Notices
Old 05-07-2013, 10:39 AM   #1
jacky599r
Member#: 137631
2006 WRX
Red
Default got lazy and need a small help
I'm in the midst of swapping a 04 JDM STI 6 speeder into my 06 WRX. I intend to keep my 5 x 100 PCD setup and stock 4/2 brakes but i understand that the rear hubs of 04 STI will not fit. May i ask what are my cheapest option but still able to retain my brakes?
jacky599r is offline   Reply With Quote
Old 05-07-2013, 10:46 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
A 3.900 R160, auto propeller shaft.
You should read the stickies above. Since i gave you the answer, Paypal me some money.
FuJi K is online now   Reply With Quote
Old 05-07-2013, 10:47 AM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Spec B axles or that dude who was doing the custom setup.
Old 05-08-2013, 10:08 AM   #4
jacky599r
Member#: 137631
2006 WRX
Red
I want to keep the change minimal, i used to have a set of brembos that would work right up. Currently, i am looking at the simplest way to change or swap out so i could use the brakes.
:FuJi K: Your suggesting keeping my rear diff and swap a auto prop shaft from which car again? Would that be the most cost efficient?
@TIC: I remembered H6 rears could work but not too sure. And it is difficult to find Spec B parts in this part of the work...
