Welcome to the North American Subaru Impreza Owners Club Sunday September 21, 2014
Old 05-17-2013, 07:00 PM   #1
elcapitan1110
Member#: 324618
2008 STi
Default Installed New HU, no radio reception?
Hi All,
Just installed a Pioneer avh-5500bhs into my 2008 sti. Everything else works except for the radio. Tried wiring blue/white wire from HU to blue metra harness wire, and I also tried connecting blue/white wire from HU to red 12v wire, and still nothing. The connection on the antenna plug seems a little loose... but it goes in anyway. Could that be the problem? Could bad grounding cause the issue? Again, all other functions work, minus the radio. Any ideas?
Thanks guys
elcapitan1110 is offline   Reply With Quote
Old 05-17-2013, 07:06 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
dont connect power to the blue/white wire coming from the headunit as that is used to turn on amps. not sure what would happen if you did that.
i cant remember if the sti has a powered antenna but maybe search that.
and the lug to the antenna should be tight. maybe take a pic.
PARANOID56 is offline   Reply With Quote
Old 05-17-2013, 07:19 PM   #3
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
I had this problem once. Turned out the antenna booster needed to be connected.
NITROS is offline   Reply With Quote
Old 05-18-2013, 11:06 AM   #4
elcapitan1110
Member#: 324618
2008 STi
Ok, so I fiddled around with the wring, I am confident that the wiring was done correctly. I have the blue/white remote antenna wire from my HU connected to the blue wire coming from my Metra harness. I followed the wire back from the aftermarket to the OEM harness, and it appears that everything is wired correctly. I have very little radio reception, I only get one station :-(
What's strange is that the straight plug in the back of the HU that is supposed to connect to the antenna doesn't change the reception whether it is plugged in or not. I will attach pictures... Could that just mean the cable is bad? Or maybe my HU is bad...?
Old 05-18-2013, 11:13 AM   #5
elcapitan1110
Member#: 324618
2008 STi
Just noticed something else... On the one station that I DO get, when I touch the antenna plug to the metal ring of one of the A/V inputs, the signal increases... Is the plug on the back of the HU broken?
Old 05-21-2013, 06:34 PM   #6
elcapitan1110
Member#: 324618
2008 STi
Bump... Perhaps I could have a ground loop? Anyone?
Old 05-21-2013, 09:38 PM   #7
gggplaya
Member#: 139444
2008 Impreza
Dark Gray
Do you have your headunit set correctly??? Local should be turned off.
gggplaya is offline   Reply With Quote
Old 05-21-2013, 09:48 PM   #8
sizemic1
Member#: 270669
2011 WRX Sedan
Stg 2 Phatbotti e-tuned
Make sure you're shoving the antenna in completely. It should be a very tight fit.
sizemic1 is offline   Reply With Quote
