Old 03-12-2012, 12:38 AM   #51
SteyrTMP
Member#: 107205
2007 Impreza 2.5i
I'm having issues with this code as well, however, my wife's Subie is an automatic 1997 Outback. We bought it not running worth a crap, they thought it had a blown headgasket, but it was just the timing belt. Reinstalled the belt, pulleys, and tensioner, checked compression.
Now, when I turn it on, it will run at about 2000rpm for a minute or two, then drop down to about 1000rpm, pop a CEL code, and then runs like crap. Sometimes the engine shakes, like it's running on 2 or 3 cylinders, other times just runs really rough. I've replaced plugs, wires, and checked the coil pack. I've tried starting it just with 1 and 2 or just 3 and 4, and will run soso with either set of cylinders.
I'm baffled. I'm going to take apart the intake assembly and see if anything is gunky and/or not running ok and will post back. The only thing I can think of is the IAC.
SteyrTMP is offline   Reply With Quote
Old 03-12-2012, 05:48 PM   #52
POSBUTAWD
Member#: 124694
I've sold my car over a year ago, but still get notifications on this thread being active... so just to restate what my final experience was:
I had no problems after a thorough cleaning of the IAC valve. be sure to look inside every rubber hose you remove in the process of getting the IAC off the car. The thick rubber hose that came in from the side was quite big, yet it was completely shut with packed in dirt. I'm talking dirt packed so tight, you have to push it out with a screwdriver and then spray down the hose and clean out the remainder. The entry to the manifold was also completely blocked off and packed with dirt. A good cleaning was all it took to restore the idle back to normal and prevent the engine from going into limp mode.
Hope this helps someone out.
POSBUTAWD is offline   Reply With Quote
Old 01-28-2013, 10:22 AM   #53
caschmidt
Member#: 194453
2001 Legacy 2.5 GT
Winestone Pearl
Sorry to bring back an old thread but my 98 ob does the same thing. P1507 IACV fail safe, 1540 speed sensor. I did a 4eat to 5MT swap using a completely different engine. IT DID NOT SOLVE ANYTHING! So far the only thing left is speed sensor (used from previous 4eat). Just replaced that and it still does the same thing. MAF, replaced, still does the same thing. It's not the neutral switch or ANYTHING on the engine. The only thing that I havent replaced is the cat/AF/o2 sensor, and the engine computer. Idk if there's a bad connection somewhere or what..... But I'm pretty stumped.
caschmidt is offline   Reply With Quote
Old 01-31-2013, 09:39 AM   #54
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
2007 Legacy GT Spec-B
I was dealing with that P1507 code for months. I tried changing the neutral position switch and within 1 km the light was back on and my car was stalling randomly again.
Last thursday I decided to pull the IACV off(wow was it dirty!!) and gave it a proper cleaning and it has been working ever since. I sealed up the back end with duct tape, filled the unit with seafoam and then let it sit for a few hours. I then drained all the fluid out, cleaned all visible parts with q-tips and blew compressed air into the unit. Since then it's been idling perfectly, no stalling and no more check engine light.
Caschmidt, try cleaning your valve and see if that is indeed your problem, it takes less then an hour to do and the gasket only costs a few dollars.
V8Slayer is offline   Reply With Quote
Old 02-05-2013, 02:41 PM   #55
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
I had this problem for the first time yesterday. High idle, CEL, stuttering, limp mode 5mph home.
So far I wirebrushed the battery terminals and cleaned my K&N filter. Cleaning the terminals (which were very corroded and dirty) reset the ECU.
So far so good. The problem hasn't reappeared.
monovich is offline   Reply With Quote
Old 05-09-2013, 11:38 AM   #56
jkastrin
Member#: 355948
1998 Subaru Forester
I'm having the same problem with the 1507. I also have a misfire on cylinder 1,2,4, an 0440, 0500 and 1540 code... Any thoughts?
jkastrin is offline   Reply With Quote
Old 05-10-2013, 02:52 PM   #57
Qwikyking
Member#: 336666
1997 impreza wagon
teal/barf
i think i may be having the same issue as all of you, I've got a 97 impreza 5spd brighton wagon 1.8Lame, with 180xxxkm when i first got the car it ran rough and had a high idle (winter), had exhaust leaks etc etc i was getting p0141 (o2 sensor) and the code where idle is higher than expected (p0507?)
i cleaned the entire intake from the MAF to the TB, got a new exhaust and idle was a little more tame, (still cold weather)
then was getting horrid gas milage (7mpg) so i changed the WAY out of spec plugs, which fixed that.
-now that its warming up my car will start to limp once and a while on hot days (like described above)
-its weird tho, i went on a 80km trip with no issues and great driving (chilly spring day)
-then today (20 and sunny), stop and go traffic, taking small trips etc, on my way home it started limping right before i got home, could barely even hear my engine running while at a stoplight, so i plugged in my obd dongle and logged all codes for the next 3km i got home and screencapped the codes i got along the way and shut off my car, letting it sit for 5sec i turned it back on, and it was normal again.
i got these codes
p0141 (O2 sensor)
P0264 (Cylinder 2 Injector Circuit Low) <---- would explain the limping/shaking engine?
P0507 (Idle Air Control System RPM Higher Than Expected)
P1507 (Idle Control System Fault (Fail Safe Mode)
im going to try the neutral switch, aswell as checking the voltage on my injectors, dont feel like spending $200 on a iacv for a 1.8L would rather buy a whole new engine haha
Qwikyking is offline   Reply With Quote
Old 05-27-2013, 11:12 AM   #58
EJ_Enthusiast
Member#: 341058
The P0440 is an EVAP malfunction code. The P1507 is manufacturer specific which you wouldn't be able to figure out without taking it to Subaru and the P0500 is for vehicle speed sensor malfunction. The misfire could either be due to a vacuum leak, faulty injector, ability spark plugs, spark plug wires or ignition coil pack.
EJ_Enthusiast is offline   Reply With Quote
Old 09-18-2013, 01:37 PM   #59
nsibanez
Member#: 328933
ive got this problem going on with my girl;s 99 legacy. its an auto. ive already replaced the iac which helped slightly and fixed the p0505 or whatever for the iac but the 1507 is still there. would the NSS or inhibitor switch on the tranny be the cause too? from what ive been reading it mostly fixes it on the manuals and I cant find anything about it fixing it on the autos
nsibanez is offline   Reply With Quote
Old 04-25-2014, 08:02 PM   #60
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
got these codes p0507 and p1507 on a '99 Legacy SUS
I cleaned the IAC with carb cleaner so where it moves freely very very easy.. plenty of slack on the throttle cables..
SO the only thing I did not do now is change the PCV valve..
it's a very annoying code.
SubaruImpreza_power is offline   Reply With Quote
Old 10-03-2015, 04:09 PM   #61
TurboGuyPDX
Member#: 170856
1991 SS "the Clone"
TopScoob007+livestrong14
I've read this thread with great interest. 1998 2.5 OBW Outback Wagon. Automatic transmission. I had a p1507 so I cleaned the IAC by blasting brake cleaner down the rubber inlet while holding the rpm at 2000. Let idle 10 minutes This is Subaru's recommended cleaning procedure.
Code came right back. I replaced the IAC with a known good used one, got code p0507, no worries. Reset the IAC duty ratio to 32.5% using a Subaru select Monitor and all is good. I haven't seen any posts yet that talk about resetting the duty cycle to 25-40% after replacing the IAC. This is an important last step after messing with the IAC. Basically you're loosening the two small screws on top of the IAC and rotating it. In my case it was rotated clockwise about 1/8 inch. The idle slowly adjusted, 3-4 second delay, and all was well. Long test drive, several restarts so far. Behavior is night v. day. All fixed.
TurboGuyPDX is offline   Reply With Quote
Old 06-24-2016, 09:50 AM   #62
Yfz450guy
Member#: 448468
wait what?
you realize you are creating a whole new theory with resetting the duty cycle right? lol i have been reading about this code for almost a month and have not been able to make it go away.
also, let me throw this out there to everyone. why not just bypass the nss all together? we can bypass the clutch start switch by joining the wires together. why can't we do the same to the nss?
thoughts?
Yfz450guy is offline   Reply With Quote
Old 07-09-2016, 05:39 PM   #63
Al Werner
Member#: 450429
Default Check the ground first!
98 outback determined to trouble shoot myself...
Replaced mass airflow sensor, oxygen sensor, idle control valve, vehicle speed sensor and neutral safety switch - still through the p-1507 code. Finally saw that the grounding bracket was loose. The net lead from the battery attaches to a bracket and the bolt holding the bracket was loose!! 1 min fix! Check your grounds first! Runs like a champ now!
Al Werner is offline   Reply With Quote
CEL p1507 code. Please help Ive tried everything. Motts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 07-09-2016 05:47 PM
WTB: 02-03 struts w/ everything except springs Photoroller Private 'Wanted' Classifieds 4 06-05-2008 09:32 AM
Why does Lowe's always have everything except what I want? -=C=- Off-Topic 21 12-13-2005 01:30 AM
USDM STi complete motor: need everything except the intercooler MrSaabaru Private 'Wanted' Classifieds 1 09-20-2005 10:04 AM
Myxsucks (ignore everything except best plate) SukedUpBySubiSTi Off-Topic 12 08-04-2005 01:44 AM
