Closed Thread
Old 05-07-2013, 04:19 PM   #1201
kdizz781
Member#: 340925
2013 WRX sedan
Dark Gray Metallic
I know I'm new around here but I just wanted to say Ben was awesome with communication... But that doesn't mean you people don't have to read before asking questions. It's all on page 1. Very straight forward
kdizz781 is offline
Old 05-07-2013, 04:36 PM   #1202
KAdams
Member#: 350544
2002 Bugeye Wagon
Awesome I want to do this to cut down on the things on my key ring
KAdams is offline
Old 05-08-2013, 02:17 PM   #1203
jadawgis732
Member#: 208409
2012 WRX Sedan
Default Needs Help
Here was my problem. I have now solved it. It seems the last time I had removed the door panel I had not properly installed the cluster of window switches and plugs correctly. Only unlock worked.
So, I'm having a little trouble getting the programming phase to work. I own a 2012 WRX, and I think I'm using the correct fob. There are two pictures below. I do open and close the door between turning the key to the one position 10 times, and starting the programming, and the long beep starts at that point. I get the car into programming mode just fine, but when I enter the first number on the drivers side door (using the lock side of the lock/unlock switch) and then press unlock (to signal the car that I've finished entering the first number) the beep doesn't end. I get 6 digits into the code and it fails everytime. Am I missing a step?
http://img32.imageshack.us/img32/7480/img1097custom.jpg
http://img38.imageshack.us/img38/4945/img1098custom.JPG
jadawgis732 is offline
Old 05-08-2013, 02:19 PM   #1204
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by jadawgis732 View Post
So, I'm having a little trouble getting the programming phase to work. I own a 2012 WRX, and I think I'm using the correct fob. There are two pictures below. I do open and close the door between turning the key to the one position 10 times, and starting the programming, and the long beep starts at that point. I get the car into programming mode just fine, but when I enter the first number the beep doesn't end. I get 6 digits into the code and it fails everytime. Am I missing a step?
[IMG]http://img32.imageshack.us/img32/7480/img1097custom.jpg[IMG]
[IMG]http://img38.imageshack.us/img38/4945/img1098custom.JPG[IMG]
Are you pushing the lock and unlock buttons on the car? Not the ones on the remote. The remote is not used for this process at all. Leave it in the house. Just the buttons on the car. When the long tone is sounding it should stop when you push the button the first time.
xluben is offline
Old 05-08-2013, 02:20 PM   #1205
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
Sounds like you're entering the code with the key fob instead of your door's lock/unlock button.
OakleyWRX is offline
Old 05-08-2013, 02:23 PM   #1206
jadawgis732
Member#: 208409
2012 WRX Sedan
No no, I know. I am pressing it on the driver's side door. C'mon give me some credit here, lol.
Disregard all that guys. Sorry, the last time I had taken the door panel off, it seems I only had the unlock button working. It is all fixed and programmed. Much apologies.
Old 05-08-2013, 02:29 PM   #1207
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
That has been a common issue. This isn't a hard process, so either your car isn't working or you're making a simple mistake. Are you pushing the lock button? Does the lock button normally work to lock the doors? If both of those are "yes" then the tone should stop the first time you push lock. If it doesn't, then you're doing something wrong.
xluben is offline
Old 05-08-2013, 03:30 PM   #1208
jadawgis732
Member#: 208409
2012 WRX Sedan
Maybe the plugs to the door lock harness are finicky? But I concur. Totally. And thanks again for putting this together.
Also, it isn't a hard process, but the beeping in the background can screw up the count, so when you have three 8's in a row, I found the best way to press the lock button the correct number of times is to count out loud. But I am ADH- oh look a butterfly! Lol.
Old 05-08-2013, 03:34 PM   #1209
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
What I'm saying is that it shouldn't be beeping in the background. The beeping should stop once you start (correctly) entering the code. Can you check that the door lock buttons are actually working when not in programming mode? I think there was one person that managed to blow a fuse during this process so it wouldn't work. Otherwise it's wiring or you're not doing something right.
xluben is offline
Old 05-08-2013, 03:38 PM   #1210
OakleyWRX
Member#: 318361
12 WRX STi 5-Door
Or maybe the fact that the door lock button won't work when the door is open (so you don't leave the key in)?
I had to do it with my door closed.
Old 05-08-2013, 03:43 PM   #1211
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
The door should be closed when you do this. It would be funny if that was really the issue, haha.
xluben is offline
Old 05-08-2013, 04:07 PM   #1212
jadawgis732
Member#: 208409
2012 WRX Sedan
I already fixed it fellas. Nothing to worry about. It was just that the harness under the lock/unlock and window lock switch was screwed up. It programmed correctly without issue once I discovered the issue.
Old 05-08-2013, 04:13 PM   #1213
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Wow. Weird. Checking if the door lock/unlock buttons function normally is a logical thing to check if you're having issues with this. I wouldn't expect it, but it's simple to check.
xluben is offline
Old 05-08-2013, 08:52 PM   #1214
esmcblur
Member#: 352593
Ben, thanks so much. Got the fob today and programmed it up. Now I just have to find somewhere to get it cut!
esmcblur is offline
Old 05-09-2013, 12:52 PM   #1215
esmcblur
Member#: 352593
This cutting process is harder than I thought! Trying to find a shop to do it, and having the confidence they will get it right.
esmcblur is offline
Old 05-09-2013, 02:02 PM   #1216
Saunders1986
Member#: 303165
no one in my area would cut mine :-S
Saunders1986 is offline
Old 05-09-2013, 02:59 PM   #1217
esmcblur
Member#: 352593
were you able to eventually get it done?
esmcblur is offline
Old 05-10-2013, 07:11 PM   #1218
erich6788
Member#: 354762
2013 WRX Hatchback
Do you have to break the key in once it's cut, like a normal doorknob key?
erich6788 is offline
Old 05-11-2013, 04:12 PM   #1219
ndmx52
Member#: 200802
2006 LGT - sTg 1
BSM
Same here.
ndmx52 is offline
Old 05-11-2013, 08:19 PM   #1220
SaiYanNara
Member#: 333328
Default Parts for Flip Key
Do you know where I can get all the necessary parts for the Flip Key mod for a 2012 STi?
SaiYanNara is offline
Old 05-11-2013, 08:31 PM   #1221
kdizz781
Member#: 340925
2013 WRX sedan
Dark Gray Metallic
Page 1... Read
kdizz781 is offline
Old 05-12-2013, 01:09 AM   #1222
SaiYanNara
Member#: 333328
Originally Posted by kdizz781 View Post
Page 1... Read
Apparently like most of the newbies I cant send EMail yet
Old 05-13-2013, 08:19 AM   #1223
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by ndmx52 View Post
Same here.
It can be a bit tricky. Just take your time and go slow. And if you screw up, find someone to cut that blank blade!
Maybe in and out a few times depending on how well the blade was cut, but it shouldn't be too bad.
Page 1... Read
Sent you a PM!
xluben is offline
Old 05-13-2013, 01:21 PM   #1224
esmcblur
Member#: 352593
Got it cut today for $28!
Very happy, thanks again Ben!
esmcblur is offline
Old 05-13-2013, 08:34 PM   #1225
ndmx52
Member#: 200802
2006 LGT - sTg 1
BSM
Anyone have pics of a few months of use? How is this case holding up to all the wear and tear of everyday life?
ndmx52 is offline
Closed Thread
Switchblade key for a 2007 WRX? coop3422 Interior & Exterior Modification 20 08-02-2011 02:46 PM
flip out switchblade key help CSwrx22 Car Audio, Video & Security 8 01-01-2011 11:04 AM
Bugeye ebay switchblade key fob flacopower Newbies & FAQs 4 03-01-2010 06:15 PM
Anyone try this switchblade key for their subie? Renton_TDI Interior & Exterior Modification 22 02-04-2010 08:34 AM
DIY 08 Key fob into switchblade key EdsWRX Interior & Exterior Modification 32 04-08-2009 01:14 AM
