Old 09-04-2009, 11:55 PM   #251
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
I decided to do a brake swap and finally got around to fixing the sagging IC pipe shown in the pictures above.
Following Stimpy's thread on this subject... http://forums.nasioc.com/forums/show...ght=SVX+master I didn't like the spongy brake feel after the swap. I decided to swap in an SVX brake master cylinder and upgrade to 4/2 pot brakes and new rotors. While the brakes were ok, there was still too much brake pedal travel for my liking. The install was pretty straight forward and has been documented several times so I'll refrain from posting the details of the swap. Parts used were as follows:
4/2 pot brakes
eBay drilled and slotted rotors
2006 WRX pads (PBR / Axxis pads)
1991-1995 SVX Brake Master Cylinder
Kartboy rear brake caliper adapters
I did have to remove the rear dust shields due to the larger rotors. Some folks have drilled the spot welds (I did one this way - see pics), but I opted to use a small pry bar and channel locks and it worked fine. The master cylinder took a little over an hour to swap, but everything bolted up. I did have to splice the master cylinder wiring since the SVX clip was different than the '98L clip, but that was easy.
2 Pot Fronts:
Single Pot Rears:
Rear Dust Cover Removed:
Kartboy Adapter Brakets:
JDM 2 Pots Installed:
JDM 4 Pots Installed:
End Result:
Results:
After bedding the pads, I couldn't believe the difference! The brake travel has been significantly reduced with excellent braking. Thanks to Stimpy and Legacy777 for this mod. For those who have swapped rear disks from drums, have a single brake booster and no ABS, I'd highly recommend this mod.
beaviscih is offline   Reply With Quote
Old 09-06-2009, 09:57 PM   #252
beaviscih
Member#: 123362
'93 Crapcan, '98L
A few pictures after installing the HT Auto mini scoop, fixing the IC piping and installing the IC wrap.
Old 09-08-2009, 02:03 AM   #253
EsubaruJ
Member#: 200008
03 wrx
TE72 wagon, Legacy wagon
Originally Posted by scarless ronin View Post
i bought an EJ20G a few months back, and I have a '00 rs, I want to go full out like this on the car, but judging by how much time and new parts you've put into yours, I'll be broke before I get halfway done, especially with the mechanic bills... how much do you think you've put into it so far? (if you don't mind me asking) she looks beautiful by the way
You can do these swaps for very cheap. I am in to mine like 2,000, thats including the price of the car(Picked up a 93 L with 130K on the odo, great condition for $500), complete swap(2 ECU's[3b and z4] wiring harness, fmic with piping for reversed manifold[swap came with a reversed mani]) The swap was $750, picked up a td04(just until I get something bigger) for $50, 2.5 rs bumper grill and headlights for $140 total and a couple fixed back carbon fiber seats[traded one sparco fighter for the pair]. And a few more misc items like a clutch and axles. I will be in it about 3,000 by the end including the car. I think thats not bad at all.
EsubaruJ is offline   Reply With Quote
Old 09-08-2009, 02:04 AM   #254
EsubaruJ
Member#: 200008
03 wrx
PS. Your car looks great! Props on a very nicely done swap and car!
Old 09-11-2009, 12:05 AM   #255
krylon
Member#: 56761
9599 EJ255 EJ257 GC8
Rally Blues
Default Brakes look Great..
:::~Yummy RPF1's goldies..!~:::
Hows the snow down there..? I see you're all set with that ground clearance..!
krylon is offline   Reply With Quote
Old 09-11-2009, 12:13 AM   #256
krylon
Member#: 56761
Rally Blues
Well after several weeks without working on the car due to contracting Typhus - no joke, and it's some nasty stuff (my pet river rat turned on me and let his fleas attack me)
Dude... you have a river RAT as a pet...?? I'd like to see pics of that thing!
Any mods...?
Old 09-11-2009, 08:54 PM   #257
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Wow!
At the car and river rat.
Smoke is offline   Reply With Quote
Old 09-11-2009, 09:09 PM   #258
beaviscih
Member#: 123362
'93 Crapcan, '98L
Yea, I'm ready for the next 50 year snow event. We might hit freezing once or twice per year. While I'd prefer a little more drop, the more I drive the car the better I like the suspension set up. I have coilovers on my STi and it rides like it.
Any mods...?
No pet rat, but there are enough nasty critters in the area that typhus is pretty common. It's not a weight loss program I would recommend.
Old 09-17-2009, 04:37 PM   #259
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Baller!!!
Gr3en is offline   Reply With Quote
Old 09-17-2009, 06:36 PM   #260
beaviscih
Member#: 123362
'93 Crapcan, '98L
Thanks for the props.
Old 01-01-2010, 04:25 PM   #261
beaviscih
Member#: 123362
'93 Crapcan, '98L
Ouch - Hit-n-Run left the carnage. Some will buff out but other parts will need to be fixed or replaced.
I've bent the hood back as close to normal as possible, but I can't do much with the front part. The bumper will need a repaint and of course a new headlight. The grill survived, but I had to use a ratchet strap to pull the radiator support back about 1/2".
Old 01-03-2010, 02:49 PM   #262
K-Dizzle
Member#: 185365
2015 Forester 2.5i
Dude, I would seriously be fighting the intolerable need to commit homicide if that was my car and it was hit and run. Sorry to see this happened.
Im glad to see you got it on the road now tho. Looks great, congrats.
K-Dizzle is offline   Reply With Quote
Old 01-04-2010, 12:11 AM   #263
tony_0227
Member#: 177300
93 Subaru
Damn that sucks. But it could have been worse
tony_0227 is offline   Reply With Quote
Old 04-07-2010, 10:53 PM   #264
beaviscih
Member#: 123362
'93 Crapcan, '98L
The hood has been fixed. On to the next project. My half-hearted attempt to sell the Ver4 STi heads was, well, just that.
Sooo...While the car is running great, I managed to pick up a EJ205 with forged pistons and STi rods and have decided to mate the Ver4 STi heads to this guy.
I'll post some more pictures, but I've installed most of the bolt-on stuff (pulleys, 12mm JDM oil pump, water pump, STi pickup tube and oil pan. More to come.
Old 04-14-2010, 06:56 AM   #265
beaviscih
Member#: 123362
'93 Crapcan, '98L
Heads and misc. accessories bolted on. I still need to install the cam seals and torque the cam caps/cam covers.
Old 04-17-2010, 10:05 PM   #266
followmylead
Member#: 238875
05 sti
aspen
nice +1
followmylead is offline   Reply With Quote
Old 05-08-2013, 02:32 PM   #267
97 outback
Member#: 286935
97 Legacy Ouback
where did u find all of the info for the wiring?
97 outback is offline   Reply With Quote
Old 05-10-2013, 02:55 PM   #268
Gokart38
Member#: 313730
I like this build keep up the work
Gokart38 is offline   Reply With Quote
Old 05-14-2013, 10:44 PM   #269
beaviscih
Member#: 123362
'93 Crapcan, '98L
The FSM and Zephyr did the harness merger.
Old 02-23-2015, 06:12 AM   #270
SixPillar
Member#: 338072
Bump: I give you life. Awesome build.
SixPillar is offline   Reply With Quote
I want to tune my 1995 L GF8 2.2L AT OBDII Type2 Engine Management & Tuning 0 02-26-2009 04:06 PM
FS: '98L 2.2L Motor, 5MT and Rear Differential beaviscih TXIC Private Classifieds 0 12-06-2008 09:26 AM
2.2L to 2.5L swap? PyronAbyss Subaru Conversions 11 03-14-2006 03:12 PM
2.2L to 2.5L will this work ? PumpsGOTAWD Normally Aspirated Powertrain 6 04-24-2005 11:49 PM
How much to mod 2.2L to =2.5L hp OSUBeaver Normally Aspirated Powertrain 27 03-26-2003 11:21 PM
