Vancouver Impreza Club
Old 03-05-2013, 04:21 AM   #1251
Ctogo
Member#: 338399
2002 Impreza WRX
Default Morettes
Got my Morette replicas in the mail today!I decided to dip the center portion of the lights! Can't wait to mount these!
Hopefully I'll figure out how to retrofit some projectors into these.
Ctogo is offline   Reply With Quote
Old 03-05-2013, 07:52 AM   #1252
dirtbikeridr12
Member#: 209896
03 2.35L bugeye
holset he351ve @23psi
Replicas? Nice, if ya don't mind me asking what'd u pay? I've had my real ones for about 3 years n I don't think anyone was doing that at the time(that I noticed). They are a little different but I kinda like them like that. Its more like it has the stock pieces that go between the headlight n grill
dirtbikeridr12 is offline   Reply With Quote
Old 03-05-2013, 10:32 AM   #1253
rs420
the cone killer
Member#: 157784
02 swapped bugeye
anthricite
I like them with the black inside - looks great
rs420 is offline   Reply With Quote
Old 03-05-2013, 12:27 PM   #1254
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Everytime I see morettes now I think Chevy Sonic.. anyone else? Anticipating the end result!
brett192 is offline   Reply With Quote
Old 03-05-2013, 02:35 PM   #1255
Cranker625
Member#: 327676
2002 Stg 2 WRX Sedan
PSM "sold"
^ Ditto
Cranker625 is offline   Reply With Quote
Old 03-05-2013, 03:29 PM   #1256
Ctogo
Member#: 338399
2002 Impreza WRX
Got them for 300 shipped from another nasioc member.
Old 03-08-2013, 05:23 AM   #1257
bee4bee4
Member#: 349474
I like your mods.
bee4bee4 is offline   Reply With Quote
Old 03-08-2013, 01:53 PM   #1258
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
You like who's mods?
Old 03-11-2013, 05:24 PM   #1259
R.Reyes
Member#: 323823
01 Gc6
Black Diamond Pearl
installed my fog lights cover, rally tech tilt plate and sti blue door inserts
R.Reyes is offline   Reply With Quote
Old 03-11-2013, 05:43 PM   #1260
easterbran
Member#: 307359
'05 STi Stage II
Who is Mods?
Old 03-11-2013, 06:53 PM   #1261
Cranker625
Member#: 327676
PSM "sold"
Wow, that is some seriously nice interior
Old 03-12-2013, 12:05 AM   #1262
LilDragon
Member#: 203913
1999 2.5 RS Sold :(
WRBlue & Rally Tattoo
Where did you get those door inserts man? Looking sick!
LilDragon is offline   Reply With Quote
Old 03-12-2013, 03:29 AM   #1263
R.Reyes
Member#: 323823
01 Gc6
Black Diamond Pearl
thanks man!
www.z-interiors.com, thank you!
Old 03-18-2013, 11:48 PM   #1264
Ctogo
Member#: 338399
2002 Impreza WRX
Default extended armrest
I got an armrest extension!!!
Old 03-19-2013, 08:49 PM   #1265
ShiftGear
Member#: 130493
1999 v5 STi
Dem crumbz
Mmmmmmmmmmm
ShiftGear is offline   Reply With Quote
Old 04-30-2013, 03:55 AM   #1266
wrxposer
Member#: 188219
2007 2.5i Ltd.
Finally did my HID retrofit today. STi projectors (thanks minifreak), TSX-R clear lenses, Matsushiita ballasts, Phillips bulbs, TRS relay/harness.
Super easy swap and very happy with the results. All in for just over $250.
Used this thread
Stock H7 halogen projectors
STi HID w/TSX-R clear lenses (not sure why the cutoff seems to curve in the pic, it's actually nice and flat all the way across, maybe the angle. The passenger side seems to be aimed a little high, thought I had it aimed correctly but will tweak it tomorrow.
wrxposer is offline   Reply With Quote
Old 04-30-2013, 08:21 PM   #1267
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Looks good
minifreak is offline   Reply With Quote
Old 04-30-2013, 10:07 PM   #1268
thesniperz
Member#: 235744
2000 Forester STi
White - JDM yo!
my next project.
thesniperz is offline   Reply With Quote
Old 04-30-2013, 11:45 PM   #1269
wrxposer
Member#: 188219
2007 2.5i Ltd.
It's definitely way better than stock. The pics actually make my stock lights look better than they are, the white balance makes them look brighter and less yellow. The nice purple flicker at the top of my cutoff with the HIDs doesn't show up in the pics either.
Sniperz just a heads up, for our cars I had to buy the relay harness from TRS because I was blowing the headlight fuse but apparently 08+ is plug and play. I also bypassed the DRL resistor, not sure if I needed to with the relay harness but I had already done it before I figured out I needed the wiring harness.
Old 05-01-2013, 10:37 AM   #1270
thesniperz
Member#: 235744
2000 Forester STi
White - JDM yo!
Nice! Did you open the headlight yourself?
Old 05-01-2013, 06:17 PM   #1271
wrxposer
Member#: 188219
2007 2.5i Ltd.
yeah it's easy, I've done it a couple of times. Getting the lights in and out of the car is the biggest PITA of the entire projecect. Just go slow and use this thread I leave mine in the oven for 20-30 mins. They come apart easy but be careful not to get any of the sealant on your reflector or headlight lens, it can get stringy like melted mozzarella cheese when it's warm. You don't need to remove all of the bulbs and wiring. I only remove my hi/lo beam bulbs and leave everything else in.
If you paint your inner housings use very thin coats and give ample time for the paint to dry, the fumes can mess up your headlight lens. I f'd up one of my lenses and had to spend a lot of time polishing it to fix it.
If I paint them again, I would maybe heat the painted portion of the housing by itself in the oven for 20 mins before reassembling it.
Put the lights loosely back together and heat again in the oven then push everything tightly back together while it's still hot and reinstall the 5 screws. I've never had any moisture issues.
I didn't paint the orange reflector because I want my lights legal and safe. If you paint it, you lose your corner lighting and IMO you should add the jdm side markers like semaj did.
I hooked up the wiring harness ahead of time and tested and tuned the HID projectors (adding washers) so that everything was ready since my car is my DD and I couldn't run to the store once my lights were out of the car.
EDIT: Oh yeah be very careful if you clean the inside of the lens. It has an antiglare/antifog coating on it that hates windex and other cleaners. use a damp cloth only.
Old 05-06-2013, 08:49 PM   #1272
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
It is days like these that I truly appreciate the OEM leather shift knob. I guess the aluminum nub will forever stay in the storage bin now
Old 05-26-2013, 12:15 AM   #1273
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Mitsubishi EVO 9 MR BBS, 17x8 +38 with 235/45/17 tires.
Powder coated Kawasaki Green.
Old 05-26-2013, 11:02 PM   #1274
wrx.
Member#: 258781
2002 Subaru WRX
wrx. is offline   Reply With Quote
Old 06-23-2013, 03:39 PM   #1275
mixdnuts
Member#: 147357
1997 JDM Fozzie S/Tb
Forester Getting Horned Up
Put some Supertones in the new Fozzie yesterday as the stock one are just to wimpy. Also swapped the JDM headlights and corners back in. The worst part is now I need to go to the dealer and get a bunch of grill and trim clips. I can't seem to ever pull the grill off without snapping a few.
https://picasaweb.google.com/lh/phot...eat=directlink
(I hate posting pics on here they rarely work)
mixdnuts is offline   Reply With Quote
Mod of the day: Engine/driveline/power steve Vancouver Impreza Club Forum -- VIC 873 04-12-2016 01:00 AM
Mod of the day: Suspension/Brakes/Wheels&Tires steve Vancouver Impreza Club Forum -- VIC 999 04-10-2016 02:00 PM
Crackhead mod of the day: Loomin Vancouver Impreza Club Forum -- VIC 45 12-17-2011 03:51 PM
Mod of the day: Home Improvement Loomin Vancouver Impreza Club Forum -- VIC 276 11-06-2010 03:53 PM
E85 Boondoggle of the Day: U.S. taxpayers subsidize ethanol to the tune of 51 cents AVANTI R5 Non-Subaru News & Rumors 24 06-05-2008 11:53 AM
