Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 05-13-2013, 01:52 PM   #1
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Default Precision PTE Turbo Results Thread
I'm seeing a lot of great results from the PTE turbos, so I figured a thread like this would be a good place to combine them all, and also open it up for discussion as well (currently spilling over multiple PPB and build threads).
Please start by making a post following the normal PPB template. Include plots, time slips, photos, videos, and links to your build threads if you would like. Whatever works for getting all the info about the setup and the results.
Template:
http://forums.nasioc.com/forums/show....php?t=1858764
Old 05-13-2013, 01:53 PM   #2
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Results List:
WHP / WTQ | 1/4 @ MPH | TURBO @ PSI | FUEL | VEHICLE | USERNAME | LINK
828 / XXX | XX.X @ XXX | 6765 @ 36psi | E85 | 2002 WRX | xdrian | LINK
700 / XXX | 10.1 @ 139 | 6765 @ 31psi | E85 | 2005 STI | OVeRBOOSTn | LINK
690 / 530 | 9.7 @ 143 | 6466 @ 32psi | E85 | 2005 STI | Crystal_Imprezav | LINK
670 / 594 | 10.2 @ 138 | 6466 @ 35psi | C16 | 2005 STI | JTPerryR1 | LINK
665 / 581 | XX.X @ XXX | 6466 @ 37psi | E85 | 2006 Spec B | 2.5gtbx_44 | LINK
645 / 508 | 10.1 @ 141 | 6265 @ 30psi | E85 | 2005 STI | Junior2JZ | LINK
635 / XXX | 10.1 @ 139 | FS635 @ 27psi | C16 | 2006 STI | P&L Motorsports Inc. | LINK
620 / 510 | XX.X @ XXX | 6266 @ 31psi | E85 | 2011 STI | project_skyline | LINK
613 / 614 | 10.4 @ 131 | 6266 @ 31psi | E90 | 2011 STI | baseballdbk1 | LINK
603 / 434 | XX.X @ XXX | 6266 @ 28psi | E85 | 2004 STI | ASF Machine | LINK
600+ / XX | 10.45 @ 138 | 6466 @ 26psi | E85 | 93 Impreza DKSMSHR | ASF Machine | LINK
588 / 471 | XX.X @ XXX | 6266 @ 28psi | 110 | 2007 STI | 05_wRex| LINK
576 / 530 | XX.X @ XXX | 6266 @ 29psi | E85 | 2011 WRX | xluben | LINK
570 / 486 | 10.9 @ 127 | 6262 @ 26psi | E85 | 2006 STI | banshee04 | LINK
562 / 425 | XX.X @ XXX | 6262 @ 28psi | E98 | 2005 STI | jakethesnaketimmons | LINK
551 / 441 | XX.X @ XXX | 6262 @ 30psi | 110 | 2002 WRX | robbieshonda | LINK
537 / 449 | XX.X @ XXX | 6262 @ 30psi | Meth | 2006 STI | Wicked Innovation | LINK
535 / 540 | XX.X @ XXX | 6766 @ 28psi | E85 | 2006 STI | Boosted Tuning | LINK
522 / 490 | XX.X @ XXX | 6266 @ 28psi | 93 | 2009 STI | No Limit Motorsport | LINK
500 / 480 | 10.7 @ 130 | 6262 @ 22psi | 93oct | 2005 STI | OVeRBOOSTn | LINK
482 / 450 | XX.X @ XXX | 5858 @ 28psi | METH | 2002 WRX | 02 wrx roar | LINK
478 / 355 | XX.X @ XXX | 6466 @ 20psi | 93 | 2004 STI | TheColorCute | LINK
473 / 432 | XX.X @ XXX | 5862 @ 27psi | 110 | 2007 STI | casperthekid | LINK
440 / 387 | XX.X @ XXX | 5857 @ 25psi | E85 | 2002 WRX | fastblueufo | LINK
410 / 352 | XX.X @ XXX | 6266 @ 21psi | 91 | 2004 STI | Wrx.CHRIS.Wrx | LINK
401 / 363 | XX.X @ XXX | 6262 @ 21psi | 93 | 2007 STI | expo9091 | LINK
400 / 364 | XX.X @ XXX | 5858 @ 22psi | 93 | 2004 STI | 06rexLTD | LINK
400 / 325 | XX.X @ XXX | 5858 @ 17psi | E85 | 2013 BRZ | maperformance | LINK
340 / 360 | XX.X @ XXX | 5858 @ 18psi | METH | 1996 GF8 | onurba32 | LINK
322 / 254 | XX.X @ XXX | 4854 @ 11psi | 93 | 2013 BRZ | maperformance | LINK
XXX / XXX | 9.9 @ 139 | 6765 @ 34psi | E85 | 2004 STI | vangstaboi86 | LINK
XXX / XXX | 10.7 @ 140 | 6466 @ 29psi | E85 | 2012 STI | Junior2JZ | LINK
XXX / XXX | 10.7 @ 129 | 5858 @ 28psi | E85 | 2005 STI | msp05sti | LINK
XXX / XXX | XX.X @ XXX | 6466 @ ??psi | E85 | 2007 WRX | juanmedina | LINK
Old 05-13-2013, 01:54 PM   #3
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
NF Performance Project Dark Knight
Event: Road Dyno Pull
Ambient Temp: 35F Outside
Elevation: ~1,000ft
Weather: Sunny and Cool Outside
Car: 2011 WRX Hatch
Tuner: Nuke @ NF Performance
Tuning Software: COBB AP Speed Density
Dyno Info: Virtual Dyno - Dynojet
Transmission: 2011 STI 6 Speed
Gear: 4th
Peak HP at RPM: 576 WHP @ 6,400 RPM
Peak Torque at RPM: 530 WTQ @ 4,948 RPM
Baseline hp/tq for a stock on same dyno: ~240WHP Stock
Target Boost: 29psi
Target AFR: 12's
Fuel: E85
Engine/Power Modifications:
  • 703 Casting Case Halves
  • Manley Turbo Tuff Rods
  • Manley Coated Pistons
  • Stock Subaru Crank
  • ACL Race Bearings
  • Balanced Rotating Assembly
  • MAP H11 Head Studs
  • TGV Deletes
  • FujiK of NF Performance Head Porting
  • GSC Beehive Springs
  • Stock Valves
  • Stock Cams
Intake/Exhaust/Fuel:
  • PTE 6266 V-Band Journal Bearing Turbo
  • Fobia Twin Scroll Header
  • Fobia Rotated 1.5 Scroll V-Band Uppipe
  • Fobia Rotated 3" V-BandDownpipe
  • Fobia Rotated 4" Intake
  • Fobia Rotated/SD FMIC Piping
  • TurboSmart HyperGate 45mm EWG
  • TurboSmart RacePort 50mm BOV
  • COBB 3" Cat Back Exhaust
  • FMS FMIC w/GS Thermal Coating
  • GrimmSpeed MBC
  • Walbro 465 Fuel Pump Hardwired
  • FiveO Motorsports 1600cc Injectors
  • Fuelab FPR at 55psi
  • COBB AP Speed Density Tune
Driveline Modifications:
  • 2011 STI 6 Speed Transmission
  • Spec B High Speed 5th and 6th Gears
  • ACT XT Pressure Plate
  • ACT Unsprung 6 Puck Disc
  • Kartboy/TiC Super Shift Set
More info on the car here:
http://forums.nasioc.com/forums/show....php?t=2078765
Here is the plot:
My last setup was a 20G XTR that made about 100WHP less than this. It was a really fun setup, but this completely blows it away! The top end of the powerband is so much stronger. It just pulls, and pulls! Nuke has been tuning in the 27-29psi range and it's been making 560-580WHP on Virtual Dyno. It is a lot of fun!
It does spool later than the 20G XTR (obviously), but the low end powerband really isn't that bad. I think it's perfectly fine for street driven, daily use. You can't mash the pedal in a high gear, but it feels plenty peppy just getting up to speed. It hits 20psi by around 4k rpm's with the 07+ STI 4th gear. A little later in 3rd.
Pictures:
Video:
Old 05-13-2013, 02:27 PM   #4
xsblack
Member#: 26530
2004 Sti
JBP
Started one a few years back
http://forums.nasioc.com/forums/show....php?t=2006685
Some good info in there
xsblack is offline   Reply With Quote
Old 05-13-2013, 02:53 PM   #5
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Dang. I totally missed that. I think it must have been because "PTE" wasn't in the title, or I just suck at searching. I'm open to input on which thread to keep around. If people want this thread, I am happy to compile a list for the second post. Otherwise I can just post in the other thread.
Old 05-13-2013, 04:09 PM   #6
reid-o
Member#: 103631
2004 STI
Pte has really come a long way. I remember in my DSM days that they were bearing killers. It's good to see then get qc under control
Old 05-13-2013, 04:22 PM   #7
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Here are some. Working on more and a better format. There are a lot!
??? / ??? | XX.X @ XXX | 6466 @ ??psi | E85 | 2007 WRX | juanmedina | LINK
620 / 510 - 6266 @ 31psi on E85: http://forums.nasioc.com/forums/show....php?t=2503772
535 / 540 - 6766 @ 28psi on E85: http://forums.nasioc.com/forums/show....php?t=2492537
828 / ??? - 6765 @ 36psi on E85: http://forums.nasioc.com/forums/show....php?t=2420002
700 / ??? - 6765 @ 31psi on E85: http://forums.nasioc.com/forums/show....php?t=1968767
576 / 530 - 6266 @ 29psi on E85: http://forums.nasioc.com/forums/show....php?t=2484865
Old 05-13-2013, 05:20 PM   #8
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
The first on on the list is a 6266...
Old 05-13-2013, 06:22 PM   #9
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
that mikey tuned LGT needs to get into here, as does the 6765 and 5858 NF cars!
Old 05-13-2013, 06:33 PM   #10
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Oops. Got confused because it's AMS spec. lol.
Yeah, those JTPerry and more I'm sure. That was pretty much just the first page. I need to reformat the list to have 1/4 mile info as well.
Old 05-13-2013, 07:00 PM   #11
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Don't forget Layvon's 6262. I think his thread is 2004 STI EFR 7670. He obviously did not use the BW turbo. http://forums.nasioc.com/forums/show....php?t=2268987
Old 05-13-2013, 07:03 PM   #12
manitou
Member#: 193757
2006 XTI Limited
There's the guy in NE with A 5858 I think CJ. Military guy.
Old 05-13-2013, 07:19 PM   #13
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
PTE 6265 [email protected] 34psi e85
http://forums.nasioc.com/forums/show....php?t=2239198
PTE FS635 ( 62 PTE Billet 35r hotside ) [email protected] 27psi C16
http://forums.nasioc.com/forums/show....php?t=2073328
Old 05-13-2013, 08:11 PM   #14
05_wRex
Member#: 170097
2007 WRX STi PTE6266
Sweet. I should have updated numbers in a couple weeks.
05_wRex is offline   Reply With Quote
Old 05-13-2013, 08:35 PM   #15
juanmedina
Member#: 133146
damn! I have to beat that 535...
Old 05-13-2013, 08:42 PM   #16
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
http://forums.nasioc.com/forums/show....php?t=2073328[/quote]
Jr, I need to know more about how you all ran the PTE with the 35R housing, can you share?
gotsugg is offline   Reply With Quote
Old 05-14-2013, 09:32 AM   #17
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Any info on the "smaller" sized PTE's? Mainly the 5431 and 5557?
Subian is offline   Reply With Quote
Old 05-14-2013, 10:25 AM   #18
xsblack
Member#: 26530
2004 Sti
JBP
I want a 5858 with a Fobia twin scroll manifold.
Anyone run anything similar to that??? If so post up results!!
Old 05-14-2013, 10:38 AM   #19
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I think this is going to be the closest:
http://forums.nasioc.com/forums/show....php?t=2411326
It's a 5858 with a Fobia rotated setup, but it's a single scroll v-band.
Old 05-14-2013, 11:18 AM   #20
xsblack
Member#: 26530
2004 Sti
JBP
Very impressive for stock heads/cams. It would be interesting to see how a twin scroll manifold and a ball bearing turbo would increase area under the curve. Regardless 10.7 @ 130 is moving!
Old 05-14-2013, 12:05 PM   #21
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Added.
Can you post a link to the current setup and results?
Added.
Send me your numbers!
Sorry, didn't see any of those yet.
Here's the updated list so far. Starting to get into the older posts that don't have all the info in the first post so it's a bit harder...
Results List:
700 / XXX | 10.7 @ 130 | 6765 @ 31psi | E85 | 2004 STI | OVeRBOOSTn | LINK
Old 05-14-2013, 12:23 PM   #22
manitou
Member#: 193757
2006 XTI Limited
Added.
I think I did post Layvon's there.
Old 05-14-2013, 12:31 PM   #23
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
I looked at the first page and the last page and I didn't see anything except a parts list. Link me to a post with power, torque, boost, 1/4 mile, etc.
Old 05-14-2013, 05:17 PM   #24
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
If you want to fix Overboostins
Same car 2 different setups in that thread.
Old 05-14-2013, 05:19 PM   #25
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Jr, I need to know more about how you all ran the PTE with the 35R housing, can you share?[/quote]
It is a 35r cartridge with PTE billet compressor wheel. I am not sure but its either the 62 or 64 wheel. IT has a 1.06 hot side.
It is on my old wagon now, makes 500whp on dynojet on 93octane. Trapped 129mph like that as well
