Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 04-11-2013, 01:05 PM   #651
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
I just snagged some 1/4 inch Plate out of the scrap bin at work for modifying my rear subframe
olsen726 is offline   Reply With Quote
Old 04-16-2013, 11:12 PM   #652
VIsubi
Member#: 187834
06 2.5i impreza
Red
Stupid question but question none the less. Cars a 2006 2.5i lol with 27k just hit on the Odom. Supercharged for bought 3k. When the best time to change my timing belt and water pump. Looking into changing it with a stronger better Performance TB or blue?? Or have you even chagned your timing belt yet??
VIsubi is offline   Reply With Quote
Old 04-16-2013, 11:16 PM   #653
VIsubi
Member#: 187834
06 2.5i impreza
Red
Originally Posted by chang09 View Post
would i have to change any of my internal or anything else if i want to boost more wit the supercharger?[/font][/size]
Depends on your boost needs, since boost is a bit more linear you can actually run bit more boost than required for turbo. I'm pushing 9 psi on a centrifugal and since my Boost Controller is my right foot depends on when or how high you take your RPM's, i like to shift at 6k whe ndriving spirited. Internals not so much but do realize one day you will have to do this.
Though all other requirements to go from N/A to FI like bigger injectors,fuel pump , colder plugs etc. will have to be addressed
Old 04-16-2013, 11:18 PM   #654
VIsubi
Member#: 187834
06 2.5i impreza
Red
Originally Posted by olsen726 View Post
carnage report
Wow from one of the strongest gears in your car. not to mention a straight cut none the less. So looks like you'll be going hardened or stright cut next FTW!!!
Old 05-14-2013, 07:32 AM   #655
Snydas_99legacy
Member#: 262632
2006 Wrx
Subscribed, im in the process of doing a r200 swap on my 06 wrx that has been rwd a week lol. Im now working on getting the materials to do the swap.
Snydas_99legacy is offline   Reply With Quote
Old 05-15-2013, 04:17 PM   #656
05subysti
Member#: 268190
2005 STi
bump waiting for pics of the r200 fabbing. and also some pics of maching the s14 hub down
i have to do the same conversion as well.
Old 05-17-2013, 09:41 AM   #657
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
Sorry guys, I havent touched the car in a couple of weeks, the front end went out of my toyota, so I straight axle swapped it, and have been spending most of my free time finishing that up. I should finally get to my car this weekend though
Old 05-17-2013, 01:54 PM   #658
saari
Member#: 236271
2007 impreza 2.5i
Flat black
I just finished piecing together a kit and boosting my 2.5i. I'm actually going in for a tune today.
I say go for it. Do your homework and play it safe for longevity, but its a fun process and is worth it in the end!
saari is offline   Reply With Quote
Old 05-17-2013, 03:56 PM   #659
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
post some numbers when you get your tune... i kinda already went for it though?
Old 05-17-2013, 11:02 PM   #660
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
ok guys, i have a couple of questions for anyone that has experience using a lathe.
(this is so i can machine down the s14 hubs to fit the subaru wheelbearings)
my plan is to remove the wheelstuds on my hubs, and then bolt them together face to face, using the holes where the studs were, like how i am showing in this pic.
that way i can chuck up one of the hubs and lathe off the extra material on the side that is bolted to it, and flip it around to do the other side...
does anyone see a problem with this idea? or have a better idea?
and my other question is what bit do i use? and how fast should i have it spinning?
this is my first time using a lathe, so i am pretty clueless on what the best methods are.
Old 05-21-2013, 12:41 PM   #661
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
i got one of the hubs lathed down, and the other one is almost finished. here are some pics
and in this bottom pic it shows top to bottom stock 240sx, shaved down 240sx, stock subaru
Old 05-21-2013, 04:30 PM   #662
Snydas_99legacy
Member#: 262632
2006 Wrx
Nice work man, did you get any quotes at any shops on how much it would be to have them machined or did you already have the lathe laying around and decide to do it yourself?
Old 05-21-2013, 08:48 PM   #663
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
we already had the lathe laying around, so i never checked to see what it would have cost to have someone else do it. it took for ever to shave all of that material off though.
Old 05-21-2013, 10:00 PM   #664
Snydas_99legacy
Member#: 262632
2006 Wrx
Dude I just realized your in Portland lol, im in Medford lol.
Old 05-23-2013, 03:41 AM   #665
KGwrx
Member#: 268868
this is my first time stumbling on this thread, gotta say this is some good stuff!
KGwrx is offline   Reply With Quote
Old 05-24-2013, 02:11 AM   #666
05subysti
Member#: 268190
2005 STi
nice work! will any lathe work, what bit did you use, and did you install the s14 hubs yet??
Old 05-24-2013, 01:08 PM   #667
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
I went to test fit one side, to make sure everything was going to line up correctly, and I broke the inner race trying to press it onto the hub and to top it all off I cant find a place that sells the races separate from the wheelbearings
Old 05-24-2013, 01:11 PM   #668
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
I think pretty much any metal lathe will work, as long as you can get the hub to chuck up, and I'm not sure what bit it is, it was just the bit that happened to be on the lathe when I tried it lol
Old 05-26-2013, 02:31 AM   #669
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
I got one of the hubs pressed into the spindle waiting for a race, so I can do the other side
Old 05-26-2013, 04:19 AM   #670
Snydas_99legacy
Member#: 262632
2006 Wrx
So would you be willing to mod another set?? = D lol
Old 05-27-2013, 03:19 PM   #671
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
hell no, it took forever lol, i think part of it was due to the belts on the lathe being 50 years old though
here is a pic of the nissan hub mounted into the subaru spindle, and bolted onto the car... not the greatest picture, but i guess its better than nothing
Old 05-28-2013, 01:00 AM   #672
Snydas_99legacy
Member#: 262632
2006 Wrx
=( okay im just afraid a machine shop is going to charge a arm and a leg.
Old 05-28-2013, 01:51 PM   #673
05subysti
Member#: 268190
2005 STi
nice! so did you buy new or used hubs, and how much you remove off the hub?
pretty cool the subarus have the same 12x1.25 thread pitch on the studs as nissans do haha.
Old 05-28-2013, 03:10 PM   #674
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
I bought some used hubs, I'm pretty sure it was 5mm that I had to romove for the races to fit, and then I had to remove a **** ton of material to give the seal a place to sit
Old 05-28-2013, 04:48 PM   #675
05subysti
Member#: 268190
2005 STi
How much would you charge to do the machining if I shipped you a pair of hubs?
My '07 2.5i project Vizzionz Member's Car Gallery 25 06-09-2012 04:40 AM
2.5i wrx header project coopeco2.5i General Community 9 02-03-2010 09:12 PM
Project 2.5i scoobyimp07 Member's Car Gallery 112 10-20-2008 09:28 AM
2.5i Turbo Project JLW2007RS Normally Aspirated Powertrain 13 04-02-2008 05:33 PM
2.5i n/a project. call me insane all you want iRick. Normally Aspirated Powertrain 26 01-08-2008 10:59 PM
