Old 09-15-2010, 05:09 PM   #1
1hotsubaru
Member#: 244748
2002 WRB Impreza WRX
"aka" NGRY REX
Default EJ207: US ECU or JDM ECU???
Hey guys, i have a question... I have read and read lots of info, and some ppl say u need the jdm ecu if u want to swap a ej207, or that u can reuse the stock USDM wrx(2002) ECU... is this true? and if it is, what r the differences???
1hotsubaru is offline   Reply With Quote
Old 09-15-2010, 05:21 PM   #2
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
Us ecu has no way to control the AVCS.
666stars is offline   Reply With Quote
Old 09-15-2010, 07:50 PM   #3
thebionicman
Member#: 247561
2011 TR-42S
I am pretty sure EJ207 V5/V6 don't have AVCS.
thebionicman is offline   Reply With Quote
Old 09-16-2010, 01:03 AM   #4
linuxbatm
Member#: 71292
Sedona Red Pearl
You can use either, but as said above the US ecu will not do AVCS. The ecu plugs right in and starts up, at least on a Bugeye WRX with the v7 motor.
linuxbatm is offline   Reply With Quote
Old 09-16-2010, 12:28 PM   #5
1hotsubaru
Member#: 244748
"aka" NGRY REX
oh alright i gotcha, and yeah i wanna get the early v7 engine, with the bigger ports, and i def want AVCS, so ill go with the jdm ecu! thxs
Old 09-16-2010, 01:53 PM   #6
shaggy-with scoobi
Member#: 207631
2002 XPT Stage 2 WRX
Fat Chicks love that ride
I believe the later V7 had the big port, but dont take it as gospel
shaggy-with scoobi is offline   Reply With Quote
Old 09-17-2010, 09:15 AM   #7
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You best be sure that V7 is a Spec C or STi Spec C model. Reg Ver7 STi's do not have large intake ports. All Ver8's do. However the small ports can be ported out to flow just as good or better if need to be.
Old 09-17-2010, 09:27 AM   #8
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Will a WRX ecu trigger a CEL if used with a JDM EJ207? Either because of avcs or because of a lack of TGV's?
garface is offline   Reply With Quote
Old 09-19-2010, 02:26 AM   #9
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Well.... it will trigger the TGV, but the AVCS is will not know because it doesn't have AVCS and it doesn't know what AVCS is. You can have those CEL's turned off.
Run the EJ207 longblock with USDM intake mani and everything else on top.
Old 09-24-2010, 06:33 PM   #10
slickonice
Member#: 241812
2002 Ej207 Sedan 30r
I actually just got done swapping a v7 ej207 in my 02 wrx last week. After I got the new motor installed, it started up with the USDM ecu just fine. It did however have a check engine light and the car was pretty slow. The next day I went ahead and swapped in the JDM v7 ecu and the car started and ran much better but still had a CEL. I then installed the IA performance AVCS kit and started the car back up and the check engine light was gone and AVCS was working.
In my opinion, definitely get the Jap ECU and AVCS working on that motor. Night and day difference. Hope this helps some.
slickonice is offline   Reply With Quote
Old 09-24-2010, 06:55 PM   #11
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Slickonice all you did was swap a EJ207 with a US ecu not tuned for the setup you had, so of course it's not going to run optimally. Getting the JDM ecu and the IA kit only enabled you to run AVCS. I'm assuming you had the entire swap turbo and all and on the US ecu anyone should expect the car to run like ****. Running the JDM ecu and having the AVCS kit would obviously be a help, but only by helping spool up.
My point is running the US ecu with a tune will be fine and still create just as much peak power as without AVCS enabled. I'm not saying don't do it, on a daily AVCS is a great thing. However if you look at many high horsepower cars they don't run AVCS cams because they are power limiting.
domestic_abuser is offline   Reply With Quote
Old 05-14-2013, 04:00 PM   #12
redline1785
Member#: 335984
2002 WRX V7 EJ207
how do I tune my v7 ej207? do I need to buy standalone ecu, piggyback? Do I just go to a tuner with no equipment?
redline1785 is offline   Reply With Quote
Old 05-15-2013, 10:11 AM   #13
1hotsubaru
Member#: 244748
"aka" NGRY REX
Easiest thing to do would be to go with an opensource tune on your stock ECU. The tuner will have all the equipment needed other than the green stuff
Old 06-02-2013, 09:20 PM   #14
redline1785
Member#: 335984
2002 WRX V7 EJ207
I just installed my V7 jdm on my bugeye and im running my wrx ecu because jdm ecu runs the car terribly right now. wrx ecu runs the motor very smoothly but it runs very rich because STi injectors are larger. Getting jdm ecu open source tuned next week by Mach V Manassas VA
Old 06-02-2013, 09:39 PM   #15
25rsti
Member#: 166324
Weird because my usdm ecu sucked at running my jdm v9 sti engine.
25rsti is offline   Reply With Quote
Old 06-12-2013, 08:07 PM   #16
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
I did v7 swap on my 04 wrx I had it tuned on wrx ecu now I got the sti ecu and I'm getting tuned for avcs either ecu needs to be tuned sti ecu due to diffrent fuel in us and wrx due to different compression ratio and no tgvs
alexandern05 is offline   Reply With Quote
Old 06-15-2013, 12:38 PM   #17
95ONE
Member#: 349550
I have the V8 and JDM ECU. I bought the car in this condition. It had a USDM wrx map on it that was tuned for the motor. Retarded. This combination was not utilizing the AVCS. Felt boggy down low. I used Romraider and loaded a JDM map. Night and day difference. Car feels fantastic. Of course, just in my opinion, to not use the AVCS on this engine is an epic fail.
95ONE is offline   Reply With Quote
ECU pinouts / Wiring Diagrams for the UK (EURO) or JDM or AUS Spec 2004 WRX mistaboosta Engine Management & Tuning 5 09-30-2010 12:57 AM
WTB: JDM EJ20k PowerFC or JDM v3/4 ECU evilferret Private 'Wanted' Classifieds 2 04-04-2007 01:48 PM
JDM ECU paired with US ECU - pro & cons cjfike Engine Management & Tuning 12 01-28-2006 01:12 AM
WTB: JDM V7 or V8 or USDM ECU harness. V6 Private 'Wanted' Classifieds 3 05-20-2005 07:47 PM
ECU or Access ECU bdel-WRX Private 'Wanted' Classifieds 1 08-18-2003 02:05 AM
