Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 05-09-2013, 09:25 AM   #1
2000subie
Member#: 207638
2004 WRX
Yellow
Default 04 wrx, built 2.slow, gt3076r,
Event: dyno pull
Ambient Temp: roughly 65f
Elevation: 5000'
Weather: cloudy and wet
Track and Conditions: na
Tires: 225/45/17 hoosier D.O.T drag radials
Car: year, model
Tuner: the awesome Harvey Epstein
Dyno Info: dyno dynamics
Transmission: 6spd stock gearset
Gear: 4th
Peak HP at RPM: 450awhp at 5900rpm corrected
Peak Torque at RPM: will have to check can't remember exact number around 360.
Baseline hp/tq for a stock on same dyno: 215 sti I believe
Target Boost: 23psi
Target AFR: 11.5
Fuel: e85
Engine/Power Modifications: New ej205 cases, New revised ej205 crank, ACL race rod and main bearings, crower I beam rods, mahle 8.5:1 pistons, mild port and polished heads, +1mm exhaust/intake valves, bc springs and retainers, kelford 280/278 camshafts, 18mm phenolic spacers, tgv deletes, p&p reversed intake manifold, turbo xs fmic, rotated Garrett gt3076r, pte 39mm ewg, uel header, 3" straight back exhaust, fic 1000cc injectors, walbro 255, aem fpr, aem ems, and more I'm forgetting right now.
Driveline Modifications: 05 6mt swap with r180, exedy twin disc clutch.
Suspension Modifications: tein H lowering springs, perrin rear sway bar.
Was shooting for 500whp, but the turbo maxed out way sooner than expected. Will be going bigger soon.
2000subie is online now   Reply With Quote
Old 05-09-2013, 09:28 AM   #2
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
Originally Posted by 2000subie View Post
Event: dyno pull
Elevation: 5000'
Car: year, model
Gear: 4th
Target Boost: 23psi
Target AFR: 11.5
Fuel: e85
I know I gave you no time, but we want a log, file, VD or outwise printout!
Cool to see a small stroke getting beat up on though!
Old 05-09-2013, 09:28 AM   #3
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Graph?
Old 05-09-2013, 10:09 AM   #4
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
What do u mean by the turbo maxed out sooner than expected? Your only running 23psi, thats nothing. You have e85. Crank the boost up to 26-28 and theres your 500whp? I dont understand the pump gas boost level when u have e85? Seems WAY conservative
Slimsti is offline   Reply With Quote
Old 05-09-2013, 10:11 AM   #5
2000subie
Member#: 207638
2004 WRX
Yellow
Will try and get the graph and stuff emailed from Harvey today. He gave me a print out, but his printer is on the way out. And you cant see it very well. Also don't know how to post files from a phone.
Old 05-09-2013, 10:18 AM   #6
mekilljoydammit
Member#: 258151
5000 foot altitude; ambient air pressures going to be around 12.2 psi instead of 14.7. So 23psi there is the same turbo pressure ratio as 28psi of boost at sea level would be.
mekilljoydammit is offline   Reply With Quote
Old 05-09-2013, 10:24 AM   #7
Slimsti
Member#: 155696
Ah i see. Damn thats crazy. lol. I had no clue. I just got schooled.
Old 05-11-2013, 08:06 PM   #8
shano
Member#: 223839
2004 WRX
Java black
Good power on a 2L @ 5000FT!
shano is offline   Reply With Quote
Old 05-11-2013, 08:45 PM   #9
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Any Dyno graphs or even VD?
west_minist is offline   Reply With Quote
Old 05-13-2013, 10:19 AM   #10
2000subie
Member#: 207638
2004 WRX
Yellow
Sorry guys, I'm still waiting on the graphs. Harvey is moving to a different shop, so he is busy. I will try and get some logs, and vd tonight. I'll also post up my ****y print out.
Old 05-14-2013, 11:50 PM   #11
LTZ_STI
Member#: 285936
04 WRB STI
02 WRB WRX
slooooooow as ****kkkkkkkk
LTZ_STI is offline   Reply With Quote
Old 05-20-2013, 10:02 PM   #12
2000subie
Member#: 207638
2004 WRX
Yellow
Updated op with the only dyno graph I have. Will get a vd as soon as I can, the car did trap 127mph yesterday. Very happy with the car this far!
Old 09-29-2013, 08:46 PM   #13
BOOSTBOX
Member#: 165415
New revised EJ205 Crank....Is this a specific part number from Subaru?
BOOSTBOX is offline   Reply With Quote
Old 09-29-2013, 09:01 PM   #14
2000subie
Member#: 207638
2004 WRX
Yellow
I believe it's the only 2.0 crank Subaru sells now, not 100% on that though.
Old 09-29-2013, 10:19 PM   #15
Lenny2005
Member#: 289657
2005 Subaru WRX STI
When u got bigger let me know. Im in the springs and id def be interested in the turbo setup
Lenny2005 is offline   Reply With Quote
Old 09-29-2013, 10:30 PM   #16
2000subie
Member#: 207638
2004 WRX
Yellow
I am actually in the process of going bigger, but the kit is going to a friend locally.
