Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 05-16-2013, 06:44 PM   #1
con10der8
Member#: 165107
2003 wrx ;)
black/BLUE
Default Please I Need Help...:(
im going crazy trying to figure out whats wrong with my bugeye.
specs: 2.0L stock, stage 2, XPT tune, TBE, UP, K&N filter, 255lph, VF39, 565cc injectors..
it was tuned 2 weeks ago and runs smoothly and holds boost.this morning i used the car to go to work and ran snoothly.
now after getting off work, the car started then died after 10 secs.
i tried to start it again but the nothing.
here are my observations:
fuel pump is running everytime i put the key on "ON" position.
the car cranks but doesnt turn over.
the cluster doesnt show any CEL, oil light, hand brake light etc... only the door jam and mileage are on.
i tried jump starting it using a jump cable but nothing.
now im clueless on whats wrong with the car...please help
con10der8 is offline   Reply With Quote
Old 05-16-2013, 06:54 PM   #2
MMY MSL
Member#: 335135
2007 WRX
WRC blue
http://www.iwsti.com/forums/2-5-lite...o-start-2.html
FWIW... The above thread seemed to have some helpful ideas in it. Search first, post second.
MMY MSL is offline   Reply With Quote
Old 05-16-2013, 07:00 PM   #3
brutnus
Member#: 257195
2004 WRX
2.1L 12k miles strong
i bet spark plugs. To rich.
brutnus is offline   Reply With Quote
Old 05-17-2013, 06:58 PM   #4
con10der8
Member#: 165107
2003 wrx ;)
black/BLUE
still no power on the cluster...new battery installed today but no go.
this morning i tried starting it and it turned over, but died as soon as RPM went on idle.
Old 05-17-2013, 09:35 PM   #5
quazimoto
Member#: 70395
Sounds like a ground problem.
Old 05-18-2013, 02:54 PM   #6
Sypher
Member#: 106366
2006 WRX
I agree sounds like a grounding problem OR an immobilizer problem, check your maf wiring make sure its not grounding out some where, also check your Main relay fuse, and all fuses in the car make sure there not blown. It damn sure isnt spark plugs, trust me you would have had warning sights and a "Rich" situation rarely "drowns" spark plugs to where the car wont even start.
Sypher is offline   Reply With Quote
Old 05-18-2013, 03:32 PM   #7
Nolanb121
Member#: 343531
Spark plugs?
Nolanb121 is offline   Reply With Quote
Old 05-19-2013, 10:49 AM   #8
con10der8
Member#: 165107
2003 wrx ;)
black/BLUE
Ok my friend and i narrowed it down.
We used a power probe between the igniton switch to the fuse box under the dash and eveything works.
But it only works becuse of the power probe putting power to the ignition fuse.. So im guessing it somewhere in between the ignition switch and the ignition key... Is there another relay in between those 2?
Does soemone knows or have a wiring diagram on that fuse box?
Please lmk
Thank you
Old 05-19-2013, 04:44 PM   #9
Wrextasti
Member#: 356426
02 Wrx
Black and pink
I feel your pain. Going through a similar issue myself w/ my bugeye. I been using these diagrams. Hope they help.
http://ken-gilbert.com/wrx/mans/7%20-%20WIRING.PDF
http://ken-gilbert.com/wrx/mans/3%20...C%20ENGINE.PDF
Wrextasti is offline   Reply With Quote
