Old 05-19-2013, 04:18 PM   #2651
cRashtEstDumy
Member#: 291602
2007 Limited STI#464
New question here and let me explain, my car was tuned at 600 hp on e85 last winter and I'm using Denso two step colder spark plugs with I believe a .8 gap. Now that it's getting warmer my car is starting to sputter and pop during idle and to about 3000 rpm, under load spool up and boost the runs fine and pulls hard no popping or sputtering. It also seems to happen more during the day time when it's hot, no codes are showing and my wideband seems to be holding relatively steady. So I guess the question is can the e85 be acting differently with the spark plug in these hotter day or vice versa, should I lower the gap to .6 or raise it? Any advice would be appreciated and please ask me questions if you need more info!
cRashtEstDumy is offline   Reply With Quote
Old 05-19-2013, 04:34 PM   #2652
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
Post or email a log showing: rpm, knock, timing, afr learning, wide band, manifold pleasure relative, maf and sd if running sd.
gaby is offline   Reply With Quote
Old 05-19-2013, 04:46 PM   #2653
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
2 steps colder is too cold for an e85 tune. I'm running over 700whp on 1 step colder.
06rexwagon is offline   Reply With Quote
Old 05-19-2013, 06:22 PM   #2654
cRashtEstDumy
Member#: 291602
Ok, I've never logged anything before, I guess I'll give it a try, I'm running both MAF and MAP hybrid with the Cobb ap.
Old 05-19-2013, 07:33 PM   #2655
gaby
Member#: 94097
[email protected]
Connect coob to car laptop to coob and play with logging data till you get it to work.
Old 05-19-2013, 07:55 PM   #2656
cRashtEstDumy
Member#: 291602
Ok well I just used the Cobb ap to log and I'm getting them ready to post, I did a few variations of logging from idle, idle with rev, 1234 gears normal driving, 4th gear at 3k rpm, 3rd gear at 3k rpm, 3rd gear at 2-2.5 rpm, and finally a wot pull from 123. I'll have it up in a few.
Old 05-19-2013, 07:56 PM   #2657
Andrewxxcarlson
Member#: 316415
2006 WRX
Subscribed!
Old 05-19-2013, 08:16 PM   #2658
cRashtEstDumy
Member#: 291602
Idle:
/Users/juliemahlstede/Desktop/datalog7.csv
Idle & rev to 4k rpm and hold, 3k rpm, 2k rpm
/Users/juliemahlstede/Desktop/datalog8.csv
Acceleration 1-4th gear "normal driving"
/Users/juliemahlstede/Desktop/datalog9.csv
3rd gear @3rpm
/Users/juliemahlstede/Desktop/datalog10.csv
4th @ 4k rpm
/Users/juliemahlstede/Desktop/datalog11.csv
3rd @ 2-2.5 rpm
/Users/juliemahlstede/Desktop/datalog12.csv
WOT pull 1,2,3 gear
/Users/juliemahlstede/Desktop/datalog13.csv
let me know if you cant pull these up, ill try another way.
Old 05-19-2013, 08:42 PM   #2659
cRashtEstDumy
Member#: 291602
Looks like it didn't work, can I just email it to you?
Old 05-19-2013, 09:11 PM   #2660
Andrewxxcarlson
Member#: 316415
2006 WRX
Idle:
3rd gear @3rpm
4th @ 4k rpm
3rd @ 2-2.5 rpm
WOT pull 1,2,3 gear
Host each file on google documents. Make sure the public can see the files by using the file settings.
Old 05-19-2013, 11:05 PM   #2661
gaby
Member#: 94097
[email protected]
Old 05-19-2013, 11:31 PM   #2662
cRashtEstDumy
Member#: 291602
[email protected]
K just sent you the email.
Old 05-20-2013, 12:06 AM   #2663
gaby
Member#: 94097
[email protected]
Working on it looks like is getting too much fuel at lower rpms.
Old 05-20-2013, 12:20 AM   #2664
cRashtEstDumy
Member#: 291602
Lets try this, thanks for your time and patience while i figure this out. if you need me to do different pulls or log different info let me know.
http://db.tt/38vGRNCU
http://db.tt/miMYxw7m
http://db.tt/ydSlGpnK
http://db.tt/IHpzmUwY
http://db.tt/ObVztEql
http://db.tt/AcjYqk8o
http://db.tt/x3WFoMAR
Old 05-20-2013, 01:22 AM   #2665
cRashtEstDumy
Member#: 291602
just did two more pulls in 4th gear from 2krpm to about 6krpm
pull 1
https://docs.google.com/file/d/0B2wB...it?usp=sharing
pull 2
Old 05-20-2013, 01:24 AM   #2666
gaby
Member#: 94097
[email protected]
Check your email
Old 05-20-2013, 01:47 AM   #2667
cRashtEstDumy
Member#: 291602
Thanks gaby!
Old 05-20-2013, 02:00 AM   #2668
gaby
Member#: 94097
[email protected]
Anytime.
Old 08-23-2013, 07:55 PM   #2669
kidtofuu
Member#: 353496
93 RHD GC
Red-ish
Can you tune an ej20k for e85 with just an apexi afc neo? I already have injectors and fuel pump
kidtofuu is offline   Reply With Quote
Old 09-14-2013, 02:55 AM   #2670
Street_EJ257
Member#: 256924
2011 2011 STi
Dark Gray Metallic
Question E85 and Colorado Emissions Testing
I am about to move from Arkansas (a non-emissions testing state) to the Fort Collins area in Larimer County, CO. I have a 2011 STI hatchback w/ full COBB 3" TBE (w/ high flow cat), 44mm EWG setup, 1000cc injectors, and tuned on E85 w/ supporting mods.
There is no way my car is going to pass emissions testing at face value (would not even make it past the visual inspection), but I have heard Colorado has certain conditions which will allow you to be exempt.
They do visual inspection, sniff test, OBDII test, and exhaust pipe probe testing.
FFS, I thought we lived in a free country. You would think the hippies would love that my car runs on 85% renewable energy, but something tells me I'm going to have issues just the same.
Do any of you have any ideas, or experience trying to pass or exempt from Colorado emissions with a highly modded car?
-Josh
Street_EJ257 is offline   Reply With Quote
Old 09-14-2013, 02:58 AM   #2671
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
You should post in the CO regional forum, since your question is not necessarily E85-specific. Probably get better first-hand experience there.
That written, I have had no problems passing IL emissions testing (OBDII test) with a highly modded car.
RP31 is offline   Reply With Quote
Old 09-16-2013, 01:10 AM   #2672
Street_EJ257
Member#: 256924
2011 2011 STi
Dark Gray Metallic
Thanks, RP31. Redirecting to regional.
Old 10-09-2013, 07:26 PM   #2673
mistycargo
Member#: 292608
2012 WRX Hatch
I just got my '12 WRX tuned on E85 and talked to my tuner a bit about the winter blends (E70) which he said the car would richen up but he didn't really elaborate on if anything bad happens. I'm going to get a kit and start testing on fill ups but I'm just curious to what can happen if you were to have some spirited fun on the winter blend fuel?
mistycargo is offline   Reply With Quote
Old 10-14-2013, 02:55 AM   #2674
cRashtEstDumy
Member#: 291602
I'm curious about this as well, obviously less hp but does this also mean the tune will be thrown off entirely and would it be dangerous for the car?
Old 10-14-2013, 07:38 AM   #2675
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
This is exactly why the ecu has long term fuel trims.
What do you need to do to use E85 fuel? wantsti Rocky Mountains Impreza Club Forum -- RMIC 37 02-20-2014 01:27 AM
E85 fueling question- 850cc + fpgreen...adjustable FPR? Blown95ImpalaSS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-29-2009 07:37 PM
E85-Fueled Z06, 30th Anniversary Corvettes to Pace 08 Indy 500 AVANTI R5 Non-Subaru News & Rumors 0 12-27-2007 01:56 PM
E85 fuel available now in Arvada 9/22/06 hotrod Rocky Mountains Impreza Club Forum -- RMIC 9 09-25-2006 02:29 PM
E85 Fuel in Austin? When? dromango Texas Impreza Club Forum -- TXIC 8 06-29-2006 01:32 PM
