Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Old 05-15-2013, 05:28 AM   #1
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Default 2012 WRX Boost Leak?
I have a 2012 WRX running Torqued Performance Stage 2 map @ 19 psi, along with a Cobb Catted Downpipe.
At one point while running TP Stage 1, I acquired the typical boost leak from the throttle body, which was the clamp completely loose. I fixed the issue. The leak at the time made the car sound like it had an intake.
Now at Stage 2 I hear a high pitched squeak at certain rpms under boost. Sounds like you blowing air into a bottle. Not sure if that's a leak or something else.
Any suggestions would help.
Note: according to AP, I hit target boost. Sometimes a 0.1-0.4 spike over 19 psi. Also, still have the rubber gasket couplings over the intercooler to throttle body that is usually the culprit.
Here's a video:
https://www.youtube.com/watch?v=ZRYY...e_gdata_player
Subie FA20 is offline   Reply With Quote
Old 05-15-2013, 07:22 AM   #2
jpatt006
Member#: 289470
2010 Forester XT
Remove the rubber gaskets from the throttle body hose and retighten, preferably with t-bolt clamps.
If the problem still occurs, try a smoke test to see if there is a boost leak anywhere else.
jpatt006 is offline   Reply With Quote
Old 05-15-2013, 07:40 AM   #3
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Yeah, I was gonna remove them. Figured to give it a shot and ask here as well.
No t-bolts on hand, I would have to order them. Have to find out what sizes.
Old 05-15-2013, 08:00 AM   #4
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Not sure about the wrx, but the for the sti TB to IC coupler a 2.75" t-bolt clamp works great.
Old 05-15-2013, 08:23 PM   #5
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Bought new clamps, removed the inserts and its still there. Also notified my underside intercooler looks all mangled... no idea from what
Old 05-15-2013, 08:32 PM   #6
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
Bpv? The stock one leaks sometimes even with the stock boost levels....
moonrider_99 is offline   Reply With Quote
Old 05-15-2013, 08:52 PM   #7
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Im guessing maybe... i'm just too cheap to spend the money on it this second
Old 05-16-2013, 07:26 AM   #8
jpatt006
Member#: 289470
2010 Forester XT
Snap pics of the intercooler if you can.
Before you spend any money on new parts, do a smoke test. No need to buy a $100 BPV when it could be a $10 hose, or even just a disconnected line.
Old 05-16-2013, 09:27 AM   #9
Dr. octagon
Member#: 171127
2015 Subaru
search google.....NASIOC BOOST LEAK TESTER..........make one, cost you about 40 bucks.
Dr. octagon is offline   Reply With Quote
Old 05-16-2013, 10:09 AM   #10
nmlittlebigman
Member#: 321409
2003 Big Effing Van
7.3L powerstroke diesel
Old 05-21-2013, 06:38 PM   #11
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
or buy one for less than $40 bucks, there is universal testers on ebay.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 05-21-2013, 07:02 PM   #12
blehhh
Member#: 316517
2012 WRB WRX Hatch
TP Stage III & ELH
My EBCS makes an absolute racket under really heavy load and it kind of sounds like a boost leak. Everything is tightened to oblivion though, and I'm pretty sure it's just the intake & EBCS tweaking out together with all that air.
blehhh is offline   Reply With Quote
Old 05-23-2013, 12:12 AM   #13
Subie FA20
Member#: 72195
2016 Golf R DSG
Oryx White Pearl
Did a quick datalog.
Hit the target boost (19 psi) for a whole 1 second
https://docs.google.com/file/d/0ByJA...it?usp=sharing
