Old 02-24-2013, 12:31 AM   #1
joker11
Member#: 77572
Default Plasti-Dip questions.
I want to plasti-dip the badges on my trunk. I saw pics of someone doing this and they didn't mask off close to the badges at all. I know this stuff is suppose to peel off of your paint, after I spray it and it dries, should I score the edges of the badges with a knife, so it will peel off of the trunk but not the badges?
I guess really what i'm asking for is an actual step by step process of how do I plati-dip my trunk badges.
joker11 is offline   Reply With Quote
Old 02-24-2013, 12:36 AM   #2
Pengu
Member#: 341101
2005 STI
Just rub your finger on it and it'll come off. (After tapping the sections off).
Pengu is offline   Reply With Quote
Old 02-25-2013, 08:10 AM   #3
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
Actually while the thread was started, I am having problems with pulling the tape after spraying plastidip. I want to paint my badges but need to be able to tape them off. I searched on this subject and found that it works better if you pull off the tape when its wet, but if you are doing multiple coats it just peels the bottom coat. I am experienced with auto paint but plastidip is a whole new thing to me. I don't mean to hi-jack the thread from you but it is already started, can anyone help me out?
Chris
00camaro16 is offline   Reply With Quote
Old 02-25-2013, 08:49 AM   #4
DearDiaryJackpot
Member#: 343041
2013 sti
white
Look "plasti dip on a car" on YouTube. That should cover some ground.
DearDiaryJackpot is offline   Reply With Quote
Old 02-25-2013, 10:04 AM   #5
Trustkevin13
Member#: 259184
2008 Subaru WRX
Trustkevin13 is offline   Reply With Quote
Old 02-25-2013, 10:39 AM   #6
joker11
Member#: 77572
How did you get out the little sections in the letters, in the B, R, and A? Also did you peel it off when it was still kinda wet, or do you want it totally dry? Looks great by the way, exactly how I want mine to turn out!
Old 02-25-2013, 11:01 AM   #7
Beau M
Member#: 345079
13 Wrx sedan
Everything you want to know is in these videos, specifically the third one down:
https://www.dipyourcar.com/pages.php?pageid=8
Beau M is offline   Reply With Quote
Old 02-25-2013, 11:06 AM   #8
JackWasHere
Member#: 346854
2005 WRX
If anyone is in the Bay Area of California and interested in Plasti Dip, I can be of help. I have been installing Plasti Dip on cars for about 8 months. You won't be disappointed with my work, and my prices!
PM me if you're interested.
JackWasHere is offline   Reply With Quote
Old 02-25-2013, 11:10 AM   #9
Trustkevin13
Member#: 259184
2008 Subaru WRX
I did the dip and then after the coats I took a toothpick and peeled it out. the inside of the letters are a little striped but when you stand back you wont even see it. that was the first time i ever did plastidip and i had to redo it cause i ripped it off the S. take your time doing it. if you failed the first time, peel it off and do it again, those spray cans can do tons of coats.
Note that you should get all angles (right to left shoot, left to right shoot, top down shoot, and bottom up shoot). and use newspaper to mask off the surrounding area like for the one you saw with the the massive coverage.
I had this on for about 8 months and it has been through countless car wash (machine and hand), any weather, rain, snow, sleet, ice and still remain strong. totally worth it and looks good.
Old 02-25-2013, 12:27 PM   #10
JackWasHere
Member#: 346854
2005 WRX
Here's a few technical tips:
-Light first coat
-Following coats should be thicker. Almost glossy looking
-Shake can very very well
-Run can under warm water (sprays much finer)
-Always keep the nozzle clean as it tends to clog
-Spray at a right angle to the surface (don't twist your wrist while spraying)
WATCH VIDEO TUTORIALS ON YOUTUBE, they help alot.
Old 02-27-2013, 06:13 PM   #11
JackWasHere
Member#: 346854
2005 WRX
Also DipYourCar sells enhanced spray nozzles for the cans. Really does make a huge difference
Old 03-03-2013, 01:06 AM   #12
joker11
Member#: 77572
Thanks again for everyone help, it turned out awesome!
Old 03-03-2013, 02:44 AM   #13
jm02466
Member#: 282876
05 LGT Limited
04 WRX Wagon
I've done my fair share of plasti-dipping and that came out great, especially for your first time. Nice job on the key hole.
jm02466 is offline   Reply With Quote
Old 03-03-2013, 10:08 AM   #14
joker11
Member#: 77572
Thanks, I scratched up the paint a bit trying to get the Dip out of the small areas in the S B and R letters, I was using a fine tip flat head screwdriver...I guess using something blunt like maybe a toothpick would have been better. Now I know for next time.
This stuff really is amazing how it just peels right off of your paint, let just hope it lasts long...
Old 03-03-2013, 02:12 PM   #15
jm02466
Member#: 282876
05 LGT Limited
04 WRX Wagon
Yeah, toothpick is the way to go.
As far as durability, I did my friend's badges over a year ago and I have done several sets of wheels, all have stood the test of time, even through car washes and New England winters.
Old 03-03-2013, 08:23 PM   #16
tmvqpbvu
Member#: 348883
tmvqpbvu is offline   Reply With Quote
Old 03-10-2013, 12:24 PM   #17
braydeno
Member#: 301547
2006 Subaru STi
Has anyone sprayed plasti through a conventional gun? I have a iwata air gunza I am going to try out. But I need an idea for tip size and air pressure.
braydeno is offline   Reply With Quote
Old 05-07-2013, 11:18 AM   #18
13-ReX
Member#: 355674
2013 Subaru WRX
The great thing about the plasti-dip is if you dont like it or you mess up.... Just do it over again. So its trial and error. Just play around with it and see how it works. Ive done a bunch of stuff with it on my '13 WRX.
13-ReX is offline   Reply With Quote
Old 05-07-2013, 10:00 PM   #19
1nonly
Member#: 355210
2006 WRX
Gray
Where can you by the spray cans from
1nonly is offline   Reply With Quote
Old 05-07-2013, 10:02 PM   #20
joker11
Member#: 77572
Got mine at NAPA.
Old 05-07-2013, 10:10 PM   #21
jm02466
Member#: 282876
05 LGT Limited
04 WRX Wagon
Got mine at NAPA.
Dipyourcar.com
Old 05-08-2013, 10:28 AM   #22
13-ReX
Member#: 355674
2013 Subaru WRX
Ive bought them at Lowes and Home Depot but they only have White and Black in the store. If you want more colors go to DipYourCar.com
Old 05-09-2013, 03:58 PM   #23
sobejoe
Member#: 298122
2011 WRX Sedan
13-rex is correct... But Homedepot.com has other colors listed as "in store" but I have only seen black. HD also has other colors but you have to order online and ship to store and it has to be a box of 6 for around $46-$62 depending on the color. This would still be cheaper than dipyourcar becuase of shipping and they charge a bit more per can.
sobejoe is offline   Reply With Quote
