Welcome to the North American Subaru Impreza Owners Club Wednesday August 31, 2016
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 05-08-2013, 11:57 AM   #1
Anthony1288
Member#: 354010
2004 WRX
BLACK
Default Help
Hey Everyone so i just got this 04 wrx the guy who i bought it from lives in PA. so here we go i tried to get the car to pass NYS INSPECTION they told me 2 of my monitors, Evap and Cat, are not ready so i called him up to let him know wast going on he tells me the owner before him has a STAGE 2 tune on the car so in order to pass i need to go back to stock well i did that with my buddy's stock 07 STI parts but i need Someone's HELP on here if it's possible can use your AP to flash ECU back to stock so i can pass. i will pay you. it has to be a 04 AP NOT ON 04 STI AP if you live in Syracuse let me know if you can HELP till i can save up 595 to buy my own AP and it's Sedan > 2004 thanks
Anthony1288 is offline   Reply With Quote
Old 05-08-2013, 01:30 PM   #2
pushnpounds
Member#: 207683
02 bugeye
wrb
an ap can only return the car that it's married to back to stock. if your car is tuned with an ap and you don't have it you have to leave it alone or get a new ecu.
pushnpounds is offline   Reply With Quote
Old 05-08-2013, 01:41 PM   #3
novacivic
Member#: 117980
2005 sti
wr blue
Not entirely true. All you have to do is in marry the accessport from the car it is married to then you overwrite the tune on the second car with any tune. Them you unmarry it from the second car and now the car is back to stock and the accessport can now be reinstalled on the original car.
novacivic is offline   Reply With Quote
Old 05-09-2013, 11:06 AM   #4
Member#: 165919
2004 WRX wagon-PSM
BYT Tuned
are u sure it was tuned with an accessport and not opensource? would save ya alot of time and money
04wagon@stg2 is offline   Reply With Quote
Old 05-13-2013, 09:57 AM   #5
Anthony1288
Member#: 354010
2004 WRX
BLACK
Yep that's what he tell me
Old 05-13-2013, 10:33 AM   #6
Anthony1288
Member#: 354010
2004 WRX
BLACK
I just call Cobb and a new AP will work and my car to fix my problem
Old 05-21-2013, 01:05 PM   #7
Anthony1288
Member#: 354010
2004 WRX
BLACK
Still need some help to pass Emissions testing thanks
Old 05-21-2013, 02:42 PM   #8
LIChuck
Member#: 266122
2007 WRX Limited
UGM
Your problem is more than a tune. Are the cats still on the car? If not, depending if your mechanic is going to do a visual check, you either have to replace the cats or disable the codes.
The evap could be as simple as a bad gas cap.
Find out what is causing the codes and then fix it. The AP can help you because you can disable the error codes, but you may still have a problem to solve.
LIChuck is offline   Reply With Quote
Old 05-21-2013, 02:52 PM   #9
Anthony1288
Member#: 354010
2004 WRX
BLACK
I replace the gas cap Already So I put the car in test mode and check this is what I found P1518 p0851 p1153 p1152
Old 05-21-2013, 02:53 PM   #10
Anthony1288
Member#: 354010
2004 WRX
BLACK
I can get the car to pass Without a cat I know the people and they won't even check for it
Old 05-21-2013, 08:58 PM   #11
Gyges
Member#: 297111
2006 STi
Mine passed no cats at all. I bit my tongue when the technician said "maybe we should do a visual check on this one?"
Thankfully they didn't and I rolled right thru. Randolph NJ DMV
Gyges is offline   Reply With Quote
Old 06-12-2013, 12:09 PM   #12
Anthony1288
Member#: 354010
2004 WRX
BLACK
Hey update my car pass One new 02 and a retune
