Old 07-24-2009, 01:05 AM   #126
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Originally Posted by lumberchicken View Post
28ft/lbs is measurement of Torque - are you looking for a conversion to another unit of measurement?
Sorry, what I mean is - is 28 ft/lbs something you can torque down using simple hand tool..
Old 07-24-2009, 07:51 AM   #127
Originally Posted by txl146 View Post
This maybe a dumb question...
Uppipe - exhaust manifold bolts are supposed to be tightened ~28ft. lbs. Has anyone had leaky gasket due to over-tightening? Secondly, how much torque is approximately 28ft/lbs? Thanks.
that is usually not quite enough
i always tighten eveything to 25ft-lbs and then go back and up evrything to 35ft-lbs and done
i get few leaks
and to get any proper torque you need a torque wrench
Old 07-24-2009, 02:26 PM   #128
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Yes, 28 ft/lbs can be managed with even a small (6 inch) 1/4" drive... It's tough, but can be done. However unless you have a torque wrench, and if I had to GUESS, most people will overtorque everything because they think its a lot. The few things people tend to undertorque is the crank pulley bolt, Cam gear bolt, and axel nut.
Do yourself a favor and buy a torque wrench... yeah they might be stupid exhaust bolts right now, but what about when you finally do your TGV's, or clutch, or timing belt? there are more precise bolts that WILL snap if overtorqued... ask me how I know. ( For the record, I set the torque wrench properly (7 lbs) for the small intake to TGV bolts and my friend picked it up and set it to 18 lbs to get the longer TGV to block bolts. I didn't realize he did this and I snapped one off. )
paintbing is offline   Reply With Quote
Old 05-02-2013, 08:00 PM   #129
nateleeg
Member#: 332396
2003 Impreza WRX
Rally Blue
I just want to know if it's possible to replace the uppipe without removing the downpipe. Since I'm only going to be doin the up first, I'de rather not unbolt the stock downpipe only to put it back on. Yuck.
If I had more money i would do the down at the same time, but thats not my case
nateleeg is offline   Reply With Quote
Old 05-02-2013, 08:20 PM   #130
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
One of the bolts is right under the DP flange. RIGHT under it. You have to unbolt the downpipe from the turbo and move it back like 2 inches to get to the nut. The good news is that it's really easy to do this if you have the stock downpipe.
Old 05-03-2013, 07:57 AM   #131
pebelz
Member#: 268632
2015 XV
After researching for months I finally bought a used 07 STI uppipe for my 04 wagon. I felt $60 was better than me cussing and busting knuckles removing the Cat. So I got my new gaskets and decided I'd take it to my mechanic instead of me suffering for a day or so. I have some tools and jack stands, but really no help unless you count the wife pumping the breaks when I installed SS lines, lol. So after it was all done $60 for the Up, $30 for gaskets, and $268 to Dixie Dan for labor. The only work I did was the resistor mod before the work was done.
I am very pleased with the sound and throttle response. My gas mileage is better, too.
pebelz is offline   Reply With Quote
Old 05-03-2013, 10:44 AM   #132
Fir3Fighter
Member#: 316780
2003 Impreza WRX
Unbolting the downpipe is least of your problems with doing an Up pipe lol. Good luck!
Fir3Fighter is offline   Reply With Quote
Old 05-03-2013, 10:45 AM   #133
Fir3Fighter
Member#: 316780
2003 Impreza WRX
You should have saved your $268 and done it yourself or maybe with a buddy. Its really not that hard but oh well its done now for ya!
Old 05-03-2013, 01:10 PM   #134
04IncreasedWRX
Member#: 325135
2004 Impreza WRX
2 1/2 hours for me. I have mechanic experience, nothing major though. Jack stands, in front of where my wife used to work actually.
04IncreasedWRX is offline   Reply With Quote
Old 05-03-2013, 04:22 PM   #135
pebelz
Member#: 268632
2015 XV
Yeah, none of my buddies are remotely able to work on cars. $268 was money well spent IMHO. I have no cuts, bruises or high blood pressure from the install either, lol!
Old 05-03-2013, 05:40 PM   #136
projectQWKSLVR
Member#: 285270
03 WRX
The uppipe was easy, maybe an hour. Guess I'm spoiled with a lift in my garage! :-)
You want a challenge? Try motor mounts! Not much fun with everything still in the car.
projectQWKSLVR is offline   Reply With Quote
Old 05-03-2013, 06:18 PM   #137
Nikryj
Member#: 346659
I wish I had paid for I installation. I sheared off part of my head when a nut seized on the header. Bad times....
Nikryj is offline   Reply With Quote
Old 05-03-2013, 06:20 PM   #138
mitch808
Member#: 10228
2002 Subaru WRX
Both are easy with the right tools, and you only need a minimum of jack stands/ramps.
The problem is that it took a couple years after the bugeye for the process to be well documented here.
mitch808 is online now   Reply With Quote
Old 05-03-2013, 06:30 PM   #139
nateleeg
Member#: 332396
2003 Impreza WRX
Rally Blue
Ha thanks guys, so the downpipe isn't my worry. What about having to jack up the motor an inch or two to pull out the original uppipe? That sounds a little outside of what I have in my garage
Old 05-03-2013, 06:32 PM   #140
Nikryj
Member#: 346659
You will more than likely have to jack it up. Easiest way to do it is I remove the nuts on the motor mounts. Stick a 2x4 on your jack so you don't punch a hole in your oil pan, and lift a couple of inches.
Old 05-03-2013, 06:51 PM   #141
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
It's no big, you can just loosen the motor mounts (14mm easy to reach, but may need a breaker bar) and jack the crosspipe. Don't jack the oil pan. Or you can do the 2x4 thing mentioned. Slip one end between the oil pan and exhaust manifold and put the other end on the jack.
It's not like you're pulling the engine, you're just raising it an inch or two to get clearance between the fender and the block so you can get the pipe out. Nothing to stress over.
Old 05-03-2013, 06:53 PM   #142
super_usdm
Member#: 286211
1993 Legacy SS
Motor mounts are a cakewalk compared to the UP.
super_usdm is offline   Reply With Quote
Old 06-23-2013, 01:23 AM   #143
anasty88
Member#: 358727
2002 wrx
red
Was swappin mine out today , started at 1 stopped at 12 am gonna finish up tommorow , spent 3 hours on the heatsheields alone, Wat a pain in the ass lol, heads of the bolts came right off wasnt 10mm no more so rusted , another 2 hours trying to get the turbo off and theres one Bolt on the upipe the goes in this bracketlts just say it was alot of fun and by myself also, I aint no Master machanic hopefully installing goes alot faster
anasty88 is offline   Reply With Quote
Old 07-09-2013, 04:11 PM   #144
ScottFromMi
Member#: 361835
Pearl Blue
Hello, just lost a turbo due to my up pipe coughing a healthy chunk of cat into it. I have a broken turbo inlet pipe and an O2 sensor on the up pipe that has a bad heater circuit all within a month. Good thing it all happened at once... I want to go catless up pipe, but if I do, is there an O2 sensor bung in any of the decent priced parts out there? I have everything apart and Im just waiting for some cash to get ordering. I need the following parts, any input would be much appriciated!
Turbo - as close to stock as possible, needs to still be a daily driver
Up pipe - catless to prevent this from happening aga7n, but still have a bung for the o2 sensor
Turbo inlet tube - not a b7g deal if I have to pull intake to get it in, I destroyed the broken plastic p.o.s. removing it.
Intercooler hoses if I have cash, the plastic is just not really giving me a warm fuzzy and since I have it all apart...
I live about an hour and a half north of detroit, so if I need to have it tuned after, its not a major deal just need to know what people out there are recommending. I have about 160k miles on my 02 wrx currently, I was getting about 26mpg on average best was 33mpg on highway last 4th of july and I would like to keep it that way!
ScottFromMi is offline   Reply With Quote
Old 07-09-2013, 04:39 PM   #145
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Used TD04 - $75-$100
FMS/Gimmick/Used 06-07 WRX/STI - $50-$200
Stock/Gimmick/Samco/lots of others - $100-300
Samco/Grimmspeed/lots of others - $100-$150
Old 07-09-2013, 06:39 PM   #146
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
Few things:
1) The O2 sensor is in the RH exh. manifold, not the uppipe. There is an EGT sensor in the uppipe which can be deleted (it's only there to monitor the pre-cat), just run a resistor across the connector contacts.
2) you can remove the uppipe fairly easily from the top side with the turbo out of the way
3) get a silicon inlet, a hard inlet will ave you hating life after about 4 hours of fitment struggle
Old 07-09-2013, 07:11 PM   #147
04IncreasedWRX
Member#: 325135
2004 Impreza WRX
Damnt, i posted here already. My bad.
Old 07-10-2013, 12:42 PM   #148
ScottFromMi
Member#: 361835
Pearl Blue
Originally Posted by T-37 View Post
Few things:
Ahh, I saw the sensor on the uppipe and assumed it was the o2 that I have to replace. I'll search for the resistor to hardwire in soon on the forums. I saw a replacement guide for the o2 sensor elsewhere on the web, got the denso part number and the 22mm socket bookmarked already.
Yeah, the uppipe looks pretty manageable now, plus my nephew is a mechanic and had pretty good luck with all the bolts after some pb blaster and 15minutes wait time, even the heat shield on the turbo came off without snapping any bolts.
Perrin has a wire reinforced silicone hose, probably going with that, just thinking about taking the intake off to get different ones in make me groan... clipped the pcv valve adapter and the old one came out just fine
Thanks for the support everyone! I was on the right track but I wanted to make sure I took care of my wrx as well as it has for me in the past 12 years now that I can afford to do some of it.
Old 08-02-2013, 01:31 AM   #149
rdeezWRX
Member#: 349202
Platinum Silver Metallic
Has anyone done the install without disconnecting the Dp from the catback? I didn't order a new gasket for that section and was wondering how much harder it would be to do it if I just dropped the Dp and moved it out of the way? Or if I completely removed the whole exhaust system as a whole? Any insight would help! I wanted to start Sunday since Monday was my only day off and it gives me enough time if I hit problems.
rdeezWRX is offline   Reply With Quote
Old 08-02-2013, 06:56 AM   #150
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
dropping the entire exhaust is pretty common and works well, but it's a lot easier with a second set of hands. ..
for the sake of man, and mans best friend. please help seventhsign North West Impreza Club Forum -- NWIC 75 06-25-2009 07:15 PM
Pa. 07 sti uppipe and 02 wrx uppipe project x Engine/Power/Exhaust 4 05-05-2007 09:50 AM
f/s 2004 wrx stock turboback exhaust and stock wrx uppipe Scooby_Wong SCIC Private Classifieds 14 03-05-2007 10:08 PM
FS: TurboXS Uppipe and OEM WRX Uppipe. paper_tiger Private 'For Sale' Classifieds 13 11-04-2005 03:27 PM
What's the update on the "Battle of the Turbos"? Jonathan Kent General Forum Archive 5 08-29-2000 10:29 AM
