Old 05-09-2013, 02:40 PM   #1926
flk
Member#: 280838
2016 S4/GT4
^It has nothing to do with 19's. They are fine. My 18's with tires sticks out more than your setup will and I have a minor roll in the rear. I'm lowered on bilsteins and blacks. How much fender adjusting you need will depend on your camber settings, stiffness and height.
flk is online now   Reply With Quote
Old 05-09-2013, 03:26 PM   #1927
Scnsaracer
Member#: 319511
2013 STI Sedan
Ice Silver Metallic
Originally Posted by Maritzay View Post
Hey guys I'm picking up a set of evo bbs wheels.
They are 8.5 with an offset of +38. Will I need to do any fender rolling if I want to run rce yellows? They drop the car between 10-15mm.
Also what tire size do you recommend? I was thinking about ordering a set of DWs in 255/35/18
Depending on the specific tire you select you might need a slight roll in the rear
Scnsaracer is offline   Reply With Quote
Old 05-09-2013, 07:02 PM   #1928
NWsoobie
Member#: 289516
ISM
If you do not own an STi, you will need adapters to run those. They are 5x114.3.
NWsoobie is offline   Reply With Quote
Old 05-09-2013, 07:15 PM   #1929
dylanisco0l
Member#: 347674
2013 wrx
blue pearl
sticking with the stock wheel (2013 wrx) what's the best performance tire size but also a good daily driver (getting the michelin PSS) 2xx/xx/17
dylanisco0l is offline   Reply With Quote
Old 05-09-2013, 11:50 PM   #1930
NWsoobie
Member#: 289516
ISM
Maybe a 245/40? Or just stick with the factory 235/45's.
Old 05-10-2013, 12:50 AM   #1931
flk
Member#: 280838
2016 S4/GT4
The PSS runs wider per spec and the shoulder is more square. I've also had the PS2 and that is the same. So, keeping that in mind i'd do stock size or 255/40R17.
Old 05-10-2013, 02:47 AM   #1932
dylanisco0l
Member#: 347674
2013 wrx
blue pearl
255/40 over 245/40?
Old 05-10-2013, 02:50 AM   #1933
sc00by4life
Member#: 97135
255/40 over 245/40?
245/40 would be the widest I would go on an 8" wheel. If its a wider fitting tire like a Z2 or RSR, I'd be getting a 235/40.
Old 05-11-2013, 05:17 AM   #1934
GrumpyPitbull
Member#: 313311
Originally Posted by foolycooly View Post
A bit of a different question:
I'm picking up a set of used 245/40/17 star specs and am going to grab some cheaper drag wheels to have as a dedicated autocross set. I know i'll need an 8" wheel, but my choices in offset in the style I'm looking at are +47 and +35. I wouldn't anticipate having fitment issues with either of these offsets on my stock suspension, but can anyone provide a recommendation from an aesthetic/performance standpoint?
Thanks.
Star specs run wide, so I would personally run a 9 inch wheel with 245's, but that is purely preference.
As for fitment, I just mounted up some BFGoodrich Sport Comp 2's in 245/40/17, on 17x9 +35 RPF1's. These tires run wide, and are very square like the Star Specs.
So far after about 100 miles I have no rubbing, and my fenders are not rolled (also stock suspension). To be honest, after I mounted them I thought I would have to roll based on how far they stuck out .. but I think the smaller overall diameter is what saved me. I think if I was lowered at all I would need to roll the rears though.
Regarding aesthetics .. that is all preference really. The +35's look about the same as Delphi's car in post #1918 (the WRB with white wheels).
Old 05-11-2013, 10:56 AM   #1935
deanwrx
Member#: 188997
2007 STI
fyi: the Michelin PSS does not come in a 255/40/17, only 245/40/17. And the 245/40/17 PSS is a slightly narrow 245. I've seen it on 17x9 and it looks too small (sidewalls where not square, they were rounded). According to TireRack, the tread width is 8.5" vs the Dunlop Z2 9.2" I'm not saying its a tiny-ass tire, but it certainly doesn't run wide (PSS in other sizes might).
255/40 over 245/40?
deanwrx is offline   Reply With Quote
Old 05-13-2013, 01:59 PM   #1936
foolycooly
Member#: 260545
2011 WRX Limited 4dr
I had seen much wider tires on 8" wheels for autocross so I figured I would be ok. I'm not sure going 9" would gain me much in pure autox performance, but we will see. Obviously my stockers are 17x8 and the stock dunlops are 235 so I'm not sure I will notice a dramatic difference in feel while on the course (other than grip).
I went with the +47. I can throw some pictures up here once I get them mounted for reference. The aesthetic comment I made was sort of silly--I'm not really concerned about that since these won't see any daily driving duty.
Thanks.
foolycooly is offline   Reply With Quote
Old 05-13-2013, 03:40 PM   #1937
dylanisco0l
Member#: 347674
2013 wrx
blue pearl
Prodrive GT1 18x7.5 +53 offset, what tire size for michelin PSS 2xx/xx/18
Old 05-13-2013, 06:18 PM   #1938
Mach V Dan
Member#: 12029
One more question, tad off topic. Trying to find some gold rims (bbs gold), that look as close as possible to the look and color as the 2011-2013 OE wrx rims or the sti. Closest i can find is the Prodrive GT1, anyone know of any others? also needs the 5x100 bolt on size.
This question is not topical to this thread. You've asked this question in another thread. Please refrain from discussing topics other than WHEEL FITMENT in this thread. It's a long-enough read as it is.
--Dan
Mach V
FastWRX.com
Old 05-13-2013, 08:23 PM   #1939
NWsoobie
Member#: 289516
ISM
Here is my 12' sedan with 18x9.5 35 xxr 531's with 235/40 Toyo Proxies 4+. Fits real good. I will bring her down about an inch more. Should be good.
Old 05-16-2013, 12:32 PM   #1940
Mach V Dan
Member#: 12029
225/40R18. You really want to go with a narrower wheel and tire than stock?
Nice pic. Got more photos?
--Dan
Mach V
FastWRX.com
Old 05-16-2013, 03:40 PM   #1941
theEZV
Member#: 324205
2014 335i; 2016
Crosstrek; 2013 WRX(sold)
When you guys talk about some tires running wider than others, should we use tread width to compare? What is generally considered to run wider than most others? PSS?
theEZV is offline   Reply With Quote
Old 05-16-2013, 04:36 PM   #1942
sc00by4life
Member#: 97135
Pss is typically either right on, or slightly narrower depending on size.
You want to find the ACTUAL section width measurements. You can typically find these on tire manufacturers websites.
Old 05-16-2013, 04:45 PM   #1943
dylanisco0l
Member#: 347674
2013 wrx
blue pearl
--Dan
Mach V
FastWRX.com
can't find any other good looking rims. id like to find some 245or255/40/18s but with the look im going for i seem to be very limited.
Old 05-16-2013, 05:13 PM   #1944
NWsoobie
Member#: 289516
ISM
--Dan
Mach V
FastWRX.com
Thanks. Yes. Here are a few more. I'm debating going a bit lower. Thoughts?
Old 05-16-2013, 05:21 PM   #1945
dylanisco0l
Member#: 347674
2013 wrx
blue pearl
so to keep performance and the look i want it'd probably be best to powder coat the stock wheels and get 245/40/17 PSS tires instead of the GT1 which go down to 225
Old 05-16-2013, 05:30 PM   #1946
jonnyteix07
Member#: 246071
2010 impreza 2.5i
white
I am running 18x9 +35 fast hayukas with 265/35/18 cooper zeon 2xs on my 2011 wrx..on stock suspension...had quite a bit of rubbing in the rear..rolled my fenders pretty aggresively..
jonnyteix07 is offline   Reply With Quote
Old 05-16-2013, 08:08 PM   #1947
jlundy11
Member#: 324709
2012 WRX Sedan
I see a lot of people recommending the 235/40r17 245/40r17 and 255/40r17 for the WRX's (5-speed). Do the high revs at highway speeds (75 mph) not bother any of you? Or are these your track/auto-x only setups? I have 255/40r17's and I want to go taller to reduce the rpms a bit. Going approximately 75mph in 5th gear leaves RPM's around 3k. Seems high to me
jlundy11 is offline   Reply With Quote
Old 05-16-2013, 08:48 PM   #1948
NWsoobie
Member#: 289516
ISM
Pics!!!
Old 05-16-2013, 08:55 PM   #1949
NWsoobie
Member#: 289516
ISM
Not sure why a 40series tire would be recommended when our car comes with 45's. I could see if you were going super low, or if your increasing your wheel diameter. Other than that, I would stay with a 235/45 unless your going to a 9"+ wide wheel. If my math is right.
Old 05-18-2013, 09:10 PM   #1950
13scooby
Member#: 352942
heres mine
Stock Dunlop 235/45/17's
xxr 527 17x8.25
+35
stock alignment
no drop
no rubbing issues even fully loaded.
13scooby is offline   Reply With Quote
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 01:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 10:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 05:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 02:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 03:20 PM
