Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 02-25-2013, 05:36 PM   #401
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by Phatron View Post
You should never change anything on your car and not recheck the tune.
Let me follow up with another question...
If I install this and drive (like a normal sane person ) for a few hours to the dyno tuning session, will there be and adverse effects?
Old 02-25-2013, 06:10 PM   #402
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
The stumble would probably still be there since the massive compensations are still in there when no longer needed.
Old 02-25-2013, 08:46 PM   #403
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
So with the new fuel line/fpr setup you can zero the ELC table?
Old 02-25-2013, 08:59 PM   #404
hutch959
Member#: 267463
iwsti post claiming low load knock goes away.
the typical low load -1.4 "just noise, or random" magically disappears.
input??
hutch959 is offline   Reply With Quote
Old 02-25-2013, 09:44 PM   #405
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
For those interested there are two primary threads outside of nasioc where for the past few months people have been posting up the details of the 3 ft hose mod + tune. I linked near towards the end of the threads:
http://www.romraider.com/forum/viewt...4911&start=270
and
http://www.iwsti.com/forums/2-5-lite...d-line-14.html
Old 02-26-2013, 05:49 PM   #406
Boostedbob
Member#: 336241
08 Sti
OPB
I will be doing the 3' fuel line tomorrow and be sending out datalogs to [email protected] Performance. Ill let you all know how it goes.
This stutter has been a problem since I went with 1000cc injector's and on 91, It is only real bad at low rpm's at 1700rpms where I start bucking and stuttering. Strangly I do not have tis issue with e85, though there is still a noticable stumble at 2800rpms.
Boostedbob is offline   Reply With Quote
Old 02-26-2013, 07:00 PM   #407
Maxwell Power
Member#: 190729
is your tuner using a Cobb AP and is he updating the Short Pulse Adder tables?
Maxwell Power is offline   Reply With Quote
Old 03-03-2013, 02:34 PM   #408
Boostedbob
Member#: 336241
08 Sti
OPB
Not sure if your talking to me Maxwell, however he is tuning my car through the Cobb AP until I go OS, but I do not know if he is updating the Pulse Adder Table's.
On to the good new's I am on my 4th revision on my tune since I did the 3' fuel line replacement. Car is much much smoother in the 2600-300rpm's and seems to be doing better over all since the mod. However I still get some nasty mis fire's in the lower rpm's, 2nd gear 15-20mph and 3rd gear at 35mph, It will run alright for a little bit then start mis firing, Eric doesnt know why it does it. On E85 it doesnt do it just on 91.
Hopefully the latest revision will fix the issue but I doubt it.
Overall this is a must do mod! Very happy@
Old 05-03-2013, 04:36 PM   #409
tja1618
Member#: 181995
2003 WRX
With an appointment, does Phatbotti do e-tunes via a remote desktop connection? So, if I didn't want to send logs back and forth, can you just do the tune live, remotely? Using either Windows Remote Desktop, Norton, or some other client.
A tuner my friends use does this all the time on EVOs and DSMs, and some Subarus. I am asking because I need a remote tune for when I first start up my new engine. I'd rather not tow it across the state.
tja1618 is offline   Reply With Quote
Old 05-03-2013, 05:20 PM   #410
Phatron
Member#: 36033
CEO PhatBottiTuning
I have never done that. But it would really only make sense with an AP and real time tuning. If you're opensource the 5 second step of sending the email would be all the time u would save.
And if you have an AP I would have to unlock the map for it to be done and that defeats the whole purpose of paying the money to be able to use the Protuner software.
Old 05-08-2013, 12:45 PM   #411
Motoxdude6
Member#: 344454
2011 wrx
phatron, ive been recomended to you by a few people for a good etune. send me a PM with more info and if it can all be done by the 22nd cause im driving to california for vacation. let me know ASAP, id appreciate it! if you need my phone number let me know
Motoxdude6 is offline   Reply With Quote
Old 05-08-2013, 07:46 PM   #412
Phatron
Member#: 36033
CEO PhatBottiTuning
why didnt you just pm me? lol
Tuning Prices & What You Need
http://forums.nasioc.com/forums/show....php?t=2200994
Old 05-09-2013, 01:04 PM   #413
Maxwell Power
Member#: 190729
uh oh. No patience. Turn him away.
Old 05-10-2013, 08:57 AM   #414
Mr645
Member#: 320769
2012 WRX 5 door
Have you ever figured out how to disable the P0420 code on your open source tune?
'12 WRX stg 2 catless dp.
I tried two washers on the O2 but the error comes back sometimes. I have been clearing it from time to time with Torque on Android.
Mr645 is offline   Reply With Quote
Old 05-10-2013, 02:38 PM   #415
Phatron
Member#: 36033
CEO PhatBottiTuning
you open up the map and turn it off. who ever tuned you car should be able to turn it off in 2 seconds.
Old 05-10-2013, 06:40 PM   #416
Mr645
Member#: 320769
2012 WRX 5 door
Mikey tuned it. He said it can't be turned off unless I get an AP
Old 05-10-2013, 08:53 PM   #418
Mr645
Member#: 320769
2012 WRX 5 door
I don't have it. I just drove up, Mikey jumped in, plugged in his laptop, we were for a ride, he tuned it and that was it.
Old 05-10-2013, 09:24 PM   #419
Phatron
Member#: 36033
CEO PhatBottiTuning
are you opensource? if so, just find a local with a tactrix cable....you can either send it to me, or just scroll down to the 0420 CEL and disable it. Mike may have had an outdated definition.
Old 05-10-2013, 09:36 PM   #420
BlueDiamondOfMiami
Member#: 263806
2015 WRX Limited
MIKE BOTTI coming to SOUTH FLORIDA follow this thread for more info. http://forums.nasioc.com/forums/show...1#post39782554
BlueDiamondOfMiami is offline   Reply With Quote
Old 08-18-2013, 10:58 PM   #421
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Any comments on what a "safe" peak timing setting would be on E85?
subydude is online now   Reply With Quote
Old 08-18-2013, 11:34 PM   #422
kakarot09
Member#: 182375
08 Sti
Wrbm
No. This will depend entirely on what area of the map you're referring to and the mods done to your car etc.
kakarot09 is offline   Reply With Quote
Old 08-24-2013, 08:37 PM   #423
duck13
Member#: 307274
2012 STI Spec C
Hi,
Do you have any experience with JDM spec C?
I need an e-tune, spec C is boosting 21 psi and agressive timing out of factory.
It feels good stock, however it needs RON100 to run (not US octane). Is it possible to make it run better on RON95 (91 US oct)?
Sounds like it needs a de-tune.
duck13 is offline   Reply With Quote
Old 08-24-2013, 08:48 PM   #424
Phatron
Member#: 36033
CEO PhatBottiTuning
Sent u a pm
Old 08-31-2013, 03:33 PM   #425
microsnook
Member#: 313952
2006 STi
SGM DOM 3xt-r
I'm getting tuned by Mike at the end of sept in jax but need a map to hold me over since Im getting new parts installed.
He said he would email me a map no problem once the work is done.
My only issues is not having the ROM software of cables to flash the map...
Any suggestions or locals who wouldnt mind flashing his map for me??
Thanks...
microsnook is offline   Reply With Quote
PhatBotti Tuning (merged thread) BoostinChick Vendor Reviews 108 04-24-2016 06:49 PM
PhatBotti Tuned - 205k Mile 02 WRX Wagon - 12.4 @ 111 benit0 Proven Power Bragging 14 11-04-2011 09:06 AM
Brake Fluid FAQ & Pedal Feel Info (the reference post) 8Complex Brakes, Steering & Suspension 37 06-06-2008 08:47 AM
PDX Tuning Dyno Day - Final Schedule & Payment Info - Standby folks read as well! Geoff Texas Impreza Club Forum -- TXIC 108 05-04-2006 07:26 PM
MWSOC/INR Event: July 7th Merrillville autoX - Full Event & Caravan Info 8Complex Mid West Subaru Owners Club Forum -- MWSOC 55 07-08-2001 11:08 PM
