Welcome to the North American Subaru Impreza Owners Club Saturday August 1, 2015
Old 05-08-2013, 05:16 PM   #7301
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
It just seems some people complain for the sake of complaining or put for the sake of making someone else feel dumb or lift themselves up above an electronic representation of a person.
No, I was actually confused about what the last numbers meant...there isn't any reason to be ugly about it.
Squidz is offline   Reply With Quote
Old 05-09-2013, 01:01 PM   #7302
Maxwell Power
Member#: 190729
I don't know you.
Your post lacked as much explanation as his. You just said it confused you. You didn't say what aspect. Don't point the attention at me for being "ugly" just because I was honest.
Old 05-09-2013, 02:56 PM   #7303
Squidz
Member#: 142608
2003 Sonic Yellow
You may not know me, but we have had plenty of interactions here on Nasioc...conversations seem to always end with you being 'honest' with someone about your opinions. You can be honest without being ugly.
Well, you can't.....but it is possible.
Old 05-09-2013, 03:48 PM   #7304
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
let's back on topic, if I want to watch telenovela I turn on Univision.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 05-09-2013, 04:14 PM   #7305
Maxwell Power
Member#: 190729
yeah yeah yeah, I'm the bad guy.
Old 05-15-2013, 01:25 AM   #7306
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
Originally Posted by 06rexwagon View Post
Little beat but not horrible. Worse than I would expect from under 3k miles.
Only map he has. This is from the old e70 tune that spun a rod bearing and bent all the wrist pins at around 4k miles.
Timing was increased for the e98 tune but I don't know by how much. The aem has been sent back to get checked.
Idle timing is strange
Important to note that this is a hybrid engine with oem gasket and Cnc head chambers. Not sure of cr.
E98 map has ~2* more than what you see here, and the knock sensor calibration table was left alone, just like aem sends it. The car always thought it was knocking because knock voltage exceeded the threshold even at idle. If there was ever a quiet moment of the knock sensor it could add back in up to 4.92*. They won't be tuning the car again.
06rexwagon is offline   Reply With Quote
Old 05-15-2013, 09:07 AM   #7307
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
jeeeez ^^. that entire table looks bad...and yeah just noticed the timing in the idle area lol. shoulda just made them all 18 and called it good
Old 05-15-2013, 08:24 PM   #7308
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Could hot weather cause E85 to lean out under WOT?
340Duster is offline   Reply With Quote
Old 05-15-2013, 08:54 PM   #7309
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
seasonal blends
Old 05-15-2013, 09:05 PM   #7310
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
if the ethanol content became higher like going from winter blend to summer blend but you should be able to log the same closed loop fuel adjustment and see how much more the + or - is even at an idle it should be affected between the winter(usually 70 to 75%E) and summer blend(82-88%E).
john 1badSTI is offline   Reply With Quote
Old 05-15-2013, 11:21 PM   #7311
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Thanks guys!
Old 05-16-2013, 04:12 AM   #7312
yamahaSHO
Member#: 73932
2005 STi - E85
2004 S2000 - E85
Although I agree with seasonal blends changing AFR's, but it might also be worth looking at your MAF Temp Compensation. They will also lean out as the weather gets warmer.
Old 05-16-2013, 01:39 PM   #7313
Squidz
Member#: 142608
2003 Sonic Yellow
^^ We had this problem with our Turbo LS-3 Camaro at school. Anyone know where this table is in the Accessport software?
Old 05-17-2013, 04:58 AM   #7314
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
It's the maf compensation (intake temp). the table is at the bottom of the list right above the throttle tables in the AP
Old 05-21-2013, 10:56 PM   #7315
2011WRXDAVE
Member#: 355249
2011 WRX Sedan
WRB E-85, 354WHP/386TQ
) Your injectors size-1000CC
2) Injector duty: ~70%
3) Elevation-sea: 800ft
4) Stock VF52
5) Fuel: Aeromotive 340 pump E-90
303WHP 333TQ on Mustang Dyno at 18.6 PSI
87 degree humid day for tune
2011WRXDAVE is offline   Reply With Quote
Old 05-28-2013, 05:22 PM   #7316
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
A friend linked me to this post over on FT-86 club. I guess they are having a big E85 eating fuel filters scare right now:
http://www.ft86club.com/forums/showthread.php?t=37706
I'm at 14,000 miles and over 1 year on straight E85 (E70) with no observed side effects. The BRZ/FRS fuel sump system doesn't look exactly like the one in the LGT & 08+ WRX/STi but its pretty similar in that the filter lives inside a sealed part of the pump housing. Its kind of annoying that is part cannot be checked or replaced (to my knowledge) without replacing the whole housing.
I suspect this incident is due to something other than E85 itself. I think it might be bad fuel or additives and there isn't much data besides one guy's pictures.
Has anyone with the plastic sump style pump housing ran issues any issues that could be related to E85?
I'm swapping in a Walbro 405 soon so I'll be inspecting my sump but I thought I see if anyone else has any feedback on this.
Old 05-28-2013, 05:33 PM   #7317
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
I don't think our cars have a filter like that on the return. Either that or I missed it. I have been straight E85 daily driven for over 2 years now and no issues. I've had my pump housing out several times. I know other local guys (08+) that have been longer too. Definitely something I've considered though. I will keep checking.
Old 05-28-2013, 05:53 PM   #7318
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
I was hoping you'd chime in so thanks for doing so. I wish I had taken the time to understand exactly how the sump system works when I had it out. You can see through the plastic that there is a filter inside the top half that houses the pump. It looks like a rolled paper filter like what's inside the pre 08 STi filter housing. I don't know if this is filter is just used for fuel being sucked into the sump or if the return line flows through this or not.
Old 05-28-2013, 06:02 PM   #7319
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
From what I remember the return does feed into that but not directly. The filter you're talking about is on the feed side. The return goes through a few hoses and valves and some portion of it makes it back into that section. Maybe someone else can explain better.
Old 05-28-2013, 06:46 PM   #7320
azn2nr
Member#: 35276
are 1600 cc injectors good for over 600 on e85 or do i need 2000+ to not run out of fuel?
s300sxfmw cobb cnc heads and kelford 199-c for reference.
azn2nr is offline   Reply With Quote
Old 05-28-2013, 06:49 PM   #7321
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
There are no 1600cc injectors worth owning. Sell and buy ID2000s.
Dont want to be a debbie downer but i dont want you waste time and money.
Should you choose to not take heed... 1600s will be adequate with proper pump
Old 05-28-2013, 06:52 PM   #7322
Maxwell Power
Member#: 190729
199-C is a little small for a 300sx don't you think?
Old 05-28-2013, 06:55 PM   #7323
azn2nr
Member#: 35276
in what way? kelford says they are good between 500-700 hp seeing as the s300 is rated to 700 i think ill be fine.
Old 05-28-2013, 06:56 PM   #7324
azn2nr
Member#: 35276
thanks, i was asking because a set of five-0 1600s came up for less than the price of one id2000
Old 05-28-2013, 06:57 PM   #7325
Maxwell Power
Member#: 190729
uh no.
199-C 264 Hot street cam, suits turbo upgrade. Fantastic street performance or track day camshaft. KVS109-STI 268 264 226 222 10.30mm 10.00mm 110 112
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 02:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 10:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 08:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 11:01 AM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 07:06 PM
