Welcome to the North American Subaru Impreza Owners Club Saturday July 4, 2015
Old 04-21-2013, 12:20 PM   #501
ImaginaryRex
Member#: 353838
2013 WRX
Originally Posted by themaus View Post
Does anyone remember what size T connector they used when they installed the gauge? I replaced mine when I originally installed it because the one that came with the Defi was too small for the line that goes to the top of the BPV
I'll second this. Doing the install this week
ImaginaryRex is online now   Reply With Quote
Old 04-25-2013, 11:42 PM   #502
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
In for an answer on the BPV T. I need a new one and can't find a cheapo replacement.
JSchell1309 is offline   Reply With Quote
Old 04-26-2013, 12:16 AM   #503
tilegend
Member#: 295565
1/4" x 1/4" x 1/8" (or 3/16" also works)
tilegend is offline   Reply With Quote
Old 04-26-2013, 07:29 AM   #504
punkNdrublic04
Member#: 273621
2013 WRX Limited
SWP Hatch
This. I did mine this week and ended up having to get a universal t fitting from Napa that you cut to the size you need. But when I measured the hose sizes it was 1/4" X 1/4" X 1/8" like tiledend said.
punkNdrublic04 is offline   Reply With Quote
Old 04-28-2013, 11:24 PM   #505
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
Thanks, I found a 1/4" x 1/4" x 3/16" that works for now with some zip ties.
I need to find a good 1/4" X 1/4" X 1/8" for peace of mind. I went to 2 different auto stores here and they only have Vacu-Seal brand and none of the assortments have this size.
Good news is I ended up getting everything installed. Now running Defi oil pressure and Defi boost gauge in the SMY Cluster. I love it. One small thing I noticed. I think I have an old boost gauge as the back light is a little more orange than the pressure gauge's more red light. They look just slightly off of eachother. Can only tell in person, I tried to get a picture of it but it doesn't show.
Old 05-04-2013, 11:55 AM   #506
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
I used the T that came with the gauge. I just used zip ties on them and haven't had an issue
gsrcrxsi is offline   Reply With Quote
Old 05-04-2013, 11:30 PM   #507
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
Originally Posted by bigusnickus View Post
The username fits this thread haha. Amazing look and work man. I need to pull the trigger on this exact same setup.
I don't quite understand what O.C.D. is, but it seems to be fashionable to accuse someone of having it when they do something properly...
viper_crazy is offline   Reply With Quote
Old 05-04-2013, 11:56 PM   #508
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
OCD is the abbreviation for obsessive compulsive disorder.
https://www.google.com/search?q=obse...fari#itp=open0
Some people with the disorder like to have a certain order to things. Everything has to be neat and it has a place. This is why people say someone has OCD when they do something organized and clean.
Old 05-05-2013, 12:04 AM   #509
viper_crazy
Member#: 298403
2008 WRX Premium
Spark Silver
I have heard of O.C.D. before. It was a quote I heard from someone. I don't know who said it, but I always chuckle when people say someone is O.C.D. and all that person did was just do a neat and tidy job, especially when it comes to wiring. Being neat and tidy makes your life a whole lot simpler down the road if you ever had to take things apart again. I admire a person who does a clean install job. Having worked on running new wiring on others cars, I'd make sure the job was done properly, even labelling aftermarket wiring jobs for any future technicians so they could easily identify what it was for and not waste time tracing wires.
Old 05-05-2013, 01:37 AM   #510
JSchell1309
Member#: 321321
'11 STI Hatchback
Dom 1.5XTR, E85
Haha sorry about that. Went right over my head. Sounds like something Zach Galifianakis would say.
Old 05-05-2013, 04:06 AM   #511
peekeesh
Member#: 316476
12 WRX
Originally Posted by Jay C View Post
On mine it seems like the top 2 clips aren't fully clipping in no matter how hard I push it, is yours the same?
hey buddy, finally got the chance to look into the issue. i got it fixed by adding felt tape on all clips. it's tight fight and no wobbles now.
peekeesh is offline   Reply With Quote
Old 05-05-2013, 08:06 PM   #512
Jay C
Member#: 318234
2012 WRX
Interesting, I'll have to give it a shot, thanks for the update
Jay C is offline   Reply With Quote
Old 05-08-2013, 12:44 AM   #513
11wrx_dude
Member#: 311747
2011 wrx
white
Just installed the defi boost gauge and turned the key and got nothen! Any ideas why ? I have no idea why it dosnt work, I used the same fuses that op used.
11wrx_dude is offline   Reply With Quote
Old 05-08-2013, 01:24 AM   #514
scx89
Member#: 269388
2011 Impreza WRX
obp
Did you properly ground it? Black wire to metal ?
scx89 is offline   Reply With Quote
Old 05-08-2013, 02:57 AM   #515
peekeesh
Member#: 316476
12 WRX
Check all wires make sure there's none loose. Check the fuses too maybe one of them is broken
Old 05-08-2013, 08:12 AM   #516
nmlittlebigman
Member#: 321409
2015 WRX LTD
Each fuse tap (add-a circuit) requires two fuses in it. The one directly over the slot uses the original fuse and the one offset uses the fuse for the device. Just checking to make sure.
Old 05-08-2013, 10:58 AM   #517
Ampliified
Member#: 328243
2012 Impreza WRX
Awesome Definitely reading through this again when I do mine!
Ampliified is offline   Reply With Quote
Old 05-08-2013, 11:29 AM   #518
Raidenking
Member#: 350606
2012 WRX
I see a lot of oil pressure setups, is there a large pro for this versus the oil temp gauge? Which would be the best in general?
Raidenking is offline   Reply With Quote
Old 05-08-2013, 11:39 AM   #519
scx89
Member#: 269388
2011 Impreza WRX
obp
Oil pressure can show oil loss. So if you have a leak, itll tell you. Itll also tell you when oil has warmed up because the pressure will drop
Old 05-08-2013, 03:23 PM   #520
11wrx_dude
Member#: 311747
2011 wrx
white
Yeup! That would be my problem thank you !
Old 05-08-2013, 08:43 PM   #521
mikeluis92wrx
Member#: 348447
2013 Impreza WRX
Default price
what is best you would do on price?
mikeluis92wrx is offline   Reply With Quote
Old 05-08-2013, 09:12 PM   #522
nmlittlebigman
Member#: 321409
2015 WRX LTD
delete
Old 05-14-2013, 11:20 AM   #523
fiatlux
Member#: 340639
2013 WRX STi Sedan
WR Blue Pearl
Would it be safe to run a T fitting on the front gallery to run both a pressure and a temp sensor off of? Something like http://www.glowshiftdirect.com/1-8-n...g-adapter.aspx or http://www.summitracing.com/parts/no...5nos/overview/
fiatlux is offline   Reply With Quote
Old 05-18-2013, 11:09 AM   #524
stierzy34
Member#: 92113
2013 Mini Cooper S
"Martha"
I have the SMY cluster and boost gauge ready but the oil pressure gauge was on back order..... the wait is killing me! However, this does give me time to work on the alcantara make-over
stierzy34 is offline   Reply With Quote
Old 05-22-2013, 02:54 PM   #525
My27KGame
Member#: 294927
2011 STi
How did you guys get the wires from the engine bay to inside the fender well?
My27KGame is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
