Old 05-20-2013, 06:51 PM   #101
samai
Member#: 345221
2013 STi
plasma blue pearl
Hi, all
I am in need of help regarding the installation of the AST 4150's, so far they come with no instructions whatsoever, I never had to put coilovers together and the fact that apparently only the rear have helper springs is confusing. I have camber plates in the front. I am just trying to make sure I am not missing a step.
this is what I have so far.
http:[email protected]/8758578612/
Thanks. Samy.
samai is offline   Reply With Quote
Old 08-18-2013, 07:16 PM   #102
scoobykidzonblock
Member#: 365006
Default thanks
1st post needed. thxs.
scoobykidzonblock is offline   Reply With Quote
Old 08-22-2013, 08:43 PM   #103
Dat8687
Member#: 243261
2004 WRX
Java black pearl
H&R patented ‘Triple C’ Bolts replace the original upper fastening bolts on McPherson strut applications. ????
Why does H&R say to put them there but this faq says you cant put aftermarket bolts in the top spot?
Im confused my coilover set came with the TRIPLE C camber bolts for the front it says to put them in the spot where the factor camber bolt is.. As in Replace it with the H&R bolts..
Nevermind I think I figured it out
Dat8687 is offline   Reply With Quote
Old 08-22-2013, 09:47 PM   #104
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The first camber bolt installed should go in the top hole. Many cheap cars come with NO camber bolts at all from the factory, so the aftermarket bolt IS the first bolt and goes in the top hole. With our cars, that first camber bolt is put in at the Subaru factory. So, in this case, the generic instructions H&R publishes are wrong.
Old 08-23-2013, 09:43 AM   #105
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Yea.. I went back and re-read the faq etc.. Plus the bolt its 14mm bolt so it wouldn't fit properly in the top anyway right?..
I was just wondering because it came with my H&R coilover kit.. I didn't know if the application would be different since im not using the factory struts but the H&R coilovers.
Thanks..
It came with generic instructions as you pointed out.. Hell I don't even know how to put the stock top mounts on the Coilovers.. It didn't give instructions with the kit..
Old 09-01-2013, 06:29 PM   #106
scoobyru845
Member#: 367165
Default need help
I am curious if there is a manual steering subaru out there without converting a power steering rack to manual. i have a 96 impreza outback and i want to go manual steering.
scoobyru845 is offline   Reply With Quote
Old 11-05-2013, 04:50 PM   #107
Jmoneyzzz
Member#: 329553
01 RS-TI
Looking for a good set of struts/springs or coils that are wife friendly but really don't want to drop the cash of Pss9. Mostly spirited driving with some autocross. Any reconnendations? And things to look out for since I know you get what you pay for
Jmoneyzzz is offline   Reply With Quote
Old 11-25-2013, 09:02 AM   #108
Con6tY5efs
Member#: 374396
it is purely to compile links to the actual threads themselves
Con6tY5efs is offline   Reply With Quote
Old 11-30-2013, 11:59 PM   #109
scoobiegirl123
Member#: 374985
1998 GC8
Thanks guys some interesting stuff
scoobiegirl123 is offline   Reply With Quote
Old 03-05-2014, 11:35 PM   #110
skater532
Member#: 382437
good good good
skater532 is offline   Reply With Quote
Old 05-21-2014, 01:18 AM   #111
lifeists
Member#: 354314
Amazing sticky
lifeists is offline   Reply With Quote
Old 07-29-2014, 12:20 PM   #112
oaklandish_WRX
Member#: 267339
2002 0[[XXXXoXXXX]]0
MBP LongRoof
oaklandish_WRX is offline   Reply With Quote
Old 08-07-2014, 09:56 AM   #113
rcatabay078
Member#: 310628
2015 WRX
Crystal White Pearl
Any good write up for installing Fortune Auto Gen 5 Coilovers for 2010 WRX GH8?
Sent from my iPhone using NASIOC
rcatabay078 is offline   Reply With Quote
Old 08-07-2014, 11:36 PM   #114
kizzer505
Member#: 168897
2016 WRX
Coilovers are very straightforward.
- put car in air
- remove wheels
- loosen nuts on tophats but don't remove
- on fronts remove brake line holder
- on fronts remove large bolts holding lower strut to hub (if car has camber bolts in front which it should mark their presentation so you reinstall them the same way
- free strut from hub
- lift slightly and unbolt the top nuts to remove strut completely
- remove bolts in rear strut from lower control arm
- unscrew top nuts and pull out
- reverse process to install new coils
- be prepared to lift car up and down a couple times to check and adjust ride height on a level surface
- go get an alignment
kizzer505 is offline   Reply With Quote
Old 02-16-2015, 07:15 PM   #115
thearchitek
Member#: 413697
2005 Saab 9-2x Aero
KONI posted their official strut insert installation video. Great addition to this sticky:
https://www.youtube.com/watch?v=PXSnNZt3NiI
thearchitek is offline   Reply With Quote
Old 02-18-2015, 11:36 PM   #116
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
- put car in air
- remove wheels
BE PREPARED to repeat 2nd to last step several times(4 times for me/2 alignmnts as well)
to get perfect ride height
-too high.....so you dont look like an Outback
-too low...... so you won't eat up $80 of fndr liners or bow fndrs out
GL everyone!
Old 02-20-2015, 09:57 AM   #117
zgrunstein
Member#: 413994
2011 WRX Hatch
WR Blue
I'm looking for a good kit of coil overs. I live in Montreal and need something for good bump absorption with good dampening so I don't want to kill my wheels on these potholes. I don't want to spend too much $$$. It's a 2011 WRX Hatch GR body. Let me know if you guys got some good ideas.
Thanks.
Sent from my iPad using NASIOC
zgrunstein is offline   Reply With Quote
Old 02-20-2015, 10:20 AM   #118
jaboyd
Member#: 247304
2011 STI
WR Blue
Cold/harsh w/salt and pot holes is a TERRIBLE application for coil-overs, IMO. Upgraded struts w/springs works best in those conditions.
jaboyd is offline   Reply With Quote
Old 02-20-2015, 11:48 AM   #119
zgrunstein
Member#: 413994
2011 WRX Hatch
WR Blue
What kind of application would you suggest because I have Koni/Eibach on my Lancia Delta and it's hard like a rock. I want something that can absorb well
Old 02-20-2015, 11:57 AM   #120
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
This is not the correct place to ask for recommendations!
Stop trashing the thread and start one for your questions.
Old 03-13-2015, 04:25 PM   #121
Ol' Dirty Doug
Member#: 280790
2003 wrx
Hey guys I've been a member for a while but do not use this site very much due to my wrx being down for a while. I am looking for someone to point me in the right direction to possibly a thread how to or something.
I have a 2003 wrx. I have a donor 2005 sti. I am trying to do the Brembo STI brake swap on it.
Can someone post a link to one hopefully. I have been looking and can't find one. Thanks
Ol' Dirty Doug is offline   Reply With Quote
Old 04-25-2015, 03:25 PM   #122
NubImpreza
Member#: 413825
2015 base Impreza
Jasmine Green Metallic
New member here. Most of the posts refer to 2012 and earlier models. I have a 2015 Impreza base 2.0 and I'm Looking for absolute certainty that same year or previous years of WRX coilover will fit my car bolt on without alteration. Can anyone lead me to this conclusion please. Thank you
NubImpreza is offline   Reply With Quote
Old 07-10-2015, 07:37 PM   #123
rlew21
Member#: 395708
2008 WRX Hatch
Nubimpreza. Talk to the guys at rallysport direct, they are very knowledgeable when it comes to fitment.
rlew21 is offline   Reply With Quote
Old 07-11-2015, 06:01 AM   #124
NubImpreza
Member#: 413825
2015 base Impreza
Thanks bro. I already got my ride lowered with RSR springs.
Old 08-11-2015, 09:06 PM   #125
Zetto
Member#: 427875
iIm looking for a thread about the 08' Impreza 2.0 steering collumn... Its very difficult to find any information here in Brazil, so i hope i can find it here.
My Impreza makes that annoying whining noise when u turn the steering wheel, but i've replaced that o-ring located at the hose wich connects the power steering pump and the reservoir. I also changed the pump itself twice, and i've noticed that inside the pump there was like little pieces of rubber, and my mechanical told me it could be the steering collumn. He said that it could be worn out, releasing this rubber i found inside the pump, and causing the blockage of the pump, the noise and eventually, fluid leaking.
Anyone here knows if its even a possibility? Ive never heard anything like that, and i think my mechanical is crazy!! hahha !!
Well, thank's anyway!
C ya,
Zetto
"and now i wait"...
Zetto is offline   Reply With Quote
AZP Installs -Your Tri-state Brake and Suspension Installers- AZP Installs Suspension/Brakes/Handling 10 09-09-2008 07:35 PM
Ten+ simple rules for Brakes/Steering/Suspension - READ THIS BEFORE POSTING! Butt Dyno Brakes, Steering & Suspension 5 04-09-2008 11:25 AM
ssautochrome install walkthrough? Ceyvme Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-06-2006 06:46 PM
kyb agx and spring install walkthrough?? CXspeed Newbies & FAQs 4 05-09-2006 10:45 AM
Boost Gauge Install Walkthrough? Uncle Ben Electrical & Lighting 4 07-15-2003 04:31 PM
