Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 05-08-2013, 01:05 AM   #1
CZBugeye2002
Member#: 274892
Default Noob tuning wideband question
Ok so I'm working on my tune for an 02 wrx with vf39 and dw650's, walbro 255, big tmic.
My question though is related to my wideband reading vs stock narrowband reading. My wideband reads about 15.8ish at warm idle while the stock sensor reads the expected 14.7ish. Fuel tables are tuned to within 2%. I know that the wb should not be installed after any cats, my question is, does that apply to the catted up pipe as well? If so, that is probably my problem. I am waiting on my catless up pipe to arrive. I couldn't find any threads about this specific question, so I appreciate any input. Thanks
CZBugeye2002 is offline   Reply With Quote
Old 05-08-2013, 01:26 AM   #2
StIGC11
Member#: 346106
2006 SGM BW88-75
E85
where is your wideband installed? should be in the DP.
StIGC11 is offline   Reply With Quote
Old 05-08-2013, 09:02 AM   #3
CZBugeye2002
Member#: 274892
It is in the downpipe. I just wondered if having the catted up pipe in would cause it to read incorrectly.
Old 05-08-2013, 09:25 AM   #4
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
It will cause it to read lean.
endrswrd is offline   Reply With Quote
Old 05-08-2013, 10:00 AM   #5
quazimoto
Member#: 70395
Which one do you own? And yes,the catted up-pipe counts,why would it not?
quazimoto is online now   Reply With Quote
Old 05-08-2013, 04:21 PM   #6
CZBugeye2002
Member#: 274892
I figured it did, but I just couldn't find a definitive answer anywhere. Thanks. It's an innovate mtx-l.
Old 05-08-2013, 08:28 PM   #7
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
If your A/F learning 1 A is within +/- 8%, then leave it alone. Your WB will be incorrect due to the catted up pipe.
don't freak out too much until you install the catless UP.
Old 05-09-2013, 09:43 AM   #8
CZBugeye2002
Member#: 274892
Thanks. Will do. Officially done freaking out.
