Old 05-01-2013, 04:03 AM   #1676
skytup
Member#: 354711
2012 wrx permium
satin white
hi guys, lovin all the photos more boot install shoots and specs on setups
im from aus and just trying to orgainise a setup for my ride
skytup is offline   Reply With Quote
Old 05-01-2013, 01:45 PM   #1677
Sato_unit
Member#: 230417
Originally Posted by akidnamedbucki View Post
Finally!!!
Im confused. This is on air?
Sato_unit is offline   Reply With Quote
Old 05-01-2013, 02:36 PM   #1678
Triff Traff
Member#: 241415
2004 Forest STI
Untitled by AG-Studios, on Flickr
Triff Traff is offline   Reply With Quote
Old 05-02-2013, 05:28 PM   #1679
morph1n3
Member#: 149742
2002 gears go
weeeeeeeeeeeeeeeeeeee
Still need to roll my fenders and get of these fat-****ing 245's.
morph1n3 is offline   Reply With Quote
Old 05-02-2013, 05:36 PM   #1680
Wirtz
Member#: 286408
WFC #952
Function:error!
Whats so bad about 245s? I tuck 245/35 on my 10.5 wides no problem and you're on air
Wirtz is offline   Reply With Quote
Old 05-02-2013, 06:06 PM   #1681
morph1n3
Member#: 149742
2002 gears go
245 on an 8 with a high-offset isn't doing it for me, I'd just prefer something a little skinnier. Not that it really matters for these wheels anyway, as I'll be acquiring something new in the not to distant futre (hopefully).
Old 05-02-2013, 06:46 PM   #1682
allmotorvr
Member#: 319472
2012 WRX sedan
Posted this in the tech thread but there idnt much action over there. What would cause the v2 to constantly need to be calibrated. When I go to use my presets theyre always saying not calibrated. I calibrate it. It works for a couple days and then goes back to needing calibration.
allmotorvr is offline   Reply With Quote
Old 05-02-2013, 07:54 PM   #1683
xxscaxx
Member#: 86459
2013 BRZ
how do you have your ignition wire hooked up? Have you called AirLift? they are very good with getting things like this straightened out.
xxscaxx is offline   Reply With Quote
Old 05-02-2013, 10:24 PM   #1684
Bizborky
Member#: 337362
2013 WRX
Stock wheels for the loss
Bizborky is offline   Reply With Quote
Old 05-03-2013, 12:17 AM   #1685
Sato_unit
Member#: 230417
Im so confused. Half of these cars dont even looked bagged. wtf is going on.
Old 05-03-2013, 01:20 AM   #1686
Jim.mEh
Member#: 84517
05' Imprezilia
CruiseControl Warrior
You complain to much, when people arent doing it your way.
Why is it the concensus that you have to be tucking tire, rim or laying frame to be properly bagged on air.
They may have it where they like it.
Jim.mEh is offline   Reply With Quote
Old 05-03-2013, 02:01 AM   #1687
DoobyDo
Member#: 318103
2009 wrx sedan
obp
Finally some good weather in WA.
DoobyDo is offline   Reply With Quote
Old 05-03-2013, 03:09 AM   #1688
skytup
Member#: 354711
2012 wrx permium
satin white
r they aftermarket side/ rear skirts?
Old 05-03-2013, 03:23 AM   #1689
skytup
Member#: 354711
2012 wrx permium
satin white
Originally Posted by Bag Riders Air Ride View Post
Looks awesome Abbitt!
I hope everyone had a great weekend! Kevin and I spent the weekend at the shop working on our Subies, so I can't complain I worked on putting 2.5i back to stock before diving into my new WRX, whereas Kevin actually made forward progress on his car :P Using the AccuAir eXo Mounting System, Kevin mounted dual 3 Gallon black powder coated tanks to his parcel shelf. Cleaaaaaaan!!
Who is Kevin? This guy.
I'll have a build thread going for my WRX in a couple days, first up will be the air suspension. I've prepped the chassis a little bit and have been taking pictures along the way!
i like this idea mounting under the parcel shelf (floating look), can the compressors be mount on the exo mounts in this config.
Old 05-03-2013, 04:35 AM   #1690
Silver Sedan
Member#: 259220
2005 RWD STi
Silver Sedan is offline   Reply With Quote
Old 05-03-2013, 11:18 AM   #1691
rmarchigiani
Member#: 164584
2011 WRX STi
SSM
Agreed.
rmarchigiani is offline   Reply With Quote
Old 05-03-2013, 01:31 PM   #1692
Wirtz
Member#: 286408
WFC #952
Function:error!
Originally Posted by Silver Sedan View Post
I see what you did there
Old 05-03-2013, 02:10 PM   #1693
Sato_unit
Member#: 230417
Well usually when you bag a car. It's for reason to be lower than on static, or else most would just buy springs and/or be static and save yourself 2-3 grand.. But i guess some may use them for god who knows and waste money. Im just trying to grasp the fact you could buy coilovers and saved yourself plenty of money. But i guess if you have that kind of money. MBN.
Plus one to airlift lmao
Old 05-03-2013, 02:52 PM   #1694
Justafour
Member#: 252066
2012 WRX LTD
DGM Sedan
the roads are terrible where i live, so are driveways, speed bumps, etc... it seems everything is made for trucks around here. if i got air lift my daily driving height would be around what you see from most others using coilovers, but i would have the option to lift when needed to protect my car. i cant tell you how many times i ripped the exhaust out of my camaro that was at stock height around here . oh and not to mention being able to hook air tools up from my trunk.
Justafour is offline   Reply With Quote
Old 05-03-2013, 05:31 PM   #1695
allmotorvr
Member#: 319472
2012 WRX sedan
Its hooked to a switched 12v in the fusebox. No I haven't contacted airlift directly yet. Figured here was just as good
Old 05-03-2013, 07:41 PM   #1696
toyotabb
Member#: 315709
2012 wrx sti wagon
pbp
It really needs to go to the ignition. Pretty much anywhere else causes issues.
toyotabb is offline   Reply With Quote
Old 05-04-2013, 01:54 AM   #1697
Strawhatrr
Member#: 267395
*Grumpy old man voice*
Back in my day, we used to bag our Subaru's to be lower than everybody else!
Now they just do it so they can be "hellastanced" without having to work at it.
/haterrant
Kyle's and Tay's car are the lowest on this page. Shame on us bag owners!
Edit: Except that GR on Klutch wheels. Noice!!
Strawhatrr is offline   Reply With Quote
Old 05-04-2013, 09:22 AM   #1698
no vtec 4me
Member#: 298688
A few shots of my car from S.N. Photography yesterday. Check him out on facebook at SN.Photography and on Instagram @SN.Photography
no vtec 4me is offline   Reply With Quote
Old 05-04-2013, 11:36 AM   #1699
ocdpvw
Member#: 282232
2012 TP Stage 3
Bagged SWP & Bagged DGM
Kevin! You made it
ocdpvw is offline   Reply With Quote
Old 05-04-2013, 02:24 PM   #1700
Tonbone23
Member#: 135998
2007 WRX Wagon
my first bitch, on air ride
now my new bitch fully tucking 19x10 et20 with a 275 tire in the rear and 19x19 et20 245 in the front will be going bigger next year
Big Thanks to John from bag riders helped me out with both cars
Tonbone23 is offline   Reply With Quote
Air ride/air bag shops in the NW? Mr. Sadface North West Impreza Club Forum -- NWIC 10 10-17-2013 12:59 AM
FS : WI: BMW 740il on Air ride Jester of Paint Private Vehicle 'For Sale' Classifieds 9 04-16-2012 07:49 PM
Suby high speed ride? ProvenPSI General Community 60 08-22-2007 08:40 AM
Tahoe on 20" wheels, and Air Ride ON EBAY!!!! airbags98 Private Vehicle 'For Sale' Classifieds 6 11-19-2005 10:08 AM
All Subies on the Marine Corp air station redgrocerygetter South East Region Forum 8 08-29-2003 05:26 PM
