Old 02-21-2013, 02:33 AM   #751
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Originally Posted by Bariga View Post
hmmm, thats why the orficer said i was going 65 and i wasnt
So what ever you set in there also reflects the gauge cluster reading?
Base map from my Plug in board for 2007 sti had it at 240
Doesn't affect gauge cluster.
Weird... Most Subaru base maps have it at 260.
255 worked for me! My tires are 295/30/18 which is same diameter as stock 225/45/17. If your tires are taller or shorter then it would make a difference.
Old 02-25-2013, 11:23 PM   #752
J3SST3R
Member#: 298926
2007 USDM STI
When you swapping your head gasket out Arthur?
you should have green grass and +15 weather over there by now dont you? haha
J3SST3R is offline   Reply With Quote
Old 02-26-2013, 01:53 AM   #753
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
our weed is always green here bro
Bariga is offline   Reply With Quote
Old 02-26-2013, 02:14 AM   #754
alcoolaid
Member#: 134949
'07 SWP STi
i'm so lazy... should have done it when i had more time a couple weeks ago.
now it's tax season and i'm working 10-12 hours a day
grass is getting greener but still around 5-7C with rain this week. last week was warm! what the hell!
Old 02-26-2013, 02:14 AM   #755
alcoolaid
Member#: 134949
'07 SWP STi
you wish
Old 02-26-2013, 09:02 AM   #756
J3SST3R
Member#: 298926
2007 USDM STI
I know the feeling, sounds like your getting Calgary weather lol, except instead of rain we got snow last night, yet it was +7's on weekend??
At this rate I won't get anything done until June haha
Like they say, Grass Is greener on the other side. Haha
Except for you Alex
Old 03-01-2013, 02:01 PM   #757
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
Did you get around to swapping the head gaskets yet?
06rexwagon is offline   Reply With Quote
Old 03-01-2013, 03:14 PM   #758
alcoolaid
Member#: 134949
'07 SWP STi
Unfortunately not yet. Lol it's been so long since I said I was going to do it.
How is your benson block? What head gaskets did you end up using? Any sealing issues?
Old 03-01-2013, 03:15 PM   #759
gregonfire
Member#: 181047
2015 CWP WRX Limited
2010 WRX 310/345 - Sold
How do you like being an accountant? I am an accounting major graduating this may. I've done a couple internships, but mainly just bookkeeping and not in a firm type environment. I know this is off-topic so feel free to PM me if you don't want your thread cluttered.
gregonfire is offline   Reply With Quote
Old 03-01-2013, 03:25 PM   #760
06rexwagon
Member#: 114730
[email protected]
So far it's been good. Using the Cosworth gaskets and L19 studs.
Old 03-01-2013, 07:37 PM   #761
alcoolaid
Member#: 134949
'07 SWP STi
It's alright. Kind of boring at some times but the pay is really good. 5/6 members in my family are accountants so what can I say haha. Dad runs his own private accounting company and he's getting quite old now so will probably have to take over soon. I got the easy way in terms of finding a sponsor, getting advice, etc.
It's amazingly competitive in BC to become a CA so if you don't have grades or work hard enough you won't be able to get a job in the field as a CA.
Old 03-01-2013, 07:38 PM   #762
alcoolaid
Member#: 134949
'07 SWP STi
Dammit, only if I had used cosworth head gaskets from the beginning. Never wanted to use cometic but I was told they weren't going to be an issue.
Oh well at least I won't have to oring the block because you're running a lot more boost than i plan to.
Old 03-01-2013, 11:41 PM   #763
WhatTurboLag?
Member#: 243992
2006 WRX TR
More antilag videos!
WhatTurboLag? is offline   Reply With Quote
Old 03-12-2013, 10:25 PM   #764
GA scooby
Member#: 229518
2011 STi
Amazing car and sweet little shop set up you've got going.
31 pages of awesome.
GA scooby is offline   Reply With Quote
Old 03-15-2013, 01:25 AM   #765
alcoolaid
Member#: 134949
'07 SWP STi
I'll try to do some when the engine gets new head gaskets... maybe we'll play with it on the dyno this time
Old 03-15-2013, 01:25 AM   #766
alcoolaid
Member#: 134949
'07 SWP STi
Thanks man!
Old 03-15-2013, 01:31 AM   #767
alcoolaid
Member#: 134949
'07 SWP STi
Been a while since I turned any nuts and bolts on the car. Decided to put my arp extended wheel studs on today.
Rear was a piece of cake going through the abs sensor hole. Just needed a bit of grinding with the angle grinder and stone bit.
Front was a little more work. Had to crack the axle nuts loose, push the axle back in a bit, remove the 4 bolts holding the hub in, pull it out a bit, then put the studs in.
Rear rotors finally hit minimum thickness
Old 03-20-2013, 06:43 PM   #768
alcoolaid
Member#: 134949
'07 SWP STi
Not Subaru related but a truck I bought was delivered to my house today.
2001 F350 SD 7.3 Powerstroke Diesel
Has a 6.5" lift and 37" BFGoodrich 37" A/T's on it right now. 4" exhaust, etc.
Needs some work right now. Oil cooler o-rings, rear diff pinion seal, new glow plug relay and glow plugs, etc. Maybe new injector o-rings.
Transmission was completely rebuilt just a year ago. Needs some body work too but I got it really cheap
Old 03-21-2013, 05:23 AM   #769
cRashtEstDumy
Member#: 291602
2007 Limited STI#464
Wow that's different! At least it's got a turbo!
cRashtEstDumy is offline   Reply With Quote
Old 03-21-2013, 09:28 AM   #770
ryan s.
Member#: 276486
'08 lowered Outback
I would love to have that F350!
ryan s. is offline   Reply With Quote
Old 04-10-2013, 08:45 PM   #771
Splat_One
Member#: 5857
2004 STI
subscribed for knowledge, thanks.
Splat_One is offline   Reply With Quote
Old 05-02-2013, 08:12 PM   #772
alcoolaid
Member#: 134949
'07 SWP STi
Small photo shoot we had yesterday. Just all the car friends I grew up with. Some of them are selling their rides so we decided to get everyone together one last time.
Old 05-02-2013, 10:29 PM   #773
russgt
Member#: 256322
Thats awesome man! Yours looks so tough!
Also love the true track spec brownbos! haha
russgt is offline   Reply With Quote
Old 05-03-2013, 03:34 AM   #774
tbtstt
Member#: 233064
05 STi Type UK PPP
WR Blue
Quality photo: something there for everyone!
tbtstt is offline   Reply With Quote
Old 05-03-2013, 01:06 PM   #775
slowguy
Member#: 4326
awesome pic arthur!
slowguy is offline   Reply With Quote
04 STi Weekend Warrior Blazin Brakes, Steering & Suspension 2 03-07-2008 02:10 PM
So I just found out I need hand surgery tomorrow...Weekend warriors be careful! Neek Off-Topic 45 12-12-2006 09:30 AM
Attention Car Enthusiast’s, Car clubs, & Weekend Warriors GotTurbo Tri-State Area Forum 15 08-11-2006 02:46 PM
Optimum weekend warrior suspension set up? EarlQHan Brakes, Steering & Suspension 15 11-03-2005 01:18 AM
What pads are folks using for daily driver/weekend warrior? Mephiska Brakes, Steering & Suspension 6 06-28-2002 02:08 PM
