Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 05-18-2013, 02:23 PM   #26
ShinjiML
Member#: 257231
2011 STI
Originally Posted by WelDun1 View Post
Wow, I've heard ppl say it, its just hard to believe. Not saying you are lying, but if you look in the JDM parts catalog, it says that all Ver5/6 STi ej207 are forged. I would be pissed if I found out that I had Cast pistons! Did you remove the pistons themselves, or did you look at them while still installed? Thanx for sharing.
Pistons were physically removed. I was pretty disappointed when I found out.
ShinjiML is offline   Reply With Quote
Old 05-18-2013, 02:38 PM   #27
WelDun1
Member#: 249130
1999 Ver5 STi RA
No crap, I would be too. I wonder if someone switched them out. What is the engine out of? And where did you get it from? Some of these JDM shops are known for doing crap like that.
WelDun1 is online now   Reply With Quote
Old 05-18-2013, 02:51 PM   #28
ShinjiML
Member#: 257231
2011 STI
That's a possibility. The engine was supposed to be from a v5 type R, but I later found out that the engine had been in and out of the car a few times before it was shipped to me from Japan by a US Marine.
Old 06-03-2013, 05:59 PM   #29
ShinjiML
Member#: 257231
2011 STI
A little update, previously I thought that the square dish V5 pistons were cast, but apparently, the V5 Type RA pistons are square dish and FORGED. So, it looks like these could be forged pistons after all, plus they feel pretty light, which further supports the possibility.
Old 06-06-2013, 06:39 AM   #30
WelDun1
Member#: 249130
1999 Ver5 STi RA
I know ur happy. I know my pistons are forged, the engine only has 37k on it and its never been worked on let alone taken apart. Lol... I'm still rebuilding the bottom end, ill keep the stock forgies for a back up I guess, maybe just set them on the shelf for another build later down the road!
How is ur project going?
Old 06-06-2013, 06:40 AM   #31
WelDun1
Member#: 249130
1999 Ver5 STi RA
Does anyone know what size Oil Pump is stock for the Ver5/6 STi? 10mm? 11mm? And is it big enough for a 400+awhp build? I'm swapping out the stock pan for a 06+STi pan and a KillerB pick-up and baffle to compliment it.
Old 06-06-2013, 06:48 AM   #32
WelDun1
Member#: 249130
1999 Ver5 STi RA
I'm looking at a few different Turbos for my build.. which do u think is best for a 400+awhp build , for a Ver5 Type-R? Fully built bottom end, and possibly heads as well. Looking for a somewhat torquey build, which I know the 1.5 will produce plus it was made for the 2.0, but what about the Polka Pickle? And Garrett? I think the 2.5xtr or the gtx3071r is the best bet, just a Lil spendy!
-Blouch Dom 1.5
-Blouch Dom 2.5
-Gt3071r
-gtx3071r
-gt3076r
What do you guys think?
I like the 1.5, I'm looking for a reliable strong build.
Old 06-06-2013, 10:00 AM   #33
Modollenroc
Member#: 243499
question, as I search I keep hearing different answers from different sites, but does the v5/v6 haavr a vf29 or a vf34 Turbo?
Modollenroc is offline   Reply With Quote
Old 06-06-2013, 10:43 AM   #34
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
I think they are different you are correct I have a V6 in mine and I can go double check the stamp tonight and Weldun's is a V5 so he can fill in that blank when he has a second.
Devilteg is offline   Reply With Quote
Old 06-06-2013, 01:21 PM   #35
WelDun1
Member#: 249130
1999 Ver5 STi RA
Ver5 has vf28
Ver6 vf29 and apparently rumored that the early Ver6 had a vf28 but I'm pretty.sure the Type-R/RA had vf29.
The vf34 came on the Ver7 spec c
Old 06-11-2013, 10:04 PM   #36
Modollenroc
Member#: 243499
Is anyone using the apexi power fc for their ECU? I need help finding the wiring diagram to make a small harness for
Old 06-11-2013, 10:09 PM   #37
Devilteg
Member#: 127545
2013 XV
Dark Gray Metallic
Sorry man Im going open source but someone will know or check the ej207 owners thread i recall discussion about the power FC in there
Old 06-11-2013, 10:16 PM   #38
WelDun1
Member#: 249130
1999 Ver5 STi RA
I'm using the PFC, but I'm not sure which wire diagram ur referring to.
Old 06-11-2013, 10:16 PM   #39
Modollenroc
Member#: 243499
The pinout diagram if possible.
Old 06-11-2013, 10:28 PM   #40
WelDun1
Member#: 249130
1999 Ver5 STi RA
What kind of harness do u need? What engine do u have? You shouldn't need anything for it bcuz its plug n play. Just swap out your stock ECU and plug in the Apexi.
Old 06-11-2013, 10:33 PM   #41
Modollenroc
Member#: 243499
V6 ej207 I do not have the harness from the engine to the power fc... I have the JDM harness.. I can't really understand the situation that the mechanics at rennermotorsport are in. From my understanding the Guy told me that he was going to need a pinout diagram from the power fc because he has to make a harness or something of that nature.
Old 06-11-2013, 10:51 PM   #42
WelDun1
Member#: 249130
1999 Ver5 STi RA
Not at all bro. All u do is unplug the harness from the stock ECU, and then plug it into the Apexi PFC. It's as simple as that. If they are saying otherwise, they are either trying to rip you off, or you don't have the right Apexi ECU.
Old 06-11-2013, 11:25 PM   #43
Modollenroc
Member#: 243499
now that you said that. Its starting to sound like I have the wrong ECU. I REALLY hope that isn't the case.
Old 06-11-2013, 11:25 PM   #44
Modollenroc
Member#: 243499
By any chance do you know your ECU model number?
I just asked the guy whom I purchased the pfc from which motor he bought it for and he said the ej20k. Now, are those complete different ECU setups? I think I'm screwed ...
Old 06-11-2013, 11:33 PM   #45
WelDun1
Member#: 249130
1999 Ver5 STi RA
Well I have a Ver5 Type-R. It's different than yours. It's the Apexi model # u need.
CHECK OUT PAGE 16
Apexi PFC Instruction Manual
Old 06-11-2013, 11:43 PM   #46
WelDun1
Member#: 249130
1999 Ver5 STi RA
The serial # should look something like this
PFC gc8f 999-0024
Old 06-11-2013, 11:56 PM   #47
Modollenroc
Member#: 243499
PFC gc8f 999-0024
I have pfc Gc8f 020-1024. . .
Thanks for the file its extremely helpful.
Old 06-12-2013, 12:17 AM   #48
WelDun1
Member#: 249130
1999 Ver5 STi RA
Well it looks like you have the right one.
I don't know what else to say. The manual is going to tell u exactly what I did.
First disconnect the negative battery terminal. Then You unplug your ECU, and then you plug IN the Apexi unit. Very straight forward.
Good Luck bro!
Old 06-12-2013, 12:29 AM   #49
Modollenroc
Member#: 243499
Good Luck bro!
Thanks, I was told I need a pin out and a jump harness Idk what any of that hoopla is I do NOT deal with wiring in any shape way or form.
Old 07-21-2013, 11:39 PM   #50
ShinjiML
Member#: 257231
2011 STI
Haven't check this thread in a while, my heads sat at the machine shop for about a month before they finally began working on it, but everything's basically together now, only hold up is the injectors. I bought a set of 565 dark blue's from the classified, but all 4 ended up not spraying at all, so now I'm getting a set of Deatschwerks 650cc. That'll teach me to always try to buy used to save a few bucks...Some things you can buy used, but I guess injectors is one of the things that's probably better off purchased new. =\
Can't wait to finish everything and get it tuned!
