Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 05-09-2013, 07:49 PM   #2151
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
Originally Posted by Louie View Post
Disclaimer here though... Catless on the GR seem to have a unique raspy sound to it. This is the borla atak. It was in my invidia too. I think it's a characteristic of the catless exhaust.
Louie, is yours a GR or GV? I do get that same "GRAAAAANCH" when I'm WOT in my car with the catted DP. It may just be a bit more pronounced with the catless.
Gallo2011 is offline   Reply With Quote
Old 05-09-2013, 08:34 PM   #2152
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Originally Posted by xabre1200 View Post
Honestly I thought about running catless for awhile just because of the price and the fact that I could pop fireballs out of my exhaust but the harmful effects on your body and everyone else from breathing in all those harmful positions that aren't filtered by your cat anymore really isn't worth it IMO. If you have an exhaust leak anywhere with a catless dp most likely the fumes are going to be going into your cabin when driving around in the city. Just my .02
You make it sound like your pumping sarin gas out of the tail-pipe. If you scale your car against the millions on the road, your emission foot-print is pretty small (I know I'm stretching this pretty far). I understand your point and it is valid; however, the emissions coming from your catted exhaust is just as poisonous as my uncatted emissions... just food for thought.
And momentary fireballs isn't going to melt your bumper, its not a flame thrower. You can check my bumper for 18k miles of fireballs (I've only had after-fire pops only when tracking the car).
Originally Posted by Gallo2011 View Post
This isn't a problem if she showers first.
And for what it's worth, I went catted. You will still smell the exhaust more than you do with the stock DP because the aftermarket DP is freer flowing and doesn't filter exhaust fumes like stock. But it's not ridiculous.
2011 STi Sedan.. its still a GR right? The Borla really makes a unique sound. You love it or hate it.
Louie is offline   Reply With Quote
Old 05-09-2013, 11:29 PM   #2153
PearlRex11
Member#: 284420
2011 WRX Sedan
Catless does add more rasp. A friend of mine had a sedan with the Q300 as well and his is catless, definitely more rasp than mine. Another friend was catless with the Q300 but El headers, it was so raspy it was ridiculous. It sounded like an entire different cbe was on it. Crazy how parts change the sound that much.
PearlRex11 is offline   Reply With Quote
Old 05-10-2013, 06:13 PM   #2154
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
I believe the sedan is a GV while the hatch is a GR. Don't trust myself on that so...
From Wikipedia:
The new Impreza was offered as a five-door hatchback (designated GH), with the four-door sedan (designated GE) introduced in 2008. The wide-body variants of the hatchback and sedan are labelled GR and GV, respectively.
Old 05-10-2013, 07:58 PM   #2155
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
From Wikipedia:
Well.... Eh, thanks I guess. Good luck finding parts in GV searches. I don't think I've seen enough to make wonder what the GV designated.
But I guess it's good to know.
Old 05-10-2013, 08:23 PM   #2156
RM_2
Member#: 163058
'16 BRZ Limited WRB
'06 Saab 9-2X 2.5i NGM
2011 WRX Hatchback - Various catback exhausts.
SPT Exhaust
Stock Exhaust
Differences. SPT on right and stock on left. No resonator on the SPT exhaust. Double walled tips on SPT.
And my new instrument of destruction - the TurboXS GT Catback:
Last edited by RM_2; 05-10-2013 at 08:38 PM. Reason: Now with smaller images that aren't 3MB each
RM_2 is offline   Reply With Quote
Old 05-10-2013, 09:07 PM   #2157
PearlRex11
Member#: 284420
2011 WRX Sedan
Good choice on that cbe. It sounds nice with a very bassy tone.
Old 05-10-2013, 09:13 PM   #2158
RM_2
Member#: 163058
'16 BRZ Limited WRB
Thanks! I'm looking forward to installing it tomorrow morning.
Old 05-11-2013, 02:52 AM   #2159
PearlRex11
Member#: 284420
2011 WRX Sedan
Here is some info on installing that cbe I posted earlier in the thread. Hopefully this makes sense and helps if you run into problems installing it. It's not a very hard install though.
The stock spring bolts still fit in the mid pipe/Dp connection. I put the spring bolts through the turbo xs mid pipe (without spring on it) first, then turned them so that the shoulder of the bolt would wear down slightly and fit through the flange better, then put the spring on it. The spring bolts on the rear are a similar issue, you might have to take a small file and clean out the mounting holes on the flange so that the spring bolt can slide through the flange holes. A dab of oil on the shoulder of the bolts would help.
Old 05-11-2013, 10:00 AM   #2160
Ampliified
Member#: 328243
2012 Impreza WRX
Going stage 2 soon full turboback straight pipe hope I don't shoot too many flames.
Ampliified is offline   Reply With Quote
Old 05-11-2013, 02:42 PM   #2161
RM_2
Member#: 163058
'16 BRZ Limited WRB
TurboXS GT Catback Exhaust installed. OEM downpipe. Bunch of new washers and bolts from Napa Auto Parts
Results:
Checking for evenness on both sides:
Success!
Old 05-11-2013, 05:05 PM   #2162
BigO Scoobie
Member#: 299124
^ sweet
BigO Scoobie is offline   Reply With Quote
Old 05-11-2013, 09:43 PM   #2163
honestabe
Member#: 261730
2011 WRX hatch
RM_2 that actually looks pretty good, how's it sound?
honestabe is offline   Reply With Quote
Old 05-11-2013, 10:33 PM   #2164
RM_2
Member#: 163058
'16 BRZ Limited WRB
It provides the signature UEL rumble and from the interior, it actually sounds quieter than the SPT I had before (less resonance/drone, maybe?). It's a good system for the price I paid for it. It ran me $604 for the exhaust from Spun Autosports, then about $20 for a rubber mallet to beat the heat shield into submission (so it doesn't come into contact with the flex joint) and two bolts, two nuts, six or so washers. Idle is barely noticeable over the stock exhaust, except in the lower frequencies (more bass).
I haven't broken it in yet since I just put it on today but my impression is that it looks much louder than it sounds. Firing the car up is a much quieter affair, compared to the SPT.
Old 05-12-2013, 06:17 PM   #2165
ionoo
Member#: 317035
2015 STI
CWP
https://www.youtube.com/watch?v=Nk4xkxFNFHE
2013 STI Sedan Cobb Cat-Back exhaust. Enjoy!
ionoo is offline   Reply With Quote
Old 05-12-2013, 06:22 PM   #2166
RM_2
Member#: 163058
'16 BRZ Limited WRB
You need a better camera!
Old 05-12-2013, 06:45 PM   #2167
ionoo
Member#: 317035
2015 STI
CWP
Quick cell phone for sound clip, better vid coming.
Old 05-12-2013, 09:20 PM   #2168
RM_2
Member#: 163058
'16 BRZ Limited WRB
Sweet. Looking forward to it even though I don't have a sedan haha
Old 05-13-2013, 12:59 AM   #2169
ionoo
Member#: 317035
2015 STI
CWP
Absolutely, time permitting tomorrow I should have something up with a real camera. Also, I'm considering using some protools recording gear to get a high quality sound clip. That would take some time so let me know if anyone is interested in that.
Old 05-13-2013, 01:04 AM   #2170
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Sounds really quiet and the tips stick out pretty far...
xabre1200 is offline   Reply With Quote
Old 05-13-2013, 01:58 AM   #2171
ionoo
Member#: 317035
2015 STI
CWP
It was recorded on a cell phone it's actually louder in person. I should have a higher quality sound clip available this week. I am still fighting with the tips, they are supposed to be flush, I'm not sure why they are out so far. I'm going to mess with that more tomorrow.
Old 05-13-2013, 02:24 AM   #2172
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Oh okay and haha dang cause they are sticking out WAYY further than flush.
Old 05-13-2013, 07:03 AM   #2173
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Ionoo-
Pull your car out of the garage and place your camera about 5-8 feet behind the the car at tail pipe height. Phones actually have decent microphones in them but are meant to pick up sounds that are direct. I have compared several phones, cameras, go pro, and contours... They really all sound about the same. A higher end microphone will probably pick up more ambient noise..unless you can cancel it all out post.
Good luck
Old 05-21-2013, 11:57 PM   #2174
ionoo
Member#: 317035
2015 STI
CWP
So I spent a solid day working with EFI logics to find a solution to the 2011+ WRX/STI Sedan CBE tip alignment problem for my Cobb prototype. We came to the conclusion that it was welded incorrectly so naturally before personal fabrication I contacted Cobb. Within 24 hours Cobb has a replacement exhaust being shipped from CA to CT. Moreover, this replace is a production product, NOT PROTOTYPE, prepare for the release!!
Sound clip: Prototype Exhaust
Old 05-22-2013, 01:30 AM   #2175
cliff_11WRX
Member#: 275586
2011 WRX Sedan
290whp 340wtq Cali 91oct
^ are you on stock dp? aftermarket? catted or catless? How's the drone on the freeway etc?
cliff_11WRX is offline   Reply With Quote
2011 Subaru WRX/STI Front lip! AndrewtechAutomotive Exterior/Styling 16 07-09-2012 10:13 PM
2011 Subaru WRX STi Limited Sedan 1080p and stills, near Mt. Hood. HannahSubaru North West Impreza Club Forum -- NWIC 118 12-24-2011 01:51 AM
2011 Subaru WRX STI ricochet NASIOC Official News, Articles and Polls 176 07-07-2011 09:29 PM
2011 Subaru WRX STI Sedan vs. 2007 STI AVANTI R5 News & Rumors 42 01-18-2011 10:47 PM
Subaru WRX / STi Exhaust Parts + More ViperBoy Private 'For Sale' Classifieds 6 10-10-2004 12:26 AM
