Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 01-18-2011, 10:06 AM   #1
2005rs
Member#: 126753
2005 2.5 RS
black
Default CEL on my 05 rs
I have a cel light on my 2005 Rs
the codes are
p0031 HO2s heater control circuit low bank 1 sensor 1
p0131 02 sensor low voltage sensor 1 bank one
p0037 HO2s heater control circuit low bank1 sensor 2
p0134 02 sensor no activity bank one sensor one
I have already replaced the front A/f ratio sensor. were is the next place i should look for a solution
2005rs is offline   Reply With Quote
Old 01-18-2011, 07:52 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Look in the wiring going to the oxygen sensor. All of it. Check all connections, all grounds, did you reset the ECU after replacement?
yarrgh is offline   Reply With Quote
Old 03-29-2012, 09:32 PM   #3
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
I see this is over a year old now, but did you find the problem ? Working on a 05RS also, had the P0031 & P0134 codes. Checked the old sensor with a muiltimeter and the heater was dead. It should be around 10 ohms it said, this one was open.
Put on new O2 sensor, cleared the codes, it got rid of the heater code but still gets P0134 after a minute or 2 of driving. Testing the sensor shows it's outputting voltage when the car is running, but the computer is not seeing it. On the scope, the computer says the O2 sensor is flat at .02 volts.
The strange thing is the computer is putting back out about .350 volts on the sensor wires if you unplug the sensor and probe the car side of the plug and then 14 volts on the 2 heater wires, but that part is ok.
Im thinking the ecu may have failed to put putting out power on the sensor inputs ? Anyone else have to change a computer for this reason ?
bobjr94 is offline   Reply With Quote
Old 04-10-2012, 12:26 PM   #4
Colando Dunes
Member#: 262977
2002 2.5 RS
silver surfer
Currently have a p0131 (low o2 circuit voltage) on an 05 rs. Just changed the o2 sensor for a denso, now code only comes back after harder acceleration (does this have to do with open vs closed circuit conditions? Still reading up on all of that).
Colando Dunes is offline   Reply With Quote
Old 12-03-2012, 08:47 PM   #5
BlobEyeRS
Member#: 336270
2011 Wrx limited
Just pulled similar codes from my 05 RS. I have a new o2 sensor to put in and going to replace the cat too just in case. Hoping it's not the ECU...
p0131
p0031
p0134
p0297
BlobEyeRS is offline   Reply With Quote
Old 12-03-2012, 10:55 PM   #6
bobjr94
Member#: 6176
15 WRX, 04 wrb STi
85 wrb BRAT
As a follow up, it turned out the auto parts store sold me the wrong sensor, a narrow band sensor that only works for the rear. I got the correct one online and it fixed the problem.
Old 01-14-2013, 11:31 PM   #7
BlobEyeRS
Member#: 336270
2011 Wrx limited
I think part of my problem is an exhaust leak at the header/cat flange which is also leading to the CEL issue.
Old 05-03-2013, 02:47 AM   #8
JR Imperial
Member#: 214161
I know this is hella late but I'm getting P0031 and P0037 on my 05' RS. I replaced both the a/f sensor and the o2 sensor and disconnected the batter and tried to clear the code but CEL comes back on immediately after start up. I don't know what else to do. I know you can check resistance or something in the wires to see if the sensors are getting voltage, but I don't know which wires to check and what the voltage or resistance should be. FML.... If you guys got any suggestions for me it would be much appreciated!! Thanks!
JR Imperial is offline   Reply With Quote
05 saabaru catback on my 05 RS RallyImp05 Normally Aspirated Powertrain 3 08-13-2007 07:24 AM
06 wrx TR rims on my 05 RS (pics) al27an Normally Aspirated Powertrain 23 09-22-2005 11:27 AM
rs mudflaps wont fit on my 05 rs. rsracer2005 Interior & Exterior Modification 6 03-30-2005 11:37 AM
Steering is all messed up on my 05 RS rsracer2005 Service & Maintenance 5 01-08-2005 12:01 AM
What will fit on my 05 rs Honkey3k Impreza Forum 0 12-06-2004 02:58 PM
