Welcome to the North American Subaru Impreza Owners Club Monday May 30, 2016
Old 10-24-2012, 03:36 AM   #1
mightymints
Member#: 252858
2015 STi WRB/Gold LE
2013 WRB STi 5dr Stage1AP
Default How to: remove daytime running lights on a 2013 STi
Couldn't find a decent how to, so I snapped a couple of pics. Its really quite simple and I figured it out myself with the help of a few random posts.
1) Remove the two clips holding the intake scoop by unscrewing them slightly and then popping them out with your flat head. The scoop then just pulls out.
2) Next you are going to unclip the MAF sensor, and the two clips holding the airbox/ filter. At this point, split the box open and carefully remove the filter. You may want to clean or replace it while you are at this too.
3) After that, there is a bolt and a nut that needs removing. One is tucked under the left of the passenger fender, and the other down to the right of the airbox when facing it. After that, unscrew the hose clamp and work the tube off the box.
4)At this point it will be easier if you take the screw cap off the headlight on the interior. It just screws off by hand. Once that is off, unclip the tubing clipped onto the right side of the air box, and then go ahead and work the two half's of the air box out. The front half of it will have a bottle under it which you will have to work out with it. Once that is out, you can get to work on the cable.
5) You will see the two clips way down left under the light. Unclip the grey connector. Zip tie it away somewhere, i made sure to point the ends down just incase some moisture gets near it.
[b]And that's it, you are done. Just reverse steps 1-4 and you are good to go![/B
mightymints is offline   Reply With Quote
Old 10-24-2012, 12:27 PM   #2
iRaWr
Member#: 243008
2012 STi Limited
If you do this will you loose the use of your high beams?
iRaWr is offline   Reply With Quote
Old 10-24-2012, 01:17 PM   #3
WiechWRX
Member#: 249659
2012 WRX Limited
I just took off the little cover on the side of the bumper, you can see the module as soon as you remove it. and no it doesn't disable the highbeams!
WiechWRX is offline   Reply With Quote
Old 10-24-2012, 01:43 PM   #4
iRaWr
Member#: 243008
2012 STi Limited
Cool Thanks. Ill do this when i get to see my car again!
Old 10-24-2012, 02:39 PM   #5
Yeeman19
Member#: 8
Chapter/Region: HIIC
Ice Silver Metallic
I used this method as well. The vent will pop off when you slide it to the rear allowing easy access to the drl connection.
Yeeman19 is offline   Reply With Quote
Old 10-24-2012, 04:58 PM   #6
apkarian100
Member#: 207053
2013 XV Crosstrek
No. The high beams will still be functional.
apkarian100 is offline   Reply With Quote
Old 10-24-2012, 07:20 PM   #7
m1r4g3
Member#: 220476
2--> 06 STI & 12 Leg
WRB & SWP
but why remove drl's?
m1r4g3 is offline   Reply With Quote
Old 10-24-2012, 10:32 PM   #8
Kraakmo
Member#: 332518
2009 Impreza OBS 5mt
Silver on Silver
DRLs run your high beam at a lower wattage, hence the resister that they run through. This lower wattage can cause the filament to burn out faster. In addition, to some they look ugly.
Kraakmo is offline   Reply With Quote
Old 12-31-2012, 06:02 PM   #9
SchwanGizzard
Member#: 292614
I disabled my DTRL on my 2013 WRX a few days back. I went in from the bottom right in front of the passenger side tire. 2x plastic clips and 1x 10mm nut ( I I recall correctly). Bend the plastic down and everything is right there. Less than 5 min job, not including jacking up the car.
SchwanGizzard is offline   Reply With Quote
Old 01-01-2013, 01:32 AM   #10
Slurpyy08wrx
Member#: 256155
I just went from under the passenger splash gaurd by the end of the front bumper bent it down stuck arm in there in plugged and put splash guard back 2 min job haha on my 13 wrx.
Slurpyy08wrx is offline   Reply With Quote
Old 01-01-2013, 01:33 AM   #11
Slurpyy08wrx
Member#: 256155
Oh he already posted it I used that method on my 13 wrx takes 1-2 minutes.
Old 05-09-2013, 10:51 AM   #12
yswizzy19
Member#: 341421
2008 wrx sedan
wr blue
I removed this connector yet they still come on every time I put the key in. Any advice? I can't stand this feature
yswizzy19 is offline   Reply With Quote
Old 05-09-2013, 03:49 PM   #13
sobejoe
Member#: 298122
2011 WRX Sedan
I am really confussed by this "mod." But hey, everyone cant agree on everything. However, I will say nice post for those that dont (for some odd reason) like DRL...
sobejoe is offline   Reply With Quote
Old 05-10-2013, 12:56 AM   #14
neomax
Member#: 54585
2013 WRX
Going to be doing this tomorrow! Nice write up.
For those not getting why someone would do this, your headlights are a "wear" item. Why run them and wear them out faster then they need to? It's actually really nice to see the DRL fad starting to go away. Many new cars I'm noticing don't have them.
neomax is offline   Reply With Quote
Old 05-10-2013, 12:10 PM   #15
mrkyle3
Member#: 272675
2004 Miata
Nothing like getting rid of a safety feature that increases your visibility to other drivers.
Wear and tear? The bulbs are like $10 a piece and the wear is negligible because they are run at a much lower power for DRLs.
Old 05-10-2013, 12:16 PM   #16
Mr. G
Member#: 264069
2008 Impreza 2.5i
Dark Gray
^ Yeah, what he said. Doesn't seem like it's worth it; from a safety standpoint.
Mr. G is offline   Reply With Quote
Old 05-10-2013, 12:34 PM   #17
neomax
Member#: 54585
2013 WRX
haha no worries then! We can agree to disagree
Old 05-10-2013, 03:00 PM   #18
sobejoe
Member#: 298122
2011 WRX Sedan
So the only reason to do it is to safe life on the bulb? lol... like i neomax said --- agree to disagree
Old 05-10-2013, 03:10 PM   #19
JBK_Elements
Member#: 321239
The stock DRLs in my opinion are not very appealing. Need something that stands out a bit more
JBK_Elements is offline   Reply With Quote
Old 05-10-2013, 03:26 PM   #20
besthaticouldo
Member#: 279660
sorry, but i'll take the stock DRLs over your LED faux audi kit any day. not to be mean. the stock DRLs look good IMO. swap em out for a yellow noyka bulb. had mine for 2 years and never had a problem.
besthaticouldo is offline   Reply With Quote
Old 05-10-2013, 03:49 PM   #21
mattesonb
Member#: 139607
DGM Wrapped Satin Black
is it strange my11 wrx doesn't have the white jug under the air box?
mattesonb is offline   Reply With Quote
Old 05-10-2013, 04:04 PM   #22
cmiovino
Member#: 134005
2004 WRX Premium
That's the snorkel.. snorkus, whatever you want to call it.
Are you sure you're just not looking under the right plastic wheel well cover? It's hidden up in there.
If not, maybe the previous owner removed yours. It should be visible from the top if you open the airbox too... you'll see it through the hole.
Old 05-10-2013, 06:16 PM   #23
mattesonb
Member#: 139607
i purchased the car brand new, and there was definitely never anything there as the bottom where the snorkus would be is sealed
Old 05-10-2013, 06:44 PM   #24
Airplay355
Member#: 213825
2013 BRZ
I don't think the 11 had one.
Airplay355 is offline   Reply With Quote
Old 05-18-2013, 12:09 AM   #25
chris-man
Member#: 90572
2013 WRX STI
07 ninja ZX6R
does this step need to be done on the opposite side? or will unplugging the wire on the intake side disable both at once?
chris-man is offline   Reply With Quote
