Tire & Wheel Forum sponsored by The Tire Rack |
02-20-2013, 09:24 PM | #2126 |
Member#: 228116
South East
Vehicle:1998 Forester Black |
I've searched and havent found an exact answer.
18x9.5 +40 Enkei NT03's what is the minimum spacer to clear brembo's? I know a 10mm will work but i want as much inboard clearance as possible
02-21-2013, 03:06 AM | #2127 | |
Member#: 97135
NWIC
You'll already have a bunch of inboard room, not sure why you would be concerned with that. |
02-23-2013, 08:23 PM | #2128 |
Member#: 98582
Hi, tried searching these specs but couldn't find much info.
I'm thinking about getting a set of Advan RG in 17x8.5 +31 that was previously on a DC5 Integra. Would that offset screw up the bearings on a '05 STi? |
02-26-2013, 12:32 PM | #2129 |
Member#: 140163
MAIC
Vehicle:03 STi hellaflunctional |
03-05-2013, 06:18 AM | #2130 |
Member#: 289023
NESIC
Vehicle:2002 WRX Metalic silver pearl |
new to the aftermarket rim deal
I really don't want to sound like a noob, but I am when it comes to rims so I'll keep the questions and details simple. I own a 2002 wrx, stock suspension and stock 16" rims. I plan on buying a set of used ASA Ka3 rims, 5x100 with kumho Ecsta 215/45/17x7.5 i do not know the offset. Will or should these fit my car? will i need spacers or hubcentric rings(i know they are essentially the same)?
Any info regarding this will greatly be appreciated and I thank you in advance. Again sorry for the noob question... And in case anyone is wondering, I chose these because they are what I can afford and I think they will look decent for my car. I'm not worried about keeping them clean because i have been known to "play" in the fields around where I live. Thanks for the help!!! |
03-05-2013, 06:19 AM | #2131 |
Member#: 289023
NESIC
oh and i also forgot to mention, I have the stock calipers for now and no modifications to the fenders...Thanks
03-05-2013, 12:58 PM | #2132 |
Member#: 140163
MAIC
Have you tried searching for the wheel specs? They'll fit your car but nobody can tell you if they'll run without offset.
03-05-2013, 02:52 PM | #2133 |
Member#: 289023
NESIC
03-05-2013, 02:56 PM | #2134 |
Member#: 289023
NESIC
03-05-2013, 09:19 PM | #2135 |
Member#: 140163
MAIC
03-07-2013, 10:16 PM | #2136 |
Member#: 349348
SCIC
Vehicle:13 Scoob Plasma blue pearl |
Super informative post I'm just getting in on the forum world but I'm learning so much
03-09-2013, 09:45 AM | #2137 |
Member#: 210371
MAIC
Vehicle:2002 hybrid 16gxt '03 Lifted TS |
03-17-2013, 04:34 PM | #2138 |
Member#: 350489
Vehicle:09 Impreza 2.5i |
Has anyone had fitment issues with 17x7.5 5x100 +45 offset on 09 impreza 2.5i 4dr? And a solution would be nice too!
04-10-2013, 11:29 AM | #2139 |
Member#: 333403
I'll be putting Focal 428 F04's on my 09 Impreza 2.5i tomorrow. At 16x7, will there be any problems with an offset of 42?
04-10-2013, 05:33 PM | #2140 |
Member#: 352978
Varrstoen es111 18x9.5 +34 on a 2004 sti?
04-10-2013, 06:09 PM | #2141 |
Member#: 97135
NWIC
04-11-2013, 12:28 AM | #2142 |
Member#: 234357
Vehicle:2009 WRX Sportwagen zum einbauen! |
04-13-2013, 12:42 AM | #2143 |
Member#: 49066
Vehicle:97 Toyota Supra White |
i will add this question in this thread as well since its offset related. So here goes
So ive been told different opinions on this and wanted to get more input. What is the possiblity to fit a 18x9.5 +45 on a 2003 subaru wagon. My intentions on suspension is BC coilovers and camber bolts rolled fenders Tire would be 235 or 245 Now some have said it will work and some have said that due to the higher offset the inner clearance is the issue hitting the strut. My question is if this setup does not work what is the minimum offset that is needed on a 18x9.5 wheel? |
04-18-2013, 02:26 AM | #2144 |
Member#: 353355
MAIC
Vehicle:2002 Impreza WRX Silver |
I've been in the market for new wheels and tires for my 06 wagon, and I found "Master thread of OEM Subaru Wheel Specs" to be helpful...
http://forums.nasioc.com/forums/show....php?t=2239019 Last edited by rbbeauchemin1; 04-21-2013 at 09:26 AM. Reason: Incorrect data on previous post |
04-18-2013, 03:10 AM | #2145 |
Member#: 234357
It seems to me you are over complicating the situation.
Wheel width isn't nearly as important as the tire width (concerning fender clearance), unless you are stretching the tire. And it's not really a stacking measurement (wheel width and tire width). What matters in your situation is that you are keeping with the same offset and adding ~20mm of total tire width. All that is going to do is 'use up' about 10mm of clearance on each side of the tire. |
04-18-2013, 04:13 AM | #2146 | |
Member#: 353355
MAIC
04-18-2013, 04:17 AM | #2147 | ||
Member#: 97135
NWIC
there isn't ANY 1.6whatever inches you are pulling out of your ass. stop thinking about tire dimensions, as those only skew and **** up your calculations. figure out where the wheel sits within the fender FIRST then that can help you figure out how much tire you can get away with. in terms of a 6.5" +55 wheel vs 7.5" +55.....look at the friggin width. there is only 1" difference between them. that should've been the biggest hint. I got side tracked again by your retarded thinking. THE DIFFERENCE BETWEEN where the wheel sits is 12mm outboard at the outter face, and 14mm inboard on the inner face. Meaning you'll have 12mm less outer clearance than stock, and 14mm less inner clearance than stock. realistically you need to be shooting for a mid to high 40's offset on a 7.5" wheel. Quote:
just stop thinking. |
04-19-2013, 11:04 AM | #2148 |
Member#: 234357
No. If the offset of the wheel remains the same, any extra width you are adding (wider tires, etc..) will be added equally (essentially) to inside and outside. Example: 20mm wider tires, half the width (10mm) to the inside, and other half (10mm) going to the outside.
05-18-2013, 05:19 PM | #2149 |
Member#: 356804
Vehicle:2005 Subaru 2.5RS Matt Grey |
I just bought a 2005 2.5 RS. I had a toyota celica that i totalled and i still have my rims that are 18x9+35 (5x100 obvs) running on 225/40/18. Can someone confirm if these will fit without problem or will i need to work on fenders?
I tried searching but didnt find anything useful |
05-18-2013, 09:57 PM | #2150 | |
Member#: 97135
NWIC
You need to find out the center bore of the weeks though....Toyota uses a narrower hub bore than Subaru, so there's a high chance the wheels still won't fit. That fitment and stretch will look pretty stupid at stock height. |
Similar Threads | ||||
Can we correct "The Offset Information Thread"? | Portly | Tire & Wheel | 20 | 12-14-2015 06:51 PM |
So I read the Offset thread... | Dracon | Tire & Wheel | 6 | 11-18-2012 04:39 AM |
The Hella Flush Information Thread | Impreza2.5i-Kid | Tire & Wheel | 16 | 08-23-2010 08:33 AM |
The end all 6 speed swap information thread | DS1 | Transmission (AT/MT) & Driveline | 156 | 11-14-2009 08:21 PM |
The Header Information Thread | imposter | Normally Aspirated Powertrain | 315 | 04-25-2003 02:59 PM |
