Welcome to the North American Subaru Impreza Owners Club Monday September 22, 2014
Old 10-23-2010, 01:42 PM   #26
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Deck height is 201.0 mm on all EJ series engines. All info is there, some members here can help you (Matt, Jaxx etc - incl. myself).
Marnix is offline   Reply With Quote
Old 10-23-2010, 06:58 PM   #27
aps_sti1
Member#: 208837
K thx man. It made me depressed to see how big the EJ20G ports are on the head knowing I cant use em. Wheres a good place to get Engine specs other than Notable members? I looked up some 94 WRXs and pretty much figured out how Im gona have to do my intake w/ the JDM turbo. What about a tune for UTEC?
aps_sti1 is offline   Reply With Quote
Old 10-24-2010, 01:44 AM   #28
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
All turbo ports were that big until the end of the 2000 model year. The first heads to feature smaller ports for better torque and emission were the 2001 GD/GF WRX models.
Old 03-21-2011, 10:43 PM   #29
hukasabi
Member#: 277491
Default did it all work out..?
Originally Posted by TommyAtomic View Post
Marnix:
I am somewhat in the same boat having just bought a 93 jdm wrx wagon in need of a new waterpump
I bought it for $3500CAD and all it needs is a waterpump. I believe the previous owner couldnt find a shop willing to replace it for less than what he sold me the car for.
As the saying goes as long as I'm replacing the waterpump I might was well do the timing belt. I found some lovely but useless kits on ebay that I wisely chose not to buy.
After using the search button quite a bit I discovered to replicate the parts in the ebay USDM timing/waterpump kits I need :
Timing Belt and Timing gear from 93-96 legacy 2.5l ?
Tensioner from 93-96 legacy 2.5l
Water Pump from 02 WRX
Cam Seal from 93-96 legacy 2.5l
I though I would doublecheck my information is this all correct?
Also I need to know what USDM year and model I should be getting the
Front seal ?
Idlers ?
Little help would be appreciated. Much thanks in advance.
Hey buddy i got a 96 jap sti and need to do cam seals water pump timing belt... did these parts above work out for you...
i think my ej20 sti should be about the same right..?
cheers
hukasabi is offline   Reply With Quote
Old 04-07-2011, 03:11 PM   #30
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
cheers
Yeah those parts worked prefectly save for the waterpump which required some modification to plug a coolant bung for a coolant/oil heat exchanger that my ej20g doesnt have. I found a tight fitting bolt and jb welded it into the hole. Then I completely mig welded it to the bung to make sure there was less then zero chance of leakage. Everything else was a perfect fit.
TommyAtomic is offline   Reply With Quote
Old 04-24-2012, 08:17 PM   #31
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
I know this thread is a year old...is there another water pump that is the same? I would greatly appreciate the help!
GGSimpreza is offline   Reply With Quote
Old 04-24-2012, 09:07 PM   #32
tenchu
Member#: 64147
1993 STi RA V LTD
Green
I just double checked and I can tell you for certain that a EJ253 water pump will NOT work, though I know that doesn't help you much.
tenchu is offline   Reply With Quote
Old 04-25-2012, 04:14 PM   #33
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
the 02 usdm wrx waterpump will work fine if you get the 02 wrx water/oil heat exchanger that the extra coolant bung goes to.
Bonus: the Heat exchanger is almost as good as having an oil cooler.
Old 04-27-2012, 05:46 AM   #34
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Most early EJ20G engines already have the heat exchanger...
Old 04-12-2013, 09:39 PM   #35
leiferickson
Member#: 353273
Default EJ20 JDM Legacy Twin Turbo (EJ20R)
I am a bit of a newbie here, but wanted to share something I found since there seemed to be a gap when I searched recently.
I have (to the best of my knowledge) an EJ20R, which came from a JDM Legacy Twin Turbo. I am using the block to rebuild a standard 2005 EJ20 USDM engine (block cracked), and I'm not there yet, but just got through figuring out the bearings.
Obviously, there are likely to be many other situations, but this engine is a phase 1 engine (thrust #3), and I went through a couple bearings. The ones I got to work finally are: ACL 5M8297HX Std. The problems I was having were that the bearings that I kept getting recommended were too thick. Also, there is a bit of a lip around the thrust housing, but when I dropped these bearings in, it fit like a glove.
you can see the specs here, and how they differ: http://www.aclus.com/content/ACL07(1).pdf
Anyway, I don't mean to dispute any of the other recommendations in this thread, just wanted to add my findings in case it helps someone else out!
Leif
leiferickson is offline   Reply With Quote
Old 04-12-2013, 11:58 PM   #36
pmugabi
Member#: 280926
What were the part numbers of the bearings you tried out before those ACLs that worked? The HX give a marginal increase in oil clearance and in most cases H bearings would work just as well.
pmugabi is offline   Reply With Quote
Old 04-13-2013, 02:36 AM   #37
eg33GC
Member#: 206851
99 V4
EJ20K RS
I'd probably chalk taht up as an ACL QC issue as of their post-bankruptcy issues.
Old 04-13-2013, 04:04 AM   #38
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Or rod BE out of spec.
Old 04-15-2013, 10:03 AM   #39
leiferickson
Member#: 353273
I previously used the 5M8299H .75, although I think you're likely correct that the .25 may have worked.
Old 05-17-2013, 09:41 AM   #40
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Need to change the power steering pump on my 96 ej20g.... any Idea what will fit??
peanutswagon is offline   Reply With Quote
Old 05-17-2013, 01:09 PM   #41
69subaru360
Member#: 159682
1995 WRX
1998 2.5 RS
96 legacy 2.5 if it the pressure line threads into the pump, 97 legacy 2.5 if the line bolts on
early 90's jdm legacy/liberty/RS turbo parts? <Taiwan/Asian Pacific> brodie.gordon International Forum 0 05-14-2010 12:04 AM
JDM v7 Passenger Seat swap on to USDM wrx driver base dan avoN7 Interior & Exterior Modification 7 09-02-2006 08:08 PM
JDM STI V7 Comparsion to USDM WRX PumpsGOTAWD Electrical & Lighting 1 03-07-2004 01:51 PM
will axelback for JDM STi bolt up to USDM WRX? silverF4turbo Factory 2.0L Turbo Powertrain 3 06-04-2003 01:42 AM
VERY IMPORTANT! What EJ20 Series in USDM WRX? BADWRX Factory 2.0L Turbo Powertrain 6 11-21-2001 07:40 PM
