Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 05-10-2013, 04:08 AM   #1
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Default 6266 powered 2011- 621whp VD
Ambient Temp/Conditions: 68 deg F, 19% Humidity, Baro 25.2in-Hg
Elevation: 4800ft
Weather: Sunny
Tires: Factory
Car: 2011 STi
Tuner: Elevated Tuning Will
Dyno Info: Virtual dyno
Transmission: Stock 6 Speed
Gear: 4th
Peak HP at RPM: 620 at 6752rpm
Peak Torque at RPM: 510 at 5962rpm
Target Boost: 31 psi
Target AFR: .78
Fuel: E85
Engine/Power Modifications:
ASF Street Sweeper Longblock
Bottom:
Darton Sleeves, 99.5mm JE FSR Pistons, Stock Nitrided Crank (ASF Balanced) Heavy But Beefy Manley I Beam Rods, ACL H Bearings, A1 Technologies H11 Studs, OEM Subaru Gaskets.
Top:
ASF Street Series Ported DAVCS Heads, Supertech STD Size Valves (Inconel Exhaust), ASF Multi Angle Into Radius Valve Job, GSC Beehive Kit, Kelford 220-C Cams.
Induction:
AMS/PTE 6266 Turbo Kit, AMS FMIC, FIC 2150 Injectors, Walbro 416lph, Invidia Exhaust, ASF TGV Delete, JC fabworks 1.5" manifold, Accessport on SD, Cobb EBCS
Hope to make it out to the track soon.
project_skyline is offline   Reply With Quote
Old 05-10-2013, 07:16 AM   #2
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Nice build and results! I love the shape of the power band, very nice!!
Old 05-10-2013, 09:30 AM   #3
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Great to see another successful PTE build! Looks a lot like mine except the sleeves and the mild cams. Power looks a little better than mine up top, but the peak torque is about 1,000rpm's later.
Old 05-10-2013, 09:41 AM   #4
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
I hate 6266 setups , great power for the elevation.
did you guys tried more boost? why not run more boost with a sleeved block? Is the pump hardwired? what FPR are you running?
Looks good, congrats
juanmedina is online now   Reply With Quote
Old 05-10-2013, 10:27 AM   #5
manitou
Member#: 193757
2006 XTI Limited
Yeah, maybe because of less aggressive timing and the cams.
Old 05-10-2013, 10:59 AM   #6
What v8
Member#: 254718
are you on stock fuel lines?
What v8 is offline   Reply With Quote
Old 05-10-2013, 12:47 PM   #7
stu
Member#: 25768
35R bugeye
Slowbaru
Nice setup, lets see some 35+ psi pulls. What CF do you guys use?
stu is online now   Reply With Quote
Old 05-10-2013, 04:47 PM   #8
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Stock fuel lines, hardwired pump. Pressure holds great.
The cobb seemed to have lost a lot of power and spool down low compared to the hallman and I don't see putting more WGDC to it because than during roll races it just over boosts. I'd rather just go back to a hallman.
I also observed no real gains past 31 psi. IMO the hotside has become a restriction for the displacement and ethanol fuel.
Old 05-10-2013, 04:51 PM   #9
juanmedina
Member#: 133146
07 FPgreen 7.37@95
The grimmspeed seemed to have lost a lot of power and spool down low compared to the hallman and I don't see putting more WGDC to it because than during roll races it just over boosts.
Are you running the stock FPR?
Really? PTE doesn't sell a bigger v-band hotside. Imagine their engineers think a bigger hotside is not need it. EVOs make high 700whp low 800whp with this turbo 2.4L.
Old 05-10-2013, 06:13 PM   #10
Murphdog
Member#: 75414
2004 STi
Its the Blue one
Do you know what you injector duty cycle was by any chance.
Murphdog is offline   Reply With Quote
Old 05-11-2013, 02:01 AM   #11
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Evo motors don't have several feet of exhaust piping pre-turbo either
907Bum is offline   Reply With Quote
Old 05-11-2013, 02:17 AM   #12
manitou
Member#: 193757
2006 XTI Limited
Yep, it's that VE thing. Not sure why most hear want to discount this factor and run all that piping, TS, added volume etc... then wonder why the HP tapers off?
Old 05-11-2013, 04:11 AM   #13
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Apples to oranges. You ever seen a subaru go 8's with a 6262? Exactly. Aftermarket regulator.
90% at 33 psi of boost and around 11.8 AFR
Old 05-12-2013, 05:27 PM   #14
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Stock base pressure?
