Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 05-09-2013, 09:14 AM   #2851
crazyjester900
Member#: 323176
2004 WRX
Wrap it
crazyjester900 is offline   Reply With Quote
Old 05-09-2013, 09:15 AM   #2852
A. G. Pym
Member#: 287398
2008 WRX Hatch
TP Stage 1
Originally Posted by crazyjester900 View Post
Wrap it
And then post awesome pictures.
A. G. Pym is offline   Reply With Quote
Old 05-09-2013, 10:40 AM   #2853
tuzzio
Member#: 292532
05 STI
Wrap it
Never wrap it
Never pull out
tuzzio is offline   Reply With Quote
Old 05-09-2013, 10:45 AM   #2854
easterbran
Member#: 307359
'05 STi Stage II
Originally Posted by tuzzio View Post
Never wrap it
Never pull out
Old 05-09-2013, 10:46 AM   #2855
needfx
Member#: 345884
[quote=Justin V;39685074]I had my motor out last week and did a few custom things to it.
20G went on as well as a 3" hard inlet so I had to work with the fuel lines, I just got rid of the metal lines under the manifold and ran rubber hoses. I pretty much just followed APS's instructions. I had the harness out too so I did the following,
Engine wiring harness, got rid of the uneeded plugs, air pump delete on my 07, 2x TGV plugs per side, and the air check valve that runs from the pcv to the turbo inlet. Also wrapped the gray part in black now.
I tried to do a wire tuck but Geez there is no room under there.
This is what came out.
Also deleted the oil heat exchanger to fit my EL headers on my 07 wrx.
Pulled the nipple from the waterpump and tapped it for a 1/4 npt plug, I guess next go round I'll just order a 08 wrx pump.
Also order the OEM plug for Legacies and what not without the heat exchanger and removed the nipple by the oil filter.
NEXT UP: temp switch on the I/C to controller the sprayer.
Isnt that a downgrade to remove the oil cooler?
needfx is offline   Reply With Quote
Old 05-09-2013, 10:58 AM   #2856
Justin V
Member#: 98747
07 WRX
been stated multiple times its not an oil cooler
running 180 deg water around my oil doesn't seem cool
however the EL headers that required me to remove the "heat exchanger" were an upgrade
Justin V is offline   Reply With Quote
Old 05-09-2013, 04:04 PM   #2857
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
When the oil is 220F and hotter, then 180F coolant will cool the oil. Hence "oil cooler". It does double as an oil warmer when the oil temp is less than the coolant temp, but that is a good thing. Your engine is designed to work with oil that is hotter than your coolant [over 200F].
It is a BAD idea to not have an oil cooler.
jebjkey is offline   Reply With Quote
Old 05-09-2013, 08:15 PM   #2858
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
so why Subaru got rid of it 08+?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 05-09-2013, 08:26 PM   #2859
Justin V
Member#: 98747
07 WRX
the same reason you should keep the coolant lines hooked up to your throttle body. :sarcasm:
Put phenolic spacers to block heat but then just feed it up a different route via the coolant.
Air coming out of my I/C is about 80-90 deg depending on the weather and heat soak, but I wanna heat it up a little more right before it goes back into the engine.
Old 05-09-2013, 08:26 PM   #2860
vms150
Member#: 172917
2004 WRX
The thing is, the style oil coolers that you would mount up in front of the radiator are very cheap and very easy to mount and plumb. If you're going to remove the stock one, why not just replace it with an aftermarket one.
vms150 is offline   Reply With Quote
Old 05-09-2013, 08:27 PM   #2861
Jackie leggs
Member#: 249794
02 WRX wagon
atomic orange pearl
Engines were designed a bit different and made to operate more efficiently. Just because Volkswagens were once air cooled doesn't mean it's OK to remove the radiators on the newer ones. Not starting anything just making a point haha.
Jackie leggs is offline   Reply With Quote
Old 05-09-2013, 08:57 PM   #2862
Justin V
Member#: 98747
07 WRX
They are designed for worldwide production use.
They will run and operate in many different ways and in some cases better, just ask anyone with a stock car that's had it tuned. They are not pushed to their max and they can be optimized in various ways for various factors.
Many things are installed for fail safes or to offer products to a larger market, here in the south I don't worry about the TB freezing or my oil taking along time to warm up. Until I start tracking the car I will not get an oil cooler and then I will still have it thermostatically controlled because oil that is too cool is not good either.
This is the modification thread so these are things we've done to our cars that suit us best. Take it or leave it.
Old 05-10-2013, 01:27 PM   #2863
forgotten3978
Member#: 305941
2008 impreza 2.5
Charcoal
installed holograms into all 4 doors the other weekend!
[IMG][/IMG]
forgotten3978 is offline   Reply With Quote
Old 05-10-2013, 05:24 PM   #2864
easterbran
Member#: 307359
'05 STi Stage II
Pics or it didn't happen.
Old 05-10-2013, 08:31 PM   #2865
forgotten3978
Member#: 305941
2008 impreza 2.5
Charcoal
It showed up when I uploaded it from my laptop but from my iPhone I can't see it for some reason.
Old 05-10-2013, 10:21 PM   #2866
usfsfire42
Member#: 242630
.. Flu shot
technician.
bran muffin
usfsfire42 is offline   Reply With Quote
Old 05-10-2013, 11:31 PM   #2867
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Because Americans are cheap and Subaru saw this as a way to save a few bucks for SOA. All ROW WRXs get the oil cooler and so does the STI. All ROW WRXs get LSD R180s too ;-) So not critical enough that Americans can haz, but critical enough every other WRX and STI does have it.
True, you do lose the heating action so you run with cold oil longer over the stock cooler, and that period is extended a lot if you don't use a thermostat in an external oil cooler. I tried to find a cheap one when I looked at them, with a quality cooler core with low pressure drop, proper fittings and a good thermostatic sandwich plate.. its hard to do it right for less than $400. For free you can leave the stock cooler on it certainly does more good than harm.
Power6 is offline   Reply With Quote
Old 05-11-2013, 01:18 AM   #2868
mfmunh
Member#: 307040
got my LED lights for my interior and did an on-the-fly mod for the hatch light. I know there are "real" mods out there for the hatch but I think this is a easy and effective way.
tools needed: double sided tape and aluminum foil
start by cutting your aluminum foil 2"x 2.5-3"
place double sided tape where the arrow marked
follow as show. You want the shiny side of the foil inside and the matted side out.
I don't have before/after pictures(it was on-the-fly) but the end result is a BIG difference from stock and with/without the aluminum foil.
hope you guys find this useful and enjoy
mfmunh is offline   Reply With Quote
Old 05-11-2013, 01:54 AM   #2869
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
I like it, probably use this idea in my wagon to accompany the lights I added to the roof molding.
EvileyeZ88 is offline   Reply With Quote
Old 05-11-2013, 11:44 AM   #2870
easterbran
Member#: 307359
'05 STi Stage II
Originally Posted by usfsfire42 View Post
bran muffin
Old 05-11-2013, 09:09 PM   #2871
sytz
Member#: 291712
2006 WRX Wagon
Originally Posted by TTyphoon View Post
Subaru-bed! (:
I want a subabed
sytz is offline   Reply With Quote
Old 05-11-2013, 11:42 PM   #2872
usfsfire42
Member#: 242630
.. Flu shot
technician.
At bran muffin:
That bed does look comfortable. I have also never seen bars like that in the back
Old 05-12-2013, 06:03 PM   #2873
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Originally Posted by Power6 View Post
Because Americans are cheap and Subaru saw this as a way to save a few bucks for SOA. All ROW WRXs get the oil cooler and so does the STI. All ROW WRXs get LSD R180s too ;-) So not critical enough that Americans can haz, but critical enough every other WRX and STI does have it..
Source? What does ROW stand for? Because I've personally seen JDM and EDM WRX's with vlsd R160's and have never seen them with a factory LSD R180.
Old 05-13-2013, 06:35 AM   #2874
powells85
Member#: 201053
12 X
ROW = Rest of World
powells85 is offline   Reply With Quote
Old 05-13-2013, 11:53 AM   #2875
NutWagon
Member#: 230925
04 WRX Wag Stage 4
06 Impreza 2.5I
Originally Posted by silverbullet830 View Post
thanks man. did the center caps to match too.
Just a note to get the textured look from the plasti dip heat the can up a lil bit and it will come out smooth.
NutWagon is offline   Reply With Quote
Show us your unique modifications lancewr1 Interior & Exterior Modification 7214 01-10-2012 12:09 PM
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods bluerex79 Member's Car Gallery 6 05-02-2011 09:02 PM
Calling all Graphix......Show Us Your Stuff... grnlantern1 Member's Car Gallery 37 07-16-2002 01:25 AM
show us your wrx gauge installs. lstepnio Member's Car Gallery 51 05-22-2002 03:43 AM
Show us your T's (OZ Super T's that is) Who flung dung General Forum Archive 11 02-12-2001 07:46 PM
