Old 05-02-2013, 01:27 PM   #1
PFSquirrel
Member#: 355165
2015 WRX
Question Whirring noise from trans
2002 WRX EJ20
152k miles
5-speed
So there's a whirring noise coming from the transmission. I've been trying to figure this out for a while now before dumping money into a mechanic to tell me it's super expensive to fix. It's not the clutch, brakes, bearings, or anything like that. The sound starts near 30mph or so, and gets progressively louder and a little higher pitched. Clip below:
https://www.dropbox.com/s/86b617jja3...ns%20whine.m4a
If anyone has any ideas what the hell this could be, I'd love to hear any answer. I'm hopefully going to change the gear oil this weekend, and if I'm lucky maybe that's all it is. If not, then I'm completely lost, as I've never heard this before.
PFSquirrel is offline   Reply With Quote
Old 05-02-2013, 01:44 PM   #2
MRGierut013
Member#: 328260
2005 STi, 2004 RSX
i-Vtec just kicked in yo!
Originally Posted by PFSquirrel View Post
2002 WRX EJ20
152k miles
5-speed
Does it happen in multiple gears? I can't really tell from the clip.
MRGierut013 is offline   Reply With Quote
Old 05-02-2013, 02:00 PM   #3
PFSquirrel
Member#: 355165
2015 WRX
Yep, all across the range. The noise gets prominent about 20 seconds in.
Old 05-02-2013, 05:55 PM   #4
Tjlarsen
Member#: 354924
I think I'm having the same problem. Does your noise occur even while you're coasting in neutral above 30 mph? I think mine is either my transmission or my differential. Both fluids need to be changed in mine. But it could be an indication that something's on its way out unfortunately.
Tjlarsen is offline   Reply With Quote
Old 05-03-2013, 07:38 AM   #5
PFSquirrel
Member#: 355165
2015 WRX
Yep it's with or without the clutch engaged
Old 05-03-2013, 10:02 AM   #6
mneste8718
Member#: 51562
2004 WRX Sedan PSM
EJ205 [email protected] 300whp
Could perhaps be a wheel bearing or maybe a cv axle on its way out if the clutch engagement doesn't matter.
mneste8718 is offline   Reply With Quote
Old 05-03-2013, 12:36 PM   #7
PFSquirrel
Member#: 355165
2015 WRX
Nope, already ruled that out.
Old 05-03-2013, 01:16 PM   #8
CNY_Dave
Member#: 354655
If it doesn't vary with gear then at least that narrows it down to the output stage.
Bad diffs almost always are quiet when the load is removed, ditto carrier bearings and trans bearings.
I can't get to the link (blocked at work), but sube wheel bearings can get VERY loud without detectable symptoms on inspection, even with the wheels spun by the engine. Best bet is to spin 'em in the air and use a mechanics stethoscope.
CNY_Dave is offline   Reply With Quote
Old 05-03-2013, 02:56 PM   #9
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
The video is kind of hard to hear so correct if I'm wrong... it sounds like the noise is present while accel/decel/coasting. If it happened only when in gear, I'd definitely say it's a bearing. Are you 100% sure that the axles and wheel bearings are good?
Old 05-06-2013, 12:49 PM   #10
PFSquirrel
Member#: 355165
2015 WRX
UPDATE: Changed gearbox oil, noise is a little less prominent. Going to change the rear diff oil today if the weather holds.
@wrex Not 100% sure, more like 99% sure. And yes it's present at all times.
Old 05-06-2013, 03:46 PM   #11
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
Well from the way you describe it, it seems that this whirring sound is wheel speed dependant, whether or not the clutch is engaged. I wonder if it's something silly like a caliper lightly rubbing against a rotor...
Old 05-07-2013, 07:41 AM   #12
PFSquirrel
Member#: 355165
2015 WRX
I thought that too at first, but I've already taken it all apart and put it back together.
Old 05-07-2013, 08:31 AM   #13
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
I wonder if it's your center diff... does it sound like this?
Old 05-08-2013, 08:11 AM   #14
PFSquirrel
Member#: 355165
2015 WRX
I think you might have nailed it. That's pretty spot on. Wonder how much that is to fix...
Old 05-08-2013, 08:56 AM   #15
Mr Wrex
Member#: 332887
2012 WRX stage 2+
DGM (sedan)
It depends... it could be the bearing or the diff itself. The good news is that you can easily replace either one with the transmission on the car. Probably $100-250 in parts and it could take anywhere from 1-2 hours if done by a subie pro.
Old 05-08-2013, 01:01 PM   #16
97ej22e
Member#: 327710
1999 Impreza OBS
Green
My car does this exact same thing and it's the differential's in my transmission... however mine also binds around corners at slow speeds if I get the transmission hot enough (like taking it on the highway).
97ej22e is offline   Reply With Quote
Old 07-01-2013, 08:50 PM   #17
Gmcwhirt
Member#: 361135
PFSquirrel, Did you figure out this problem yet? Our 2002 Impreza also makes a whirring noise that increases with speed whether in gear or in neutral coasting.
Gmcwhirt is offline   Reply With Quote
Old 07-02-2013, 10:35 AM   #18
PFSquirrel
Member#: 355165
2015 WRX
I actually should have a solid answer in a few days.
Old 07-02-2013, 11:22 AM   #19
sconniescoob
Member#: 161488
2002 '14 CRV
Sounds very similar to the noise my trans made before it died. Got progressively louder over time and then got really loud a few days before it let go (accompanied by some other clacking noises). Shop is still working on the teardown, but in the least my output shaft and transfer gears have gone - see my recent thread here for pics of the carnage. No official diagnosis yet as to why, but I'll be interested to compare notes when all is said and done.
sconniescoob is offline   Reply With Quote
Old 07-03-2013, 12:16 AM   #20
Hellchaser
Member#: 278263
I had a nasty sound too & I replaced the transfer case bearings & the bad bearing sound went away. I used opposedforces.com to find part numbers & I used subarupartswebsite.com to order the parts. It took about 2 days for delivery & I installed them myself.
Hellchaser is offline   Reply With Quote
Old 07-03-2013, 12:29 AM   #21
New-to-the-Old
Member#: 239385
2015 Wrx
Cwp
Yeah I have this same problem with my 06 sti. When I start in 1st gear and have the wheel turned it chirps the wheels and it sounds like its caused by a bad viscous coupling. I have the whining too and my mechanic said it was the center diff bearings if it happens under load.
So I don't know if the bearings made the coupling go bad, but if its broke you should definetly fix it before something else goes wrong.
New-to-the-Old is offline   Reply With Quote
