Old 05-18-2013, 09:56 PM   #1
Donzo
Member#: 95337
2012 Jeep Overland
Default Damp calipers normal or no bueno?
I was changing my rotors and pads this morning and noticed the calipers were damp. This is the first brake change on the vehicle and currently has 48k miles. The car is a daily driver with 65 miles daily. I do a lot of spirited driving but I doubt anything to cook them or the fluid. If this is in fact not normal, I will likely start looking for stainless lines before I change the fluid.
It's a 2008 Legacy GT Spec.B
Donzo is offline   Reply With Quote
Old 05-18-2013, 10:22 PM   #2
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
Looks like its leaking fluid from the brake line attachment.
Good time to upgrade to stainless lines anyway.
Old 05-18-2013, 11:47 PM   #3
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
I would at least tighten that banjo bolt until you upgrade your lines.
jam69007 is offline   Reply With Quote
Old 05-19-2013, 03:31 PM   #4
Donzo
Member#: 95337
2012 Jeep Overland
I couldn't really tell exactly where it was leaking from. I'll look into stainless lines even though I think they're more bling than anything on a daily driver.
Old 05-20-2013, 02:12 AM   #5
aperson
Member#: 273649
2002 WRX Wagon
I'd clean everything off and tighten the banjo bolt and see if it comes back in a few months myself.
aperson is offline   Reply With Quote
Old 05-20-2013, 09:27 AM   #6
Donzo
Member#: 95337
2012 Jeep Overland
Someone pointed out that the bleeder and the cap were marked/painted and they now seem to be turned and not lined up. I'll try to tighten it up tonight.
Does anyone know the ft/lb to tighten it to? I don't want to over torque the thing and snap or crack it.
Old 05-20-2013, 10:31 PM   #7
Donzo
Member#: 95337
2012 Jeep Overland
Ok, so I may have some good news at the expense of my ego. I went to spray and wipe down the calipers after work tonight and the calipers were dry as a bone. I couldn't understand why. I wiped them down and checked the bleeder screw anyway. As I went to replace the rear pads and rotors, I sprayed the bolts with pb blaster... and that's when it hit me. I sprayed the fronts with pb blaster and let it soak in before changing the brakes. So yeah, that dampness was pb blaster and my lack of short term memory.
Old 05-20-2013, 11:01 PM   #8
Agent P
Member#: 341728
2002 stage 3 Bugeye
Try just replacing the two crush washers. See if that fixes it. Who know it might fix it . I'd try that first it's alot cheaper then getting new brake lines
Agent P is offline   Reply With Quote
