Old 03-20-2013, 07:42 PM   #76
scubynoob
Member#: 276157
2006 WRX sedan
Thats awesome! Thank you for the follow up!
scubynoob is offline   Reply With Quote
Old 03-30-2013, 08:10 AM   #77
eckoflyte
Member#: 348683
How did you get the elastic cord to hold together. Did you just tie up the ends?
eckoflyte is offline   Reply With Quote
Old 03-30-2013, 08:25 AM   #78
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
I first made the channel for the cord by folding over the edge of the material and sewing. Then slipped the cord into the channel but cutting it about a 1" or 1-1/2" depending on how much stretch you want.
Sew in one side flush to the end of the cover by hand if possible. I'm not sure how to do it any other way and I can't seem to fit it under the sewing machine.
Once you lock in one side of the cord, you'll need to scrunch up the material in order to get the cord to match up on the other end and sew it into place.
I'd like to experiment with glue to see if it'll hold better (or easier) than trying to sew it.
Old 03-30-2013, 09:00 AM   #79
eckoflyte
Member#: 348683
Awesome. Would some sort of thick polyester or nylon thread do the trick? Can't seem to find the polyurethane thread you referred to. I've sourced all the other materials fairly easy.
Old 03-30-2013, 09:19 AM   #80
Overland04
Member#: 293311
2013 FXT 6-Speed
I'm sure the nylon thread would work great. The polyurethane thread I used was from a local Walmart. Wasn't anything special, just off the shelf stuff.
I Just read your PM but I figured I'll answer it here
Cheers!
- Jason
Old 05-04-2013, 05:54 PM   #81
emusoda
Member#: 211869
2006 STI
Bump, have you decided to make these?
emusoda is offline   Reply With Quote
Old 05-06-2013, 03:44 PM   #82
Smdavis27
Member#: 219455
2009 WRX Sedan
I am interested in buying a set of these for my BC's PM me your figure
Smdavis27 is offline   Reply With Quote
Old 05-06-2013, 04:30 PM   #83
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
+1 !!
Let's Spool is offline   Reply With Quote
Old 05-07-2013, 04:14 PM   #84
Nukem
Member#: 303705
What method did you use to clean your coilovers?
Nukem is offline   Reply With Quote
Old 05-07-2013, 04:18 PM   #85
Overland04
Member#: 293311
2013 FXT 6-Speed
Originally Posted by Let's Spool View Post
+1 !!
Gathering more material soon and setting up a new sewing station.
NO Promises but I might be able to make a couple sets again.
I'll need a lot of measurements and money to cover material costs at minimum.
I'll keep you posted, thanks for inquiring!!
Old 05-07-2013, 04:19 PM   #86
Overland04
Member#: 293311
2013 FXT 6-Speed
To clean these I used very warm water, dish soap and a stiff bristle nylon brush. Came out great!
Old 05-08-2013, 07:37 PM   #87
Laciemay
Member#: 354202
2004 Impreza WRX Wag
Java Black Pearl
I would have never thought to do that
Laciemay is offline   Reply With Quote
Old 05-10-2013, 12:23 AM   #88
drifter001
Member#: 324227
05 wrx
cgm
id be interested in a set for my bc br series
drifter001 is offline   Reply With Quote
Old 05-10-2013, 06:30 PM   #89
S1CkWrx
Member#: 325249
2012 wrx
dgm
ditto^
S1CkWrx is offline   Reply With Quote
Old 08-28-2013, 04:24 PM   #90
othon
Member#: 18440
2004 WRX Wagon
Always need moar grip!
OP? Any rubbing on the fabric from the tires when the suspension compresses? That would be the only thing I could see being a real issue.
othon is offline   Reply With Quote
Old 08-28-2013, 06:14 PM   #91
vicious_fishes
Member#: 158864
2003 SOHC destroker
another +1 for buying them. i'd happily give you $50 (that's nearly a 100% markup without factoring in labour right?)
Old 08-28-2013, 08:41 PM   #92
tinkwithanr
Member#: 360865
Very well done! I've though about something like this in the past but never got around to making it. I'll definitely have to get some from you when I get around to setting up the suspension.
Thanks for sharing it.
tinkwithanr is offline   Reply With Quote
Old 08-29-2013, 12:08 PM   #93
teiva-boy
Member#: 22825
Buy proper offset wheels, problem solved
teiva-boy is offline   Reply With Quote
Old 08-29-2013, 12:21 PM   #94
othon
Member#: 18440
2004 WRX Wagon
LOL well yes that would be best. I was imagining that under some compression situations (e.g Hard cornering) that the material would bunch up from being compressed with the shortening of the suspension, which would push out the material making it touch/rub on the wheel or tire...no worries no that big of a deal, if it did and it rubbed a whole? Make new one, right? of course.
Old 09-02-2013, 01:37 PM   #95
Rferone
Member#: 364466
Kick A$$!!! I am getting ready to order my coilovers and was about to not order them since winter is coming up here quick in NJ, and I would hate to have them rust out like they typically. Awesome follow up as well by showing how effective this was a year later even after going through many washes and cleaning.
I know I couldn't make them, but my girlfriend is good with the sewing machine I can bribe her with a nice dinner!
Rferone is offline   Reply With Quote
Old 04-24-2014, 03:32 PM   #96
Jive Turkey
Member#: 219492
make me a set with purple/yellow stitching to match KW's?
Jive Turkey is offline   Reply With Quote
Old 04-24-2014, 03:45 PM   #97
andrewkpt
Member#: 387700
2002 wrx/sti clone
platinum silver
So you making these for ppl or what ?
andrewkpt is offline   Reply With Quote
Old 07-30-2014, 05:55 PM   #98
jfindo884
Member#: 271977
SRP
I know it has been several months since this has been alive, but are you making these? I have a caliper ready for measurements and a paypal account itching to be used...
jfindo884 is offline   Reply With Quote
Old 07-30-2014, 06:29 PM   #99
Overland04
Member#: 293311
2013 FXT 6-Speed
Thank you all for the interest as I do plan to be making these in full production before winter. I ended up taking the year to concentrate on building my company and is now in full swing.
Once the covers are ready to be sold they will be on our website. Feel free to head on over to check the status on their availability. Looking forward to doing business with you all.
Cheers!
- Jason
www.overland-designs.com
Old 08-01-2014, 06:13 AM   #100
jfindo884
Member#: 271977
SRP
Can't wait!! I feel so awful driving back roads with my beautiful new Feals. Need some protection ad I'm not very good with a sewing machine lol
How do you protect your coilovers? subarutrent07 Brakes, Steering & Suspension 13 12-19-2010 06:44 AM
car cover 4 sale in so cal. protect your car from falling fireworks debris 949 Private 'For Sale' Classifieds 2 07-26-2005 06:42 PM
Do Not Call List For Your Cell Phone, Protect Your Rights! BrysImpreza Off-Topic 6 12-09-2004 10:47 AM
Protect your spoiler with your life!!! Fish General Forum Archive 22 01-19-2001 12:58 AM
