Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 04-29-2013, 10:14 PM   #1
HelloMrBrahms
Member#: 320094
07 sti
UGM
Default holy knock batman - 07 sti
I've run datalogs many times before and everything looked very much fine, knock was -1 or -1.5 MAX and only for 100 rpm or so ... so fast forward a few months, I got my 60k service at forman performance in orange county [for those of you who know].
I also got my spark plugs replaced with the 60k. he asked if I wanted the standard plus or 1 step colder plugs. I told him standard would be fine, but he recommended 1 step colder ... I questioned it since I only have stage 2 - [cobb sf intake, tomei ti exhaust and accessport on the base stage 2 91 ACN map].
after the service, everything seem like it ran great ... until very recently, my car seems like it sputters around 5-6k rpms when I'm on it hard ... it felt wrong, so I did a datalog and holy ****, the knock is crazy ...
anyone have suggestions ??
pic:
http://img855.imageshack.us/img855/3249/knockj.png
HelloMrBrahms is offline   Reply With Quote
Old 04-30-2013, 12:38 AM   #2
ProfessWRX
Member#: 323379
2014 Diesel Cruze
Yamaha R6
pic:
Personally I'd check your plugs. If they look ok I'd reset the pcm and do a very short run in that rpm range. Then shut the car down asap. You can see if the car is actually knocking by reading the plugs immediately after.
If it's false knock sometimes you can get it to knock in idle. But reading the plugs is important. That kind of kr will decimate your engine. But usually that kind of knock is one of two things. An already blown motor or false knock.
Not sure what the max retard is in your tune but that's close.
Just be careful whatever you do.
ProfessWRX is offline   Reply With Quote
Old 05-01-2013, 06:01 PM   #3
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
Turn on per cylinder misfire and the stuff you had in the picture and drive around. I've seen people break the clips on the coil packs causing it to misfire... Also might have cracked a plug.. Easy enough to do... Then take a picture.. If it's one cylinder at least you know where to start looking.
Bamofo is offline   Reply With Quote
Old 05-05-2013, 08:33 PM   #4
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
True, When the coil clips break, they can make the car misfire intermittently due to the poor connection.
