Old 05-21-2013, 03:28 PM   #1
kdizz781
Member#: 340925
2013 WRX sedan
Dark Gray Metallic
Default 2013 WRX Oil Leak
Hello All,
I have a 2013 WRX and just noticed I had a small oil leak.
I saw a spot in my driveway and so last night, I laid down some cardboard under the car just to make sure it was mine, and sure enough when I checked this morning it was.
I have no idea where it is coming from, so I called the dealership and set up an appointment (Friday).
Any recommendations for what I should check besides oil levels, filter and drain plug?
kdizz781 is offline   Reply With Quote
Old 05-22-2013, 09:11 AM   #2
matigas_TT
Member#: 322775
2012 WRX-4Dr
Honestly.. Your thread is not informative at all.. Any mods? Mileage?
Anyway.. Im sure that oil leak is from tb to ic hose.. Happened to me twice and went to the dealer twice. When I had an extra money i bought an aftermarket hose and never had a problem
matigas_TT is offline   Reply With Quote
Old 05-22-2013, 09:17 AM   #3
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
There was a run of defective oem oil filters out there months back. The seal would go bad and begin to lose oil. Check your oil all the time before you drive in to the dealer.
Old 05-22-2013, 09:35 AM   #4
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
There shouldn't be SO much oil that it puddles in there enough for it to make it all the way to the ground anyway, a small amount is normal. Now you're burning it instead of it leaking out, you put a bandaid on what could be an actual problem.
On top of the filter and plug, check the mating surface for the oil pan, sides of the heads, and check the bottom of the timing cover. If there's oil in the timing cover, look for run marks coming from the crank, if there aren't any coming from the crank look for spray coming off of the cam gears. There's a ton of places that it COULD be leaking from, if you find a run try and follow it back.
If you weren't already, you should check your oil at least once a day until it gets fixed.
Old 05-22-2013, 02:43 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Step one: Stop posting
Step two: put cars on jack stands
Step three: crawl under car
Step four: look for source of leak
Since we are on the other side of this here Internet, we can't do that for your. Possible sources for and oil leak are numerous and the easiest way to find it would be to use your god given senses. Its not rocket science.
Old 05-22-2013, 03:46 PM   #6
kdizz781
Member#: 340925
2013 WRX sedan
Dark Gray Metallic
No Mods, and it has 5,000 miles on it. I just got it in September. In fact I have only had 1 oil change so far, and it was done at the dealership. I'll check the tb to ic hose... thanks!
I checked the drain plug and filter... It didn't seem to be coming from either source... I keep checking my oil but the levels have been good.
Thanks tho
Step 1: Stop being a smart ass
Step 2: Already got under the car, hence referencing the drain plug and oil filter
Isn't the point of a forum to connect with people "on the other side of the internet" to discuss a common car? If your going to post, make it helpful for me and others that might have the same issue with their late model WRXs. Contribute something meaningful.
Otherwise move on and post your high horse remarks on a different website.
Old 05-22-2013, 04:25 PM   #7
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Its not a high horse but common sense. Any place there is a flange, a gasket, an oil line, or anything that contains or holds oil source of the leak. We could list all the possible sources of leaks but its as really is just a matter of cleaning the area and monitoring it for the oily residue and drips to return. I have an oil leak from the base of my oil filler tube that drips down the side of my valve cover. Does that mean that's where yours is leaking from? Probably not but I found the leak with my own two eyes because I am always under my hood or under my car maintaining or working on it. You're making it a bigger deal than it need to be.
Old 05-22-2013, 05:37 PM   #8
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
put the car up in the air,remove the engine cover and see where the oil is coming from. its that easy. if not bring it to the dealer, you have a warranty.
Old 05-23-2013, 01:18 AM   #9
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Pictures would help too. Most oil leaks are usually above where you see residue.
SlimJim8804 is offline   Reply With Quote
Old 05-23-2013, 07:05 AM   #10
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
i agree but the engine cover is gonna make the oil come from the same area regardless. its only got a few holes in it.
Old 05-23-2013, 12:26 PM   #11
Wireeater
Member#: 76503
2015 WRX
Oil leak? Use your warranty...
Wireeater is offline   Reply With Quote
Old 05-24-2013, 03:24 PM   #12
kdizz781
Member#: 340925
2013 WRX sedan
Dark Gray Metallic
Found the source of the oil leak. It was the oil line to the turbo. The dealership took care of it.
Old 05-27-2013, 05:39 PM   #13
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Oil feed or return?
Picture didn't work.
Old 05-27-2013, 10:05 PM   #14
kdizz781
Member#: 340925
2013 WRX sedan
Dark Gray Metallic
Oil feed or return?
Let's try that picture again...
BTW it is the oil feed
Old 05-27-2013, 10:32 PM   #15
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Yep, that's her. Thanks for the heads up.
Old 03-11-2015, 03:05 PM   #16
keonigt
Member#: 304739
Chapter/Region: HIIC
2013 WRX premium
Is the car covered under warranty if he is running stage 2?
keonigt is offline   Reply With Quote
