Old 04-19-2013, 11:54 PM   #1
ccbremech
Member#: 286915
2004 STI
BLUE
Default Closed loop fuel target dropping to 13.xx AFR
Hey guys, my AFRs keep dropping to the 13's at cruise. I did some data logging and realized that my closed loop fueling target will randomly drop down to the 13's, sometimes even at idol. When it does drop, my AFR correction goes crazy and shoots up very high. Any idea why this is doing this? has any body else had this issue? Any idea how to fix it?
ccbremech is offline   Reply With Quote
Old 04-20-2013, 12:09 AM   #2
the suicidal eggroll
Member#: 51961
2005 STi
On the 16-bit ECUs the rear O2 does nothing but check cat efficiency, on the 32-bit ECUs it also adjusts the CL fueling target. A bad rear O2 can drop the CL target to ~13.5 on the 32-bit ECUs, a pretty common problem when people remove the rear O2.
Old 04-20-2013, 12:47 AM   #3
ccbremech
Member#: 286915
2004 STI
BLUE
Ok, it's a 04 Sti so 32 bit ECU. Guess I will change it out and see if that helps. Thank you for your input! The car did run rich for a small amount of time so that may have caused it.
Old 04-23-2013, 06:54 AM   #4
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
It uses coolant temp to add fueling. If your running hotter then it wants it will change the cl target for sure.
Bamofo is offline   Reply With Quote
Old 05-05-2013, 11:01 AM   #5
ccbremech
Member#: 286915
2004 STI
BLUE
Changed the rear 02 and I'm good to go now. Thx to all for your input!
Old 05-09-2013, 07:26 AM   #6
Bamofo
Member#: 159743
07 STI Limited
If it happens again you can turn off that correction from the rear 02 with ecu flash. PM me your rom if you would like it changed. Glad you got it working!
