Old 05-08-2013, 02:17 PM   #2401
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
I appreciate the help in advance.
Current set up:
2009 WRX with EPIC lowering springs (about a 1.2 inch drop)
17x8 wheels with winter tires 245/40/17
In the present I have absolutely no issues with rubbing
I just ordered a set up 18x9 Rota G forces with summer tires 245/40/18. My question is mainly this; I was in a small fender bender 3 weeks or so ago and the collision threw my alignment WAY off. To say the least they re-aligned the car and put it to factory specs.
I was planning on getting a new alignment with the rear camber adjusted -2 and the fronts adjusted to about -1.5. If I have this done do you foresee any issues with rubbing/knocking or should I be ok? The understanding I have is that if I leave the factory alignment and put on the new set-up I will for sure rub but if I have the alignment performed with the specs listed above I should not rub.
Any help/input is greatly appreciated
Super_HKS is offline   Reply With Quote
Old 05-08-2013, 02:50 PM   #2402
sc00by4life
Member#: 97135
You'll need some form of LCA or the whiteline bushing kit to gain the camber in the rear.
If you're rolled all around, and with the right camber, you *should* be ok if you aren't slammed.
Old 05-08-2013, 02:56 PM   #2403
Super_HKS
Member#: 154434
So I currently do not have my fenders rolled and I do not have a bushing kit so with that being said and done would this mean that my rear camber would essentially be set to 0? I am curious to see how much rubbing would actually occur.
Old 05-08-2013, 03:04 PM   #2404
Super_HKS
Member#: 154434
I found a guy that had the same set up on a sedan and he mentions light rubbing..
http://forums.nasioc.com/forums/show....php?t=2181370
Old 05-08-2013, 04:59 PM   #2405
prescottn6ft7
Member#: 268918
2002 WRX Wagon
You'll probably still need to roll the rear fenders. With springs and struts its hard to get the amount of camber you want in the rear too because strut / spring combos are so much wider in diameter than a coilover strut / spring. There's not as much room to angle the wheel.
prescottn6ft7 is offline   Reply With Quote
Old 05-08-2013, 07:18 PM   #2406
ViolentDecay
Member#: 355838
Still looking for advice.. 2004 Sedan, Ksport Kontrol Pro coilovers, 1" to 1.5" drop 2" max. Need to know if I could pull off 18x9.5 or just 18x9 and then what tire size would be good that doesn't involve stretching, unlike I said before. (I changed my mind, I'd rather not stretch on the tires for pothole reasons lol) Also I want to mention this is my first attempt at ever lowering any car, or attempting to stance it. New wrx owner, and I used to own a Jeep wrangler, that was easy... just lift it and most all wheels/tires fit. Going the other direction seems to be pretty complicated for someone like myself. Also I would need to figure out the offset for whichever selection is more convenient. I am willing to get my fenders professionally rolled/pulled.
Last edited by ViolentDecay; 05-08-2013 at 07:24 PM. Reason: coilover brand, left out Ksport.
ViolentDecay is offline   Reply With Quote
Old 05-08-2013, 09:30 PM   #2407
SubaruWrxNewb
Member#: 236017
04 STi with stock suspension besides some TEIN Coilovers. Interested in some wheels wider than the stock BBS, preferably 8.5 or 9. I'm not going any bigger than a 17. I would also like to fit some meaty tires on there. Would I have any trouble fitting 17x8 or 9 on it and what size tires could I run? I obviously have to make sure I pick a wheel that will clear my Brembos.
Thanks,
Ricky
SubaruWrxNewb is offline   Reply With Quote
Old 05-08-2013, 09:50 PM   #2408
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Then it's not really stock suspension...
Counterfit is offline   Reply With Quote
Old 05-08-2013, 10:05 PM   #2409
ViolentDecay
Member#: 355838
Okay so I've read for hours and I think I've narrowed it down to 18x9.5 +25, or 18x9 +25, 225/40/18, or 235/40/18. Ksport Kontrol Pro coilovers with a 1.5 - 2" drop, camber however much as needed and fender pull/rolls upon install. Thoughts? (looking for a meaty cambered look)
Old 05-08-2013, 10:18 PM   #2410
sc00by4life
Member#: 97135
k sports are garbage.
neither of those tires are going to be "meaty" or even close to it. Both of those will stretch pretty good on a 9.5" wheel. If you plan to roll/pull anyway, just get 255/35's or 265/35.
Honestly, for someone this new, these are NOT the fitments you should be looking at. Keep in mind that pulling is permanent and irreversible without a panel swap.
Old 05-08-2013, 11:07 PM   #2411
ViolentDecay
Member#: 355838
Thank you for your response and input scoob. I've heard good things about ksport from many of my friends whom have been doing this stuff for years. Everyone is different so can't really say anything about em unless you've tried em yourself.
Old 05-09-2013, 02:16 AM   #2412
sc00by4life
Member#: 97135
Its not like this forum has close to 400k members.
Old 05-09-2013, 07:02 AM   #2413
ViolentDecay
Member#: 355838
So you haven't tried them then? Why would you review them if not?
Old 05-09-2013, 09:34 AM   #2414
prescottn6ft7
Member#: 268918
2002 WRX Wagon
That offset is way wrong! On an 18x9.5 you should be looking for a +38 offset. Tire size either a 245/40 or 255/35
Old 05-09-2013, 09:38 AM   #2415
JourdanWithaU
Member#: 146287
2011 Impreza WRX 5D
That's the worst plan I have ever heard...
Way low offset wheels with ****ty coils and stretched tires for a "meaty cambered look"?
Are you trolling?
JourdanWithaU is offline   Reply With Quote
Old 05-09-2013, 11:18 AM   #2416
sc00by4life
Member#: 97135
Old 05-09-2013, 02:23 PM   #2417
rosedaleny806
Member#: 202070
2012 WRX GR LSB/Gold
2002 WRX GDB PSM
18x9.5 +20 with 235/40/18's on BC Type BR Coilovers
rosedaleny806 is offline   Reply With Quote
Old 05-09-2013, 06:43 PM   #2418
prescottn6ft7
Member#: 268918
2002 WRX Wagon
^ Looks great! Nice hatch! Tastefully modded.
Old 05-09-2013, 08:28 PM   #2419
rosedaleny806
Member#: 202070
2002 WRX GDB PSM
thank you!!
Old 05-10-2013, 01:46 PM   #2420
kracky
Member#: 353711
2002 WRX Wagon
Default Bugeye wagon
I am looking at running 18X7.5 ET 45
S.Drive 215X40R18
stock suspension (For now)
fenders will be rolled if needed.
After reading several post I really don't think this will need negative camber or fenders rolled?
Any thoughts?
kracky is offline   Reply With Quote
Old 05-10-2013, 02:31 PM   #2421
rosedaleny806
Member#: 202070
2002 WRX GDB PSM
thats a very width and offset. you wont need to roll or anything. especially at stock suspension
rears rolled for this 18x9.5 +20 all around with 235/40/18's
Old 05-10-2013, 02:37 PM   #2422
lcrazyaznl
Member#: 350014
14 Forester XT
Crystal Black Silica
^^ awesome car
saw it at the importgram meet
l
lcrazyaznl is offline   Reply With Quote
Old 05-10-2013, 02:38 PM   #2423
rosedaleny806
Member#: 202070
2002 WRX GDB PSM
oh thats awesome! thanks man! wish i had the wheels on for that meet
every friday i hold a meet in east meadow, NY if ur interested 90 merrick ave, east meado at 8 pm every friday.
Old 05-10-2013, 03:37 PM   #2424
sc00by4life
Member#: 97135
You have a very different car than OP.....
However, his fitment will fit just fine.
Old 05-10-2013, 03:39 PM   #2425
rosedaleny806
Member#: 202070
2002 WRX GDB PSM
well im assuming at 7.5 and +45 and stock height noone would have an issue lol
i jus posted my car after not as a comparison though lol
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
