Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 05-13-2013, 07:59 PM   #1
precisely3
Member#: 355824
2014 Impreza Sport
Crystal Black Silica
Angry Previous owner cut factory harness...
So I decided to look behind the crummy Sony Xplod head unit that's in my OBS and figure out if I needed to buy a harness to install my head unit, or if there was already one in there.
Well, surprise surprise, whoever installed it cut the factory harness and spliced directly into that from the head unit. Ugh.
Should I pick up a factory harness, reattach that, then attach my stereo to an adapter harness for the install? I'm assuming yes, but I'm just looking for someone to tell me yes/maybe play devil's advocate and provide reasons why I may want to stick with the botch job.
precisely3 is offline   Reply With Quote
Old 05-13-2013, 08:24 PM   #2
Guzzi 1
Member#: 338666
2014 Impreza Limited
SWP/Blk Leather CVT
Depending on how much would need to be replaced, that could be a boatload of work. If it were me, I would get the proper end from sVXdc who posts here on this board and put the factory connector back on the end of the wire. I would suggest doing a good solder job with shrink wrap. Then, moving forward from there, use his plugs to adapt whatever you desire from there.
Here: http://ae64.com/
Many here, including myself have purchased connectors from David. I would highly recommend his services.
John
Old 05-14-2013, 09:05 AM   #3
precisely3
Member#: 355824
2014 Impreza Sport
Yeah, I figured it would just be easier to get the harness in the dash all set back to normal first, so I know for sure that it would just be plug-and-play.
I wasn't aware that ae64 was a NASIOC member-run site, otherwise I would have ordered from there. I instead picked up a Scosche reverse harness at Best Buy for like $12 :-/
I kinda feel bad now, but if I need anything else in the future I'll be sure to support the community
Thanks for the reply!
Old 05-14-2013, 10:44 AM   #4
luan87us
Member#: 335013
2013 Premium WRX 5dr
Yeah you can just buy the reverse harness and splice it back into the current OEM harness. Then just get a forward harness if you need to install another aftermarket Hu.
