Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 05-21-2013, 02:39 PM   #1
Member#: 116409
2006 Steel Gray STi
2001 Dodge Viper GTS
Default Holes in rigid black tubing on stock intercooler of 06 STI
Found two small holes in the rigid black tubing assembly that bolts to the top front of the intercooler of my 06 STI. Two questions. What kind of performance problem would that cause, and what is a suitable way to repair the tube?
INDY_06_STI is offline   Reply With Quote
Old 05-21-2013, 04:34 PM   #2
Member#: 330625
2006 WRX
Thats the crank case vent tubing. I cant remember the vac line routing off the top of my head but I believe that is an after maf, pre-turbo air leak, not to mention it'll get oil mist all over the top of your engine.
Old 05-21-2013, 05:06 PM   #3
Sammo Hung
Member#: 10613
not good..thats unmetered air being sucked into turbo since the holes are past the maf sensor. I would replace them.
