Old 05-01-2013, 07:22 PM   #1
bryannako
Member#: 322016
2007 Impreza 2.5i
Gray
Default Borla Replicas
Quick question is this header uel? I have a 07 2.5i and like everyone else I'm trying to put uel s on my 2.5i together that boxer rumble.
Really appreciate the help
bryannako is offline   Reply With Quote
Old 05-01-2013, 07:24 PM   #2
bryannako
Member#: 322016
2007 Impreza 2.5i
Gray
Old 05-01-2013, 08:36 PM   #3
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
That is a borla or borla rep. It is UEL. And it will not fit your car without problems
Rudgers73 is offline   Reply With Quote
Old 05-01-2013, 08:51 PM   #4
smokeater30
Member#: 340939
2002 Swapped RS
Pure White
Agree with ^, I bought a borla rep for my Bugeye and had horrible issues with fitting it. The flange was clocked a degree or two and was almost an a half inch too narrow and wouldn't even mate up to the heads until I cut it and remeasured. The front tube which routes the exhaust from the passenger side head was not long enough to line the flanges up. Luckily I have a great shop here in town that was able to weld it on the cheap.
smokeater30 is offline   Reply With Quote
Old 05-01-2013, 09:02 PM   #5
Rudgers73
Member#: 141433
2006 Impreza 2.5i
Obsidian Black
Well, I didn't mean that it would be a crappy fit. I meant that it won't mate to your cat pipe because you drive an 06-07 and the 2.5 headers that are around (other than the Rallisport UEL) stopped fitting in 05.
You could swap out the cat section with one off of an older one but then you'll have Check engine lights bc the placement of the sensor and the second converter play more of a part on the 06-07 models.
Old 05-01-2013, 09:08 PM   #6
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Might need to stretch it and user a prybar a bit to get it in place, but I had one on my outback just like that that I quite liked. Enjoy! It is UEL and you will get the nice rumbly sound if that's what you are going for.
ResidentR is offline   Reply With Quote
Old 05-01-2013, 09:32 PM   #7
bryannako
Member#: 322016
2007 Impreza 2.5i
Gray
Thanks for all of the help, I really appreciate it!
Old 05-01-2013, 09:43 PM   #8
bryannako
Member#: 322016
2007 Impreza 2.5i
Gray
One more question, this could be a really dumb one but I'll just go for it.
So I'm thinking about using these borla replica headers, 05rs cat pipe and then could I use the 06-07 sti cat back with it? Or what cat back is recommended?
Old 05-02-2013, 09:29 AM   #9
ScoobyDrift
Member#: 315446
2004 Impreza 2.5L
With the Sti Cat back you will loose torque/low end power but will gain high end power, with the RS Cat pipe and resonator you should be fine.
ScoobyDrift is offline   Reply With Quote
Old 05-02-2013, 01:22 PM   #10
laxaholic
Member#: 338950
2006 Impreza 2.5i
I have an 06 2.5i 5spd. How could I give my little Subaru that boxer rumble??
laxaholic is offline   Reply With Quote
Old 05-02-2013, 01:33 PM   #11
PA-Outback2000
Member#: 161832
2000 Outback Limited
stromung from boxer4racing.com sounds great!
RS cat pipe meaning an older-style OEM cat or aftermarket?
PA-Outback2000 is offline   Reply With Quote
Old 05-02-2013, 02:17 PM   #12
RallyB
Member#: 294247
2007 Impreza
If u can wait 3 months the rallisportracing uel's are awesome
RallyB is offline   Reply With Quote
Old 05-02-2013, 03:28 PM   #13
smokeater30
Member#: 340939
2002 Swapped RS
Pure White
My apologies Rudgers73, I wasn't reading that in context. I also was not aware that they made that many changes to the exhaust system when the re styled the car.
Old 05-03-2013, 08:08 PM   #14
jamesonp16
Member#: 347149
2007 impreza 2.5
red
id go with the rallisport headers honestly, im getting them for my 07. i know some people dont want to wait like 2 months for them but in my opinion they are worth it. cost wise you will end up paying the about the same if you buy borla's and have them modified to fot the 06-07. if you buy the rallisport sports they are made to fit our cars, they have a built in high flow cat so you wont get CEL, you dont need to drill holes for your o2 sensors or worry about relocating them, best part is the rallisport headers are direct bolt on. no modification, you can install them yourself. borlas have the reputation to crack and have problems (from what hear) the customer service at rallisport is awesome, if there are any problems with the header or they have a defect they will pay for shipping on them and send you a new set. Honestly for our year car i think rallisport is the way to go!!! but obviously that choice is up to you
hope this helped! be sure to check the rallisport threads if you want some more info and customer feedback..... not to mention they sound amazing
jamesonp16 is offline   Reply With Quote
Old 05-03-2013, 10:56 PM   #15
klaus_b2
Member#: 318411
17 WRX
CWP
to complete your set up, youll need an 05 cat pipe like you said and a mid pipe + axle back...or catback exhaust, either or..
klaus_b2 is offline   Reply With Quote
Old 05-05-2013, 12:25 AM   #16
Bubakanush
Member#: 209975
2016 WRX
LBP
I think I'll be doing this as well. I think I'm finally going to pull the trigger and go ahead and buy the rallisport UEL headers. Hopefully I can have them on by the end of summer! And I'm most likely going to replace my catback as well. Currently have an 06 STI catback on my 06 2.5i but I really don't think it will bring out the most of the UEL's. Gonna try and get an n1 or something of that nature
Bubakanush is offline   Reply With Quote
Old 05-05-2013, 02:31 AM   #17
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
You wont be disappointed :P guaranteed.
