Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 11-16-2012, 08:51 PM   #201
09rex101
Member#: 329540
2010 wrx
Awesome write up!
09rex101 is offline   Reply With Quote
Old 12-13-2012, 03:58 AM   #202
jt11b1981
Member#: 272430
Originally Posted by boostjuice View Post
So I have been searching and reading and I haven't found anything about using a lightweight flywheel (specifically ACT Streetlite) on an 06 STi. I have a Clutch Masters FX 300 that is going in and I have heard both sides about using the flywheel, any insight or experience would be very helpful.
I have heard that the RPMs fall fast which causes rough idle.
I have a 06 WRX and just installed an F1 Racing, 13.7 lbs flywheel and a Clutch Masters FX200 today. The RPMs don't fall that fast, maybe just a slight hesitation of letting off the gas while shifting, but nothing that a week or two of driving won’t get you used to. I was also surprised to see no change at idle. The needle is as steady as it ever was. The car definitely pulls quicker and you barely have to touch the gas to keep it at 80 on the highway. I was surprised that the FX200 felt really light and gummy compared to the stocker being that it’s a Stage 2 clutch. It feels all right though and grips like a b*stard too I did upgrade my clutch line to steel braided so that could have something to do with the feel also.
The flywheel didn't throw any codes but it did misfire and stall today while casually driving down a residential street. After a rough re start and some bucking as I was getting going I was surprised to see absolutely no code at all? I have an appt to get a tune on Monday so hopefully it was just a learning process for the car and won't happen again. It drove fine after that.
I know you were looking for a STi but this is what I got. I know mine hits boost and spools even faster now than it did before, launch is significantly "touchier" but by no means have to rev to 1000s of rpms just to get it going, and you'll get put back in the seat noticeably further ha-ha. One last thing is it does feel like the top speed may have gotten decreased but I won't try that till after the tune. I can't comment on top end because I haven't taken it over 3500 yet. Hope this helps a little.
jt11b1981 is offline   Reply With Quote
Old 01-19-2013, 02:25 AM   #203
11StiGiarla
Member#: 343691
Extrrmy descriptive. Good post!!
11StiGiarla is offline   Reply With Quote
Old 01-20-2013, 09:32 PM   #204
ryanthomas6
Member#: 344259
This post saved me a bit of money. Maybe I won't re-up for a lighter flywheel.
ryanthomas6 is offline   Reply With Quote
Old 01-30-2013, 04:10 AM   #205
t6nis1234
Member#: 316906
2001 Impreza WRX 2.0
I read through the whole thread, but still didn't get a answer for my question, other than yes or no.
I have Exedy Stage 2 clutch kit with 3 puck clutch. Since the clutch is pain in the ass to drive, I would like to change it out for ACT HDMM clutch disk.
Im putting down 300 ft lb at the moment, but I want it to be good for 380 with futher upgrades.
Or would the change be pointless, because ACT HDMM or similar disk will chatter as much as my Exedy at the moment?
Good thread btw
t6nis1234 is offline   Reply With Quote
Old 02-05-2013, 08:11 PM   #206
Reaper13
Member#: 346053
2005 Legacy 2.5i lim
Default Clutch and flywheel replacement
Im still new to subaru's ive had my legacy for bout a year. im trying to figure out if I can put the 2.5gt flywheel and clutch into a 2.5i limited. ive heard alot of the subaru parts are interchangeable, but i want to make sure before making a mistake. (same with suspension parts)
Reaper13 is offline   Reply With Quote
Old 03-13-2013, 06:48 PM   #207
Djimpreza02
Member#: 328135
2004 impreza WRX
Question: When replacing the flywheel, is it a good precaution to replace all 8 flywheel bolts too, along with pressure plate cover bolts?
Stock flywheel, and stage 1 Exedy race clutch kit.
Djimpreza02 is offline   Reply With Quote
Old 03-13-2013, 09:40 PM   #208
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
The software wont let me type no all by itself, so no. If you like to put the lotion in the basket, you can replace all the hardware and we won't know or care. Some people have OCD on hardware....I won't make fun of you for it....much.
Old 03-29-2013, 08:44 PM   #209
Dom_wrx3
Member#: 342955
2004 WRX
Hey guys, so here's what happened .. A 'friend' of mine, asked to drive my car. He's normally pretty co, so I let him. I do NOT launch my car, keep in mind. He revved it up to around 5500 RPM, and just dumps the clutch. It was in gravel. My car is a stage 3 Wrx. Stock clutch, stock tranny. About 85k on the original clutch. My clutch has been grabbing extra high lately, but doesn't slip at all. And because it's a hydraulic clutch, I can't adjust it. I was looking to replace my clutch this week. I was thinking somewhere along the lines of a stage 3 clutch, just to avoid clutch problems as much as possible in the future. Car makes around 282 horse now. I don't plan on launching, or EVER dumping the clutch. Just need something more durable for a daily driven clutch. Think it's a bad idea to go straight to stage 3? And should I do the pressure plate too? Any help would be awesome. Like I said, clutch is grabbing extra high lately.
Dom_wrx3 is offline   Reply With Quote
Old 03-30-2013, 07:46 AM   #210
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
You replace a clutch when it slips.
ride5000 is online now   Reply With Quote
Old 03-30-2013, 08:14 AM   #211
New2Sube
Member#: 124195
98 LegacyGT XTswap
Green
I thought the rule of thumb was "stock tranny, stock clutch". Isn't that to prevent breaking the tranny?
New2Sube is online now   Reply With Quote
Old 03-30-2013, 11:21 AM   #212
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
it's one way to prevent breaking the tranny.
good condition oem clutch is good for at least 350ftlbs.
Old 03-31-2013, 01:22 AM   #213
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Not sure what a stage 3 clutch is, but I would recommend any "full" face clutch. No puck kind of clutch is needed. I'm putting 280 tq to the ground and use ACT HDSS clutch. I daily drive it along with , stage rally, and rally crosses. O and this is my 3rd clutch ever in the car, 2nd ACT. Bought car in 01 and have 180 ish K on the clock!!!!!
recce02 is offline   Reply With Quote
Old 03-31-2013, 02:00 PM   #214
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Who told you a hydraulic clutch is not adjustable? The adjustment is in the pedal...the pedal stop/switch can be moved
aboothman is offline   Reply With Quote
Old 03-31-2013, 02:13 PM   #215
New2Sube
Member#: 124195
98 LegacyGT XTswap
Green
There's also the thread portion of the rod to the master cylinder.
Old 04-26-2013, 12:48 AM   #216
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
subscribed... Thank you!
punchjamesarnol is offline   Reply With Quote
Old 05-01-2013, 10:43 PM   #217
SWRocket
Member#: 338985
2004 WRX SW V8TT
Great post!
I have a hybrid EJ257 (s20 heads) with about 470lb.ft of torque
I will use the car in Time Attack and on the Streets...
What clutch you reccommend?
Best regards
SWRocket is offline   Reply With Quote
Old 05-03-2013, 12:59 PM   #218
snotrocket555
Member#: 312311
very great information unibomber, and on a side note from one service member to a retired one thanks for your service/sacrifice.
snotrocket555 is offline   Reply With Quote
Old 05-06-2013, 12:36 PM   #219
whitetyger23
Member#: 115472
2005 Impreza WRX
white
Default flywheel
quick question .....does changing to a lighter flywheel effect power steering? I just changed mine to a lighter wheel and I have mostly lost my power steering
whitetyger23 is offline   Reply With Quote
Old 05-06-2013, 01:00 PM   #220
New2Sube
Member#: 124195
98 LegacyGT XTswap
Green
You probably have air in the line. Jack up the car and turn the wheels lock to lock to get the air out.
Old 05-06-2013, 03:53 PM   #221
whitetyger23
Member#: 115472
2005 Impreza WRX
white
thought of that already and topped off the fluid
Old 05-06-2013, 04:30 PM   #222
New2Sube
Member#: 124195
98 LegacyGT XTswap
Green
Hmmmm, I didn't say anything before but after i changed my clutch and added a lightened flywheel my pump started whining. I even changed my pump but could never get it to stop. I assumed it was just getting air in somewhere else, I read that the factory clamps on these cars let air in.
Old 05-09-2013, 08:54 PM   #223
Tommyp
Member#: 277475
Is shudder nessesarily a 'bad' thing, meaning that the clutch needs to be replaced? Or can shudder be a normal discomfort? Or do I just need to rev it higher when getting off from 1st. I'm on An Exedy Stage 1 Organic and an ACT lightweight flywheel
Tommyp is offline   Reply With Quote
Old 05-15-2013, 10:26 PM   #224
Wlkonh2o
Member#: 275011
2007 Impreza WRX
Urban Grey
Same setup here and when I finished the install there was shudder for a few weeks and it simmered down a bit but everynow and then it would shudder.
Wlkonh2o is offline   Reply With Quote
Old 05-15-2013, 10:31 PM   #225
Wlkonh2o
Member#: 275011
2007 Impreza WRX
Urban Grey
Everyone says replace or resurface the fly when changing the clutch. I understand its a good rule of thumb but I've got about 8k on my clutch and my pressure plate defected. Can't find the plate itself so I bought a whole new clutch kit.
Should I still resurface or replace?
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 08:49 AM
Piston FAQ: Read if you are thinking about buying them! Unabomber Built Motor Discussion 82 06-26-2015 02:51 PM
Intercooler Hose FAQ: Read if you are thinking of buying them! Unabomber Newbies & FAQs 42 04-05-2014 11:18 PM
Spring/Strut/Coilover FAQ: Read if you are thinking of buying them! Unabomber Brakes, Steering & Suspension 39 04-19-2013 06:30 AM
