Old 04-18-2013, 05:23 PM   #1
CRUZTAKER
Member#: 269757
2011 WRX 5-door
Default Bluetooth connection to Note-II skips
I perused all 96 threads and came up with nothing.
If it's discussed somewhere...someone please direct me.
I know I am not alone in frustration on this issue.
Much of time, more often than not, the music skips while my Samsung Note-II is streaming music from the Poweramp app to my stock WRX radio.
I'm losing my mind!
Sometimes I get it to clear, other times it doesn't work consistently until the next time I start the car.
I've tried ALL of the basic troubleshooting, ie reconnecting, rebooting, restarting the app....etc.
Each of the vendors with equipment and/or software involved in this equation of fail is pointing fingers at each other.
CRUZTAKER is offline   Reply With Quote
Old 04-18-2013, 09:04 PM   #2
04wrxsilverliquid
Member#: 271917
2002 wrx
Default bluetooth playback
More than likely you have too many apps running in the background I have had similar expierences with multiple phones and tablets and Bluetooth devices ..log completely out of Facebook for.instance and watch your playback.smooth out ..there're are a lot of background apps on devices these days..
04wrxsilverliquid is offline   Reply With Quote
Old 04-19-2013, 01:09 AM   #3
peekeesh
Member#: 316476
12 WRX
I read somewhere about it being a bug. I have a sprint note 2 as well and it happens even when listening using my headphones while screen is off.
peekeesh is offline   Reply With Quote
Old 04-19-2013, 04:16 PM   #4
CRUZTAKER
Member#: 269757
2011 WRX 5-door
I've tried most of the basic actions such as clearing cache, and killing tasks.
I just removed 'tune in radio' which is one of those apps that auto launch when blue tooth is turned on.
I noticed it gets really bad if someone else in the car has their blue tooth on, or if I am near another vehicle I suspect as having blue tooth.
I wish I could nail it down.
I have wondered if replacing a HU would help, but reading thru the audio forums, I am not seeing a lot of feedback related to using bluetooth from an android device to a new HU.
Old 04-19-2013, 04:27 PM   #5
Subarulvn
Member#: 342167
2011 STI
I'm losing my mind!
I have a 2011 sti and my head unit does exact same thing. I am using i phone 5, when it stars skiping i do a master reset on the phone and it goes back to normal. By master reset i mean (holding home and power button down until apple logo displays)
Subarulvn is offline   Reply With Quote
Old 04-21-2013, 09:16 PM   #6
2013SubieWRX
Member#: 349874
2013 WRX
Ok..so I have kinda the same problem...so when im streaming from my iphone 5 to my 13 wrx stock radio..if the phone is in my pocket and I rest my palm on my leg where my palm hits the top of the phone it will skip/cut out...this only happens while in my pocket..also this is has happened on three different iphone 5's...I even restored my phone and set it up as a new one instead of the cloud to rule out a software problem...no go...it even does it on other Bluetooth devices..I demonstrated it for the apple tech on a jawbone speaker....anyone else with this???
2013SubieWRX is offline   Reply With Quote
Old 04-22-2013, 11:55 AM   #7
foolycooly
Member#: 260545
2011 WRX Limited 4dr
happens on my iphone 5 as well. A reset fixes it. It seems to almost certainly be caused by lack of processing power/background apps.
foolycooly is offline   Reply With Quote
Old 04-22-2013, 12:28 PM   #8
2013SubieWRX
Member#: 349874
2013 WRX
That's possible....but when restored and set it up as a new phone...I only installed and only had running the app I'm streaming my music from which is rhapsody and it still did it...and it's not the app because it does it on others too....it has totally boggled my mind
Old 04-22-2013, 05:43 PM   #9
zer0n9ne
Member#: 321487
2012 Sport Ltd Wagon
Same phone, same issue here. FWIW my last phone, Samsung Galaxy Epic exhibited the same behavior. I flashed Cyanogenmod 9 onto it and everything worked fine from there on out. My Note II is stock, cuts out occasionally, and seems to connect/disconnect/connect a lot.
zer0n9ne is offline   Reply With Quote
Old 04-30-2013, 10:49 PM   #10
BadDog
Member#: 3725
2015 WRX / 1973 240Z
Triple Black
I have a GS3, and I think its the factory HU. I used to stream from Pandora, the Samsung music app, and the Google Play music app all the time in my Veloster and it never skipped like this once. With my new subie, it happens every 3rd or 4th drive of the day.... the skipping gets worse (more frequent) until it happens about every second, and then it completely clears up. It doesn't matter what app (I've switched, and the problem persists during a given bout), and toggling Bluetooth off and then back on again doesn't help either. I think the factory HU decoding cache is having an issue, or something along those lines. The music is not pausing at these skips at all (like you would expect if it was the phone). The Song continues playing, the tempo is not thrown off.
BadDog is offline   Reply With Quote
Old 04-30-2013, 11:54 PM   #11
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
I have an iPhone 5 and it used to skip on my stock head unit. I swapped to a 2011 forester radio a month ago, and has yet to skip.
Old 05-01-2013, 08:36 AM   #12
Angelus911
Member#: 89967
2012 Impreza Sport
This happens to me as well on a '12 Impreza. The only thing that cures it is turning off the car and turning it back on. Usually when it happens, its resolved the next time I start up
Old 05-01-2013, 08:53 AM   #13
BadDog
Member#: 3725
Triple Black
Yeah, I'm not about to reset my phone every other time I drive my car. I'd buy a new head unit first that has better Android integration (phone book, etc.) and Sirius :-)
Old 05-04-2013, 10:27 PM   #14
Chchappy
Member#: 355459
2013 Wrx premium
Wr blue
I have sprint and a s3. Doesn't skip, but sprint coverage sucks. Could be your problem
Chchappy is offline   Reply With Quote
Old 05-05-2013, 10:51 AM   #15
CRUZTAKER
Member#: 269757
2011 WRX 5-door
Originally Posted by BadDog View Post
....The music is not pausing at these skips at all (like you would expect if it was the phone). The Song continues playing, the tempo is not thrown off.
I have been able do duplicate this to some point. I have a blue tooth receiver in my barn and frequently stream music from my Note-II. If I move my phone beyond the BT receiver's range (20-25'), it will skip in the same fashion as the WRX. Not loosing a beat, just cutting in and out.
Makes me wonder if the BT receiver in the car just sucks in general.
I am still baffled why introducing another phone to the car's cabin while mine is connected BT makes that stream skip like crazy!
I am not so sure I will keep this car long enough to invest in a new HU just to solve this issue. As much as I hate cords, I may need to just plug in the old fashioned way to get phone music to HU.
Old 05-06-2013, 07:49 AM   #16
BadDog
Member#: 3725
Triple Black
Makes me wonder if the BT receiver in the car just sucks in general...
I think you hit the nail on the head.
Old 06-01-2013, 11:19 AM   #17
locozildjiangodx
Member#: 355323
2013 WRX Limited HB
WR Blue
Sorry to bring this back up, but if you are rooted and running cyanogenmod or any other 4.2 rom it could be because the bluetooth driver for these roms are not stock and not AVRCP 1.3 yet. This would also be why you wouldnt see song information on your HU. If that's not the case...then I don't know. lol
locozildjiangodx is offline   Reply With Quote
