Old 09-21-2012, 04:47 PM   #26
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
Well because of this bolt I decided not to try my rear bearings. Had a shop replace them last week and everything is fine.....except that lateral link bolt. I was under yesterday and noticed that bolt didn't look snug. I can take a wrench and spin the bolt either way slightly, like a 1/4 turn. The bushing is definitely spinning with it.
Should I be concerned that this bolt isn't tight? Trying to tighten it more results in that 1/4 turn with the bushing, and when I let off the wrench, the bolt "springs" back.
ManualOverAuto is offline   Reply With Quote
Old 09-21-2012, 04:52 PM   #27
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
tighten the nut, not the bolt.
Old 09-21-2012, 05:58 PM   #28
ManualOverAuto
Member#: 304662
Sedona red Pearl
Oh wow........
Thanks! Definitely saved me some frustration.
Old 09-22-2012, 12:35 AM   #29
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
+1 for the air hammer. works wonders!
bhhamblin is offline   Reply With Quote
Old 09-22-2012, 12:42 AM   #30
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I stacked coupons at Advanced Auto to get an Ingersol Rand air hammer for $17. Turns out, it's a weenie model but it did serve to prove to me that I wanted an air hammer that actually had some balls.
Old 09-22-2012, 03:28 AM   #31
the earthquake one from HF actually isnt bad
Old 12-16-2012, 10:56 PM   #32
SlvrRex02
Member#: 320916
2002 WRX Wagon
Can someone PM me the part number for the outer lateral link bushings? I will be ordering them for a 1997 impreza L five speed 2.2 awd tomorrow and my deal is usually difficult. thanks.-Jordan.
SlvrRex02 is offline   Reply With Quote
Old 12-17-2012, 12:41 PM   #33
Nick Boxler
Member#: 180326
2005 WRX
HTA68'ed San Remo Red
Originally Posted by williaty View Post
Day 1: Remove nut, rejoice at how easy it was. Attempt to remove bolt, find out you can't. Hose knuckle down with PB Blaster and go to bed.
Day 2: Attempt to remove bolt, find out you can't. Use 6ft long lever to spin the head of bolt, realize you're spinning the lat-link bushing inside the lat link. Decide lat link bushing must be seized to bolt. Expose union of same to fire, impact, and corrosives chemicals. Hit with larger hammer. Cry.
Day 3: Remove head of bolt with cut-off wheel, expecting to be able to slide bolt forward and out of the knuckle. Find out bolt will not budge. Cry. Attempt to place ball joint press over knuckle to press out bolt, find out the press is too short. Cry. Cut lat link off of bushing. Attempt to place ball joint press over knuckle to press out bolt, find out the press is too small to fit around bushing. Cry. Attempt to cut bushing off bolt. Find out that bushing has both inner and outer layers of rubber and steel. Nearly choke to death on burning rubber smoke. Use vise grips to peel outer rubber and steel layer off of bushing. Remove all skin on fingers in the process. Swear. Attempt to place ball joint press over knuckle to press out bolt, find out that while the press now fits over the decimated bushing, the press is too short. Swear. Cut bolt shorter. Attempt to press bolt out of knuckle. Determine that bolt was not cut square enough and press walks off bolt explosively. Devise centering press w/ small socket and nut scavenged from endlink via McGuyver like ghetto engineering skills. Press bolt a few mm forward via huge amounts of force on a 2ft lever attached to the press. Attempt to devise new tool w/ different socket, nut, duct tape, small furry animals. Accidentally bump bolt with back of hand, knock it out of knuckle. Swear and cry in relief and confusion. Go to bed.
Day 4: Reassemble suspension. Take for test drive. Nearly die as newly active rear end comes around.
OH my that was hilarious. Well done, sir.
Nick Boxler is offline   Reply With Quote
Old 12-17-2012, 03:14 PM   #34
crfnick56
Member#: 329410
2003 bugeye wagon
Sonic Yellow
That is known as the Bastard Bolt for a reason
crfnick56 is offline   Reply With Quote
Old 12-18-2012, 07:52 AM   #35
Bru1212
Member#: 178770
06 STi
04 FXT
Just call http://rallispec.com/prod_mount.htm
Bru1212 is online now   Reply With Quote
Old 05-11-2013, 01:28 PM   #36
IceWilly
Member#: 126081
2005 Sti
GT: IceWilly
Needed to get an alignment today and found out these two rear were seized.... now I get to experience all this fun just so my rear toe isn't way out of whack.
I don't mind cutting the bolt to bits, but I'd rather avoid destroying the lateral link and would greatly prefer to not have to remove the hub as that will surely be another nightmare getting that long bolt out that spans across and is surely seized as well.
How would one go about cutting the bolt out without destroying the link? Can you get enough of the head/bolt off that you can lower the lateral link out from the crossmember and get better access to work?
can't wait.
IceWilly is offline   Reply With Quote
Old 05-15-2013, 02:19 PM   #37
IceWilly
Member#: 126081
2005 Sti
GT: IceWilly
Where should I be applying heat to get this stuff to budge?
Also, if i do spin the head of the 22mm bolt and it spins the bushing inside.... is that really that bad if I am just trying to get this thing aligned and not necessarily replace the bushing? I realize that isn't not going to help me later on when I do need to replace the bushing, but if it's that or start cutting the crap out of everything then maybe I will leave it there.
Old 05-15-2013, 03:26 PM   #38
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
If the bolt is seized to the bushing, I don't see how you'll be able to get the required precision necessary to align the car. That being said, if you can pull it off, if it works, it works, you know?
Old 05-15-2013, 03:29 PM   #39
IceWilly
Member#: 126081
2005 Sti
GT: IceWilly
By spinning the bolt and bushing together, wouldn't that move the center line of the bolt the same amount? Just because the bushing doesn't spin like it should around the bolt, doesn't mean the final position of the bushing would be different.
Yes I agree that its backwards and i would be using the outside of the bushing as the rotation point instead of the bolt/bushing sleeve location... but I'm staring down the barrell of that or a massive cutting/torching job to free those parts.
This is a very poor time for me to have this problem, so I am just trying to get any solution to delay the pain.
Old 05-15-2013, 03:36 PM   #40
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, it'll do the same thing, but I guarantee you you're going to have a lot harder time putting it precisely in the correct spot to control the position of the edge of the tire to within 0.5mm, which you DO have to do in order to properly align the car.
Old 05-15-2013, 03:50 PM   #41
IceWilly
Member#: 126081
2005 Sti
GT: IceWilly
I'm just hoping that I don't have to destroy the lateral link like you seemed to have to.
This is my DD sadly. I can still get to and from work without it, but it will have me waking up super early to drive the opposite way to bring my fiance to/from work. I'm tempted to bring it to the dealer and have them fight with it, but they don't stock the possible replacement parts (bolt/cam nut/bushing) so even if they fight it out and destroy the bushing the car might be sitting there waiting for 2 bushings for a day or 2. Not super excited about that. Not to mention the probable $100 shop labor rate.
Also, getting the link off the hub is going to be equally as hard in my case due to that super long bolt that is probably in just as bad condition. I wish I could have all the links/trailing arms off so I could clean everything up and reset, but I don't even want to know how many hours it would take to break all of those pieces loose.
Wish I had a better way to put some heat on those bolts, maybe that would help my cause. Having the car as a DD really limits my options.
Old 05-16-2013, 07:26 PM   #42
call the dealer and ask them all this
Old 05-18-2013, 02:22 PM   #43
IceWilly
Member#: 126081
2005 Sti
GT: IceWilly
I did just that actually. They checked it out, and quoted $1200 to fix everything up. In that cost they assumed they would have to use heat and thus destroy the rear lateral link. That's obviously a huge amount of money for this issue, and I can't consider doing that.
I think my best option is to buy a take off set of links with oem bushings and new bolts/hardware. Cut everything off myself with no regard for the lateral links well being, and replace with fresh stuff. With some buddies at work hopefully I can get the links off cleanly without damaging the subframe at all as long as I don't care about preserving anything.
Argh, we'll see. At least lateral links are a common upgrade and OEM ones are easy to come by.
Old 05-18-2013, 02:24 PM   #44
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Buy a set of MSI lateral links from TiC. Buy a set of Group N bushings. Put bushings into links. Cut the motherfracking hell out of existing links to get them off. Bolt new links on. Taste, and enjoy!
Old 09-01-2013, 12:34 AM   #45
theo79
Member#: 159621
2002 WRX - WRB
JDM v7 Spec C drivetrain
I'm on day two of this bolt.
TIC lateral link bushings are the last part of my suspension work. (For now.)
I've sprayed 1/2 a can of PB blaster on each side. The nut comes off easy with an impact gun. I can get the bolt to spin with a 3ft 1/2 drive breaker bar. The forward lateral links will slide off the bolt.
The bolt will not spin when impact gun is applied. It looks like the rear lateral link bushings might be fused. No salt on the roads here in California, I've gotten the bolt to back out about 1cm.
I haven't tried a BFH yet because I want to try to keep the hardware if possible.
How well did the torch method work for you guys? Any other suggestions that will not destroy the hardware?
I will try jacking the knuckle up tomorrow.
theo79 is offline   Reply With Quote
Old 09-01-2013, 12:46 AM   #46
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You will destroy the hardware. You should have expected to do so and have bought spares before you started.
I did, however, find something even worse to work on than this bolt: a house.
Old 09-01-2013, 12:56 AM   #47
theo79
Member#: 159621
2002 WRX - WRB
For now I just put it back together. I'll get a new bolt this week, but I am pretty set on getting this bolt out without destroying it.
Never let the car win.
Old 09-01-2013, 01:20 AM   #48
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
At this point, being pigheaded and "not letting the bolt win" is just stupid.
Be efficient. Section the bolt, knock out the bushing, pop a new one in, and get on with your life. Screwing with it for 6 hours to "win" doesn't prove anything other than you don't mind wasting your time.
Old 09-01-2013, 01:20 AM   #49
IceWilly
Member#: 126081
2005 Sti
GT: IceWilly
You'll lose. In my case I also had to destroy a lateral link to free the stupid thing. I broke a tooth off my socket lowering the car's weight onto the wrench trying to break it loose. I was able to get the nuts off and the bolt spinning but it was seized to the bushing. There's simply no way to get access to it, and force no longer does anything since its free spinning.
I took it as an opp to use all new hardware and anti seize that bish. I plan to drive the car into the ground so I was happy to save myself trouble later.
My PB breaker didn't work nearly as well as the stuff the fab shop guys had at my work. It was penetrating fluid, but it seemed to work better. I can't remember the name but I'll return with it at some point. And FWIW, i soaked those bolts in PB breaker every day for a week before I tried with impact tools and huge breaker bars to loose things up.
Also, heating up the bolt had no effect breaking it loose from the bushing for me. And I heated it up HOT. I ended up torching a lot of it off because that bushing is hardened and was hard for even the angle grinders at work to handle.
Old 09-01-2013, 01:33 AM   #50
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The better penetrating lube was almost certainly Kroil Oil. It makes PB Blaster seem like trying to get a bolt loose by spraying pancake syrup at it. Kroil is friggen amazing but it smells TERRIBLE. In spite of that, it's the only thing I use now.
Outer lateral link bolt scoobyimprza Brakes, Steering & Suspension 20 07-13-2005 10:06 PM
Inner Front Lateral Link Bolt Removal Boxologist Brakes, Steering & Suspension 6 06-04-2005 06:36 PM
04 STI Lateral link bolts - stuck!! V8VENOM Brakes, Steering & Suspension 7 10-21-2004 08:13 PM
Can't get lateral link bolt off kaneda3 Brakes, Steering & Suspension 19 06-03-2004 08:34 AM
Outer lateral link bolt scoobyimprza Mid Atlantic Impreza Club -- MAIC 4 04-28-2004 06:33 PM
