Old 04-24-2013, 09:20 AM   #26
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
As long as the damage isn't crazy you can swap hotsides no problem. There is an index pin so it's nearly impossible to clock them incorrectly.
p951951951t is offline   Reply With Quote
Old 04-26-2013, 01:38 PM   #27
lambose5
Member#: 339331
Video of scrapes on the inside of the hotside housing, and the beat up blades that did it.
Can I swap this hotside housing over to the new turbo and run it or are those scrapes to much?
Quick vid showing Downpipe & Uppipe mating surfaces; that's after cleaning, looks the same as before I cleaned it.'
Do I need anything else besides the metal gaskets for the dp and up? Do I need some "spray gasket sealant" or something like that orange/copper stuff?
And lastly, I guess theres no type of seal or gasket involved with the 'v-band' clamp? I just swap the housings and clamp, done? Hah. If I shouldn't use the old housing on the new 'ebay turbo' I'll be lookin for a used vf40 guys. If none in great condition are available ill have to get a bnr i guess?..?
Thanks.
lambose5 is offline   Reply With Quote
Old 04-27-2013, 10:04 AM   #28
lambose5
Member#: 339331
..Bump..
Old 04-28-2013, 07:33 PM   #29
lambose5
Member#: 339331
I guess this is another option., to fix the stock turbo using the stock housing in it's entirety..for ..cheAPEr?
http://www.ebay.ca/itm/RHF5H-VF40-Su...#ht_500wt_1413
Old 05-05-2013, 03:56 AM   #30
lambose5
Member#: 339331
I swapped the turbine housing of the old turbo onto the new turbo's CHRA/compressor housing and popped it in.
She started up fine. Fixed a small coolant leak and that was that..so far.
Oil and filter change tomorrow.. and .. probably at LEAST(!) once a week for a month
Thanks so much for everyones help and patience.
