bring both nuts closer to the front of the vehicle. Moving them toward the firewall tightens it.
Old 07-16-2013, 09:13 AM   #41
Volks826
Member#: 359062
I have a impreza rs non turbo and mine does the same exact thing, i know you guys were saying that this happens from the turbo getting hot, could this happen to mine even though i don't have the turbo?
Volks826 is offline   Reply With Quote
Old 07-24-2013, 09:07 AM   #42
2005wrxowner1
Member#: 291158
2005 wrx
wrb
when its hot, mine gets really high. i drove last nite, no problem. hot days, problem.
2005wrxowner1 is offline   Reply With Quote
Old 06-28-2015, 09:47 PM   #43
ritzie
Member#: 417035
in my 04 wrx after sitting at idle for a bit my rpms raise to over 2 and takes awhile after driving for to return to normal but now I'll go and it stays around 4 for a sec or so then only lowers to about 2 not sure what causing it any suggestions
ritzie is offline   Reply With Quote
Old 06-29-2015, 08:38 PM   #44
danger1138
Member#: 279525
04 rex luger!
Its the cruise control cable. Search. Its a known issue when the summer hits and car gets overly hot. Just loosen the nut on the cruise control cable. Simple fix.
danger1138 is offline   Reply With Quote
Old 07-24-2015, 07:29 PM   #45
ritzie
Member#: 417035
awesome did exactly that completely fixed the issue
Old 07-27-2015, 06:38 PM   #46
Trentond123
Member#: 426755
How do you adjust the throttle and cruise control cable?
Trentond123 is offline   Reply With Quote
Old 07-28-2015, 07:43 PM   #47
danger1138
Member#: 279525
04 rex luger!
Default 2004 WRX hanging/high idle issue
You just adjust the cruise cable not throttle cable.
There is a nut where the rubber portion of the lines begin, smack dab in the middle top portion of intake manifold.
Just loosen the back nut on the cruise cable all the way so that there will be more slack on the line.
FS : 2004 WRX Helix High Flow Cat Downpipe brynboy SCIC Private Classifieds 6 12-06-2010 05:39 PM
FS : VA 2004 WRX STI Highly Modded $21k OBO billy720 Private Vehicle 'For Sale' Classifieds 1 11-11-2010 11:16 PM
another high idle issue, with lights dimming R-raid Service & Maintenance 14 08-23-2010 10:46 PM
high idle ISSUES!! majunche66 Built Motor Discussion 6 03-14-2009 07:44 AM
People with cold startup high idle issues 98EJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-22-2008 06:47 PM
