Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 05-17-2013, 07:34 PM   #1
Member#: 283617
Default AVCS reads 0 all the time in RomRaider Logger
I installed a STI 2004 mod JDM engine in a 2002mod wrx with a 6A(red color writing) ecu (5plugs) and everything runs fine with no dtc's...
Problem is I get 0 as a reading in Logger for the AVCS angle at all times...
Could it be the avcs is not working or is it just the logger?
I double checked the wiring and everything is correct...
Dochka is offline   Reply With Quote
Old 05-17-2013, 09:01 PM   #2
Member#: 70395
Are you saying you have the AVCS hooked up? You might want to fill out your profile so we know where the hell you are. Not all Subaru's are the same around the world.
Old 05-17-2013, 09:48 PM   #3
Member#: 72829
2006 WRX
2015 WRX
Does the neutral position switch read correctly?
Airboy is offline   Reply With Quote
Old 05-30-2013, 03:32 PM   #4
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
there are some startup checks it does btw. if it doesnt see an idle lower then 1100 it wont turn on. if the coolant temp doesnt go about a certain point it wont turn on either... seen both.
Bamofo is offline   Reply With Quote
Old 07-15-2013, 04:45 AM   #5
Member#: 268627
05 SpecC/FFR818
Unless you A) ran an additional harness to hook up the AVCS and B) have an ECU that can control it (and set the AVCS table to something other than 0), it will always read 0 because it's just floating.
ssssly is offline   Reply With Quote
