Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 05-09-2013, 09:28 PM   #1051
FireDaugs
Member#: 203747
2006 Baja Turbo
Originally Posted by JubaggWRX22 View Post
Just purchased my first baja
5speed manual turbo
Which Rally Armour mud flap application did you use???
FireDaugs is offline   Reply With Quote
Old 05-09-2013, 10:41 PM   #1052
JubaggWRX22
Member#: 318904
2002 WRX/05TurboBaja
Aspen/Satin White
They are actually off of my 07 wrx that I sold. Not all the bolts were direct bolt on but I made it work with custom holes. The fronts are way easy, the back set are just a little difficult with finding the right placement.
JubaggWRX22 is offline   Reply With Quote
Old 05-09-2013, 10:43 PM   #1053
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Go to freightliner parts. A 24x36 mudflap is 11 bucks. The material is better than any "Kit" you can currently buy. DIY!!
2.5 turbo hyped is offline   Reply With Quote
Old 05-11-2013, 10:11 PM   #1054
Ahzlon
Member#: 45216
2005 Baja Turbo
HAHAh I did the same thing, but I have a freightliner dealer near my house. Plus I'm there on occasion with my works Freightliner. I built my own mudflaps out of them.
Ahzlon is offline   Reply With Quote
Old 05-13-2013, 11:40 PM   #1055
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
Got tired of my gauge pod on the dash after a week... so decided to get the dremel out
And then my AFR gauge in the left vent.
JungleFevre is offline   Reply With Quote
Old 05-17-2013, 08:56 PM   #1056
1dweeb
Member#: 135470
In Texas you would miss the cold air from those air conditioning vents much more than the info from those gauges. But it does look slick.
1dweeb is offline   Reply With Quote
Old 05-17-2013, 09:06 PM   #1057
1dweeb
Member#: 135470
Originally Posted by WORunner View Post
Here is the interior of my baja, it's obviously still a work in progress. The gray plastic was scratched up all over, so i replaced it.
The interior so far:
Steering wheel-- LL Bean Legacy
Airbag -- WRX
Shift knob-- 07 WRX knob
Shifter boot-- redline goods
Wood grain parts-- Outback limited
Future plans for the interior
Leather swap out of a legacy (to include doorcards) and vinyl dye of the gray pieces to black.
Black carpet (dyed)
Black headliner
This is unique. I have been thinking of ordering the carbon fiber trim pieces but I am not sure what color to go with yet.
Old 05-18-2013, 09:06 AM   #1058
WORunner
Member#: 197327
2015 WRX STI
Lightning Red
You have the same radio i had in my last subaru, and the same music, as well, haha. 12 Stones.
WORunner is offline   Reply With Quote
Old 05-18-2013, 11:19 PM   #1059
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
It still blows just as strong as before (actually feels stronger because the air is more pressurized coming out less area), just no left/right adjusting.
Old 08-28-2013, 09:44 AM   #1060
Patrikman
Member#: 234499
2004 Outbrat XT
Regatta Red/Silverstone
Airbag -- WRX
Black carpet (dyed)
Black headliner
How do the Outback Limited pieces fit? I would like to have the upper cupholder in my Baja for extra storage.
Patrikman is offline   Reply With Quote
Old 09-04-2013, 12:21 PM   #1061
WORunner
Member#: 197327
2015 WRX STI
Lightning Red
I'm not 100% on the upper cupholder, I've got later woodgrain parts on there (2004). Fitment on all of it was perfect. I'd say pull your radio bezel and see if there is a pocket behind it to hold the upper cupholder.
Old 11-19-2013, 01:40 PM   #1062
Patrikman
Member#: 234499
2004 Outbrat XT
I'll check on it when I find a T harness for a factory sub. I've got to find the trim piece undestroyed at a junkyard first.
Old 11-22-2013, 08:41 AM   #1063
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Default Heated corbeau lg1 seats using OEM switches
I ordered these from Corbeau on Saturday and they arrived on Wednesday. I had them install the seat heaters in the seats and I used the included wiring harness with the OEM subie switches. They turned out awesome and work like they should.
Fabricating the brackets was time consuming but cost less than 20$ in materials.
Old 11-22-2013, 03:48 PM   #1064
JLBaja
Member#: 137951
2006 Baja Turbo Blue
Phat Botti Tuned
Nice!! I'm looking to install seat heaters in my stock seats, but would like to use the OEM heater switches if possible or at least get a blank to replace the coin holder then install new switches that come with the kit. I can get the kit with the square dials instead of round.
Do you know the part number for the seat heater switches?
Do you know the dimensions and depth of the OEM switches?
http://www.ebay.com/itm/251004563025...84.m1423.l2648
JLBaja is offline   Reply With Quote
Old 11-23-2013, 04:57 PM   #1065
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Any legacy switches fit into the baja switches. The ones I got were out of a 96.
http://www.ebay.com/itm/221277859502...84.m1439.l2649
You need to look up the part number for the heater switch surround that replaces the coin holder in the center console.
Old 11-28-2013, 01:51 PM   #1066
JungleFevre
Member#: 260153
2005 Baja Turbo
5-Speed
My Baja recently underwent a heart transplant
Also wetsanded, baked, and clearcoated the headlights
Old 12-04-2013, 10:50 PM   #1067
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Proper use of the baja. Next up for me is the sti six speed conversion.
Old 12-04-2013, 10:52 PM   #1068
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Old 12-07-2013, 09:34 AM   #1069
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
What a Big difference from OEM lights. What i did with my lamps I installed Weather tech' s headlamp protector. I figured to do it because these lamps are hard to get. Good job!
Baja_Gernaut is offline   Reply With Quote
Old 12-07-2013, 10:48 AM   #1070
JLBaja
Member#: 137951
Phat Botti Tuned
Great job on the HID install. How about those WeatherTech floor mats?!?! Which part number did you buy and do they fit right?? WeatherTech says they don't have one that fits our Baja and was going to have to buy a Husky brand instead.
Old 12-10-2013, 01:18 PM   #1071
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
Buy the forester ones. They fit. I called weathertech about this. They did not add it to their website yet? 2005 forester ones fit like a glove.
Old 12-10-2013, 05:38 PM   #1072
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
I'm a big fan of weathertech floor mats. I have them installed in my Infinity and Sienna. They fit like a glove and they are worth every dime. Never thought forester mats would fit. Nice to know.
Old 12-10-2013, 05:46 PM   #1073
Benhart21
Member#: 149617
I would've bought them long ago if I knew that. I never did since the Legacy/Outback ones I saw had a cutout for the fuel door release. I have their floor liners in my 4Runner and they're great.
Benhart21 is online now   Reply With Quote
Old 12-10-2013, 08:47 PM   #1074
JLBaja
Member#: 137951
Phat Botti Tuned
After 2 "dustings", I was ready to place my order for the Husky. So, these will fit perfect? http://www.weathertech.com/subaru/20...er-digitalfit/
It looks like Husky uses the same damn stock picture for every part number floor mat...can't tell if it even looks like the WeatherTech.
Old 12-10-2013, 09:31 PM   #1075
2.5 turbo hyped
Member#: 158810
2005 STI and Baja
HELL YES!!!! The exact same ones I bought. The grey ones match the grey dash color really well. I called them when I test fitted them and told them they fit the baja perfectly and that they should add the baja fitment. I guess they did not care enough to get more business. The carpet hook even lines up to hold the mat in place on the drivers side.
I have a set of the black ones in my 05 STI.
I love my weathertech mats.
Up to date pics & mods edoublepo Member's Car Gallery 4 10-09-2006 08:48 PM
Modded PStwo (slim) & Modded Gamecube llhype12ll Private 'For Sale' Classifieds 2 11-15-2005 01:28 PM
couple of pics & mods list WRX Ver.7 Member's Car Gallery 15 08-01-2002 01:40 PM
How to change pics & mods? mav1c Mid Atlantic Impreza Club -- MAIC 6 08-28-2001 12:51 PM
STI 3 Pics & 340HP Mods Hyperex Member's Car Gallery 38 07-06-2001 06:20 PM
