Old 05-11-2013, 01:19 AM   #2426
kracky
Member#: 353711
2002 WRX Wagon
Question Shagon wagon
[quote=rosedaleny806;39779748]thats a very width and offset. you wont need to roll or anything. especially at stock suspension
How about
225/40R18 S.Drives
18X7.5 ET45?
still stock suspension
kracky is offline   Reply With Quote
Old 05-11-2013, 08:16 AM   #2427
DUBYARX-R8D
Member#: 337691
2007 WRX
BLACK
just ordered a set of wheels, so looking for some opinions on the set up im working on, maybe some advice on doing something a lil different
year: 07
model: wrx tr
wheel model: xxr 527
wheel size: 18x8.75 +35
tire model: federal 595
tire size: 255/35/18
suspension: megan street series coilovers
alignment: N/A
fender mods: roll+pull all around
this is the set up i would like to have, just looking for any opinions or advice before i order tires, thanks in advance
DUBYARX-R8D is offline   Reply With Quote
Old 05-11-2013, 08:19 AM   #2428
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Why do people order wheels BEFORE asking for advice here? I don't get it.
Old 05-11-2013, 09:08 AM   #2429
kracky
Member#: 353711
2002 WRX Wagon
Talking asking first
Just to be clear, I am asking first! lol.
Old 05-11-2013, 12:06 PM   #2430
sc00by4life
Member#: 97135
Originally Posted by rosedaleny806 View Post
well im assuming at 7.5 and +45 and stock height noone would have an issue lol
i jus posted my car after not as a comparison though lol
you can add it to the post with pictures of your car already in it.
this isn't a picture thread or picture forum.
year: 07
model: wrx tr
alignment: N/A
255 federal is too wide for that wheel. 245/40 would be the widest I'd go, though ideally you'd want something with a smaller diameter.
you'll still need to roll and most likely pull.
Old 05-12-2013, 04:20 AM   #2431
kracky
Member#: 353711
2002 WRX Wagon
Does wheel width effect what offset you should run? Meaning, if I run a 7.5 with et 48 and want to go to a 8.5 should the offset change as well to keep from rubbing the strut? I have a wagon which already has limitations but want to run a larger wheel (both wider and taller). My plan is to run to a 225/40R18 (or 17) as long as I don't have to have neg camber or fender pull. If anyone running a bugeye wagon has some input it or does/don'ts it would be greatly appreciated.
Old 05-12-2013, 10:11 AM   #2432
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
Yes. In general, a wider wheel will require a lower offset. However, an 18x8.5 +48 will fit under a wagon with 225/40/18s with little issue. I ran a 235/35/18 (a little bit short sidewall, but wider tire) on an 18x8.5 +48 on my wagon and only had to roll the fenders because I was dropped at least 2" below stock. I ran -1.5* of negative camber up front and the rear was natural camber from lowering the car.
flat4LGT is offline   Reply With Quote
Old 05-12-2013, 07:31 PM   #2433
Derek23
Member#: 328250
2004 WRX
Alright I came across a really good deal so I'm just looking for some feed back and advice on my summer wheels I wanted to get. Tires and wheel fitment hasn't been my strongest subject
Year: 2004
model: WRX WAGON
Wheel model: BBS rs replicas
Wheel size: 17x10 +20
Tire Model: N/A
Tire Size : N/A
Suspension: Eibach lowering springs (2 inches)
alignment: Eibach camber bolts (uninstalled)
fender mods: plan on a roll and pull
I would assume I need a roll and pull, and I would install the camber bolts, what size tires would you guys recommend? Would I have to stretch the tires? I was hoping to avoid stretching. Thanks in advance
Derek23 is offline   Reply With Quote
Old 05-12-2013, 07:50 PM   #2434
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
You'll need a lot more work than is worth it, unless you're getting those wheels for free. Especially if you're new to the fitment game. If you want to avoid stretching tires, you're going to have to run a 245 or 255 which will not fit under a wagon without flares, especially with that offset.
Old 05-12-2013, 08:11 PM   #2435
Derek23
Member#: 328250
2004 WRX
What work would I need? I've read a couple people saying 17x10 wasnt too hard to fit. I pretty much am getting them for free through a straight trade. If it is a must I would do a minor stretch i guess
Old 05-12-2013, 08:15 PM   #2436
Counterfit
Member#: 124254
"The Scoobinator"
Was this person talking about a wagon? Because wagons have far less room for wide wheels.
Old 05-12-2013, 08:19 PM   #2437
Derek23
Member#: 328250
2004 WRX
its true they have less clearance but I've talked to people with 17x10s on their wagons
Old 05-12-2013, 08:23 PM   #2438
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
17x10s aren't horrible to fit on a sedan, but the wagon is 10mm (just under half an inch) narrower than the sedan. You'll need at least -2.5* to -3* of camber, and you aren't likely to be able to get that out of a camber bolt, so you'll need plates that run a couple hundred bucks. You'll need the fenders rolled flat and pulled and probably a 225ish tire that will have pretty significant stretch. I think FD7 is running 18x10s on a wagon, but I don't know the offset. Check into his set up to get a better idea of what you need to fit a 10" wide wheel.
Your answer is quoted below
Year: 2004
model: WRX WAGON
Old 05-12-2013, 08:37 PM   #2439
Derek23
Member#: 328250
2004 WRX
Thanks for the info flat4LGT! The camber bolts might get the job done I had them at 2.5 degrees before on a previous set up! Is stretching tires a must?
Old 05-12-2013, 08:41 PM   #2440
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
Pretty much. What it does is slant the sidewall so it clears the fender even if the wheels themselves poke past the fender. If the sidewall is squared up, it will rub as the suspension compresses, since the fenders curve in.
Like so:
If the sidewall was squared, the fenders wouldn't clear the tire.
Old 05-12-2013, 08:54 PM   #2441
Derek23
Member#: 328250
2004 WRX
Ahh, I get it now. Thanks that was a good explanation
Old 05-13-2013, 01:09 AM   #2442
sc00by4life
Member#: 97135
if you have no idea how difficult 10" wheels are to fit on a wagon, you probably should just walk away.
Old 05-13-2013, 09:22 AM   #2443
rosedaleny806
Member#: 202070
2012 WRX GR LSB/Gold
2002 WRX GDB PSM
18x9.5 +20 235/40/18
rosedaleny806 is offline   Reply With Quote
Old 05-13-2013, 11:09 AM   #2444
sc00by4life
Member#: 97135
This is the third post you've made with pictures.
Great. Good for you. This isn't a picture thread, or a picture forum.
While i do enjoy your car, one post is fine, but you don't need to keep posting pictures.
Old 05-13-2013, 11:10 AM   #2445
rosedaleny806
Member#: 202070
2002 WRX GDB PSM
so you cant post pictures to show fitment on a fitment thread...sounds legit. stop being all sandy vag, you dont like the pics move on, thats all.
Old 05-13-2013, 11:35 AM   #2446
sc00by4life
Member#: 97135
No, it's the fact that you are posting over an over.
Like I said. You have 2 previous posts already with pictures. This is not a "stance" thread, this isn't a "meaty" thread, it's a technical assistance thread.
Yes, pictures for reference are GREAT and encouraged, but this isn't the place to whore out pictures of your car.
Old 05-13-2013, 11:38 AM   #2447
rosedaleny806
Member#: 202070
2002 WRX GDB PSM
whoring out would be me posting every few posts, bc if you want me to "whore" out i can defiantly whore it out. yes this is a technical assistance thread, but without pictures noone will notice ****, i lowered my car more so anyone with a 11+wrx or 08+ sti can see how the set up is. like i said you dont like the pictures i post for ASSISTANCE in this thread you can go cry to someone who cares, bc i sure as hell dont
Old 05-13-2013, 11:41 AM   #2448
prescottn6ft7
Member#: 268918
2002 WRX Wagon
^ Agreed to an extent. No need to keep posting up pictures.
prescottn6ft7 is offline   Reply With Quote
Old 05-13-2013, 11:49 AM   #2449
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
The problem is that this doesn't tell us much of anything about your fitment. We need camber specs, suspension set up, etc. to know how it's fitting. Just saying you put the wheels and tires on that you did doesn't tell anyone how you made it fit.
I posted a picture yesterday to demonstrate what stretching tires and negative camber does to allow proper fitment, not to show off my fitment. 18x9.5 +38 with 235/35/18 tires on BC BR coilovers running -2.7* F/-2.9* R camber and all 4 corners rolled and pulled for those that care.
Old 05-13-2013, 11:51 AM   #2450
rosedaleny806
Member#: 202070
2002 WRX GDB PSM
i explained what suspension i was on a few days/last week when i posted in here for the first time. i explained my suspensions set up, my body mods that i had to do and thats it.
ill explain again...
rear fender rolled, fronts stock, BC type BR coilovers and natural camber from lowering still no adjustements to that but soon enough
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
